Question about Dometic Refrigerators
No lights, no nothing - Dometic Refrigerators
  • Sheldon Dedek Jul 18, 2010
    no model # either?
  • Gerry Ducolon Jul 18, 2010
    It is a Dometic ndr1062 3 way.We replaced the lower power board and the upper eyebrow board. There is power coming into the 110 fridge outlet. Is there an internal reset or breaker other than the two on board fuses on lower power board.
  • 905 Answers
Your model # NDR1062 indicates a 2 Way refrigerator, the presence of only 2 fuses confirms this.
Your fridge, though it it can use 120vac, also requires 12vdc to operate. At the back of the fridge (access through vent), there should be a terminal block where the DC connection is made. Using a multimeter, measure the voltage across the terminal block. Follow the ground wire from the block over to the common ground point, and measure from +12vdc to the ground point. You voltage should be the same. If you are not getting your 12vdc here, then check your coach fuse panel for a blown DC fuse for the fridge.
If you are getting your 12vdc at the terminal block, measure terminal J4 on the control board, to ground. You should have the same voltage as there is at the terminal block. Don't touch J5, that may have 120vac on it. If you don't have 12vdc at J4, look for missing / damaged wire that connects to J4 from the posititve connection at terminal block.
If you do have 12vdc at J4, check both sides of the DC fuse (3Amp). You should have 12vdc on both sides with respect to ground.
Grounding is crucial, esp. at the tie point. There must not be any corrosion or play in the connections.
Posted on Jul 18, 2010
Why does light comes on turntable turns when door opens nothing lights on display or nothing works ?
Normally faulty micro switch which needs replacing: Caution: hight voltage may be present so best left to service person
Jul 23, 2014 | Oster Microwave Ovens
50PF9631D
Red light only? Does set have sound or nothing except power light?
Jun 13, 2012 | Philips 50PF9631D 50 in. HD-Ready Plasma...
The sensing light comes on ,clicks, nothing happens
the sensing light comes on, I hear a click but nothing happens.
Dec 12, 2009 | Whirlpool GEW9200L Electric Dryer
Light on inside come on but nothing else
Need to make sure you have 240 volts at the wall. 120 on each leg.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
No sound but all lights light up. Displays DT7000
Bonjour,
I have exactly the same problem with my DT7000. Did you find a solution to your problem?
Stephan
May 01, 2009 | Audio Players & Recorders
No power. No lights.
I have the exact same problem.
TV was working fine (if you call having to deal with blinking lights of death and multiple starrt up errors...) - but I powered through it all.
This TV is 6 years old and started acting up after the 4-year extended warranty ran out.
This morning I went to turn it on and nothing.
Hmmm... Got my manual to count the blinking light code...
Whoops. No lights. Nothing. Checked plug. Checked power.
Uninstalled and installed lamp. Checked plug and power again.
Nothing.
Not one stinking light. No power to fan. Nothing.
How does a TV just DIE???
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No lights(lits)on WLAN-No acces from the computer
WLAN light will give you the status of your wireless connection. If WLAN light is off, it might be a possibility that wireless has been turned off or worse is the device had stopped broadcasting a wireless signal. you may try using 192.168.1.1 to get into the setup page of the device to check if wireless has been disabled.
Aug 29, 2008 | Trendware TEW-630APB (TEW630APB)
Refrigerators Logo
131 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
