Question about Boating
WE HAVE RIVENDELL PONTOON BOAT WITH ALL PEICES AND AIR TO INFLATE, SAD THING IS WE NEED TO PUT IT TOGETHER TO GET IT IN WATER. ASSEMBLEY
SOURCE: Arrow Backpacker Inflatable Pontoon Boat
goto http://www.classicaccessories.com/subcategory.aspx?id=19 and download instruction. 40 pages PDF files.
Posted on Apr 17, 2009
SOURCE: I need a new inflation valve for my colorado pontoon boat
Check E-bay -
Item number: 310151809453, Pontoon Boat Boats Outdoor Parts Repair Kit Kits black
What is your problems with pontoon bladder
Thanks for reply
Posted on Jul 09, 2009
SOURCE: I have a Simoniz 1900 presure washer and had to
i took my pressurewasher simoniz s1900 apart, i had to take off the pump and all oil leaked out.
how and where can i fill the oil in to the pump
and what type of oil would i use
thanx ernte
Posted on Sep 21, 2009
  • 72 Answers
SOURCE: HELP! My new little 200 boat will NOT INFLATE!
Hi, perhaps the problem may lie with the inflating method. Have you checked to see if the pump is actually giving air? These rafts usually have multiple bladders, are they all giving you this problem? Also, there is a plastic flap at the inside the base of the valve to prevent too much air from escaping before you plug it. you mush insert the air chuck adapter past this point. Good Luck!
Posted on Nov 15, 2010
SOURCE: I have a water skeeter
www.nrsweb.com
Posted on Aug 01, 2011
HELP! My new little 200 boat will NOT INFLATE! Have tried everything. I had another one that inflated immediately and this one will not! it is as if it has no way in the valves for the air to get into...
Nov 10, 2010 | Intex Excursion 4 Inflatable Boat Set
2005 Water Skeeter Pontoon..What kind of pump for the valves
If you look up Halkey-roberts valves you will see the air filler part.
May 24, 2010 | Water Skeeter Guide Lite Pontoon Boat
Assembly of a Cimarron Pontoon Boat
have a similar boat, but it's been a year or so since I used it. Here's what I remember.
Lay it all out first. It's very confusing until you get a visual. The seat rests on two bars. These bars span the two pontoons. I believe they use pins, rather than bolts to secure it. You probably have a basket and maybe a trolling motor mount. Get rid of the mount, unless you plan on using it. If you do, it attaches to the rear basket. The basket mounts to the back of the chair and rear bar with bolts.
Next, the leg holders slide in and there should be pins to hold them in place for the right distance. If there is a stand up plate and a casting bar, you're on your own on how to attach them. Obviously they go in the front, but I have no idea how they are attached.
Mine had an anchor, but this was a huge hassle. Much easier to pull to shore than park in the water.
There is probably a mesh type piece that fits under or around your seat with bungies or hooks. It may have a fish measure on it. If it does, that goes to the front.
The oars are merely pinned in at a comfortable spots. There should be oar "stops," that slide over your oars. Again, you have to adjust the length to how long your arms are. They don't slide too easily. And, they are needed so your oars don't slide off into the water.
The side bars should have a hump to rest the pontoons on. Buy a double pump and save some time, (or an electric pump). The following is the most important fact of all, You have two bladders in each pontoon. Inflate them BOTH. Air up one from the front, then the other from the rear, back and forth until the pontoon is ready to burst. This prevents a disaster. If one deflates or is punctured, the other one has enough air to support you to shore. Strap them on and you're ready to go. And I would suggest a practice run in calm water first. They are a little awkward at first. Good luck
Jun 16, 2009 | Classic Accessories Cimarron Pontoon Boat
Assembeling the Cimerron Pontoon Boat
I have a similar boat, but it's been a year or so since I used it. Here's what I remember.
Jun 02, 2009 | Classic Accessories Cimarron Pontoon Boat
Check E-bay -
Thanks for reply
May 30, 2009 | Sage Colorado Pontoon Boat
Boating Logo
216 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
