Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Line across picture
Ctc 169
    Sergeant:
    Champion:
  • 319 Answers
A thick, drifting line across the screen indicates an open or leaking capacitor in power supply. Needs service repair
Posted on Apr 23, 2008
I have a 52" RCA TV Model 52w1913yx1, when I turn it on the green LED will flash and then go out. There is no High Voltage and no picture.
I suspect High voltage splitter is bad, can you confirm chassis number?
It is on label on back with model number, something like CTC or PTK 169 OR 171.
IF ONE of these chassis or similar I can tell you how to prove block is bad and where to find and replace--most of these sets also have year they were made on the back.
I am here to help you for free.
SD TECH
Aug 31, 2010 | RCA Televison & Video
RCA P46731AT
Do you have the number of the board
that the glass bead was on
Dec 02, 2007 | RCA P46924 46" Rear Projection Television
Picture just went off but the sound is still there
you just lost hi volt. that a ctc 169 chaiss.
Jun 24, 2010 | RCA G36710 36" TV
When turned on you view only a vertical line. i beleave a power surge caused this. what part or parts do i need to replace. mod no-ps35123. tnank you
There is no vertical chip in this model/ ctc 169.
it's a transistor- resistor - cap circuit.
It's either the yoke wires on neck of the tube have
become de-soldered or the more likely possibility
is the viliot / white wire from the yoke have simply
become de-soldered if you first re-solder those two
Jun 01, 2010 | Televison & Video
I bought a new 27 inch proscan in 1991. It was
This is probably a tv with the "ctc-169" chassis. The BEST modern chassis RCA built. I own 2 of them that I USE, one is a 32" CONSOLE, a lot like your 27" set the other is a projo. I would keep BOTH of them ANY day--over ANY of the cheap, unreliable, fragile flat--panel sets today!!
FIX your set!! If the picture was good--it still will be--these sets had GREAT tubes in them. Most likely--a power supply isue with a couple of caps in the power supply, perhaps the controller chip for the chopper transistor, nothing likely serious. Probably about 150 repair--or less.
Oct 10, 2009 | Proscan Televison & Video
Have rca proscan w ctc 168/169. will not turn on. had bad fuse, i replaced, plugged in and still won't power up. fuse did not blow.
fuse blew due to short. look for visual sign of something burnt.if not, unless you know how to use volt ohm meter, call tech.
Sep 20, 2009 | Televison & Video
RCA 52 inch
three strikes and it's out... rca does this, it is just showing it has tried 3 times for you and untill it is unplugged it won't try again.. you need to provide model #.. could be a few different things
hissing usually meens you have high voltage...that's good but then what don't you have?
ctc 169 - 179 could be high voltage divider... need more info
Oct 17, 2008 | RCA R52WH73 Projection Television
Proscan (RCA) PS52652
Also, the proscan ps52652 has the ctc-169 chassis. This set is a 52" manufactured in 93.
Mar 30, 2008 | RCA P52926 52" Rear Projection Television
Need download (EASILY OPENABLE) RCA CTC 169 PROJ TV Schematic / Serv Man FREE
Check here for the download.
You may want to get a new winrar download to open the files.
Good Luck.
Mar 02, 2008 | Televison & Video
RCA P46771A2 (Made in '95)
since it is a 1995 tv if you will post chassis number (on back it will say ctc i am thinking ctc 169 mybe i can help) doc
Aug 16, 2006 | RCA P46924 46" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
21 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
