Question about Dell Dimension™ 4600C PC Desktop
I have replced the fan for theheatsink and i have power but nothing else the guy at a computer shop pulled the heatsink and the chip came out any thing you know
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Just go to https://www.rbypass.info/ and enter www.myspace.com in the search field which should have www.google.com already inserted, then hit the go button, and you should be able to access myspace, but if not, there are options underneath where you enter the website address, just try messing with the buttons to see if it makes any differance.
Posted on Jul 17, 2010
The video CPU fan is not working. How do I replce it?
Yes it can be replaced or you might want to just remove the fan and have the heatsink exposed but add extra case fans for better airflow.
Jul 12, 2012 | NVIDIA GeForce 7300 SE
Tip
How to Remove a AMD Processor
<p>Removing a processor AMD is a work that can only be done with a screwdriver in less than 30 minutes. The processor AMD is a central processing unit (CPU) with 939 pins, which are connected to the motherboard. Removing the processor is an issue to withdraw from the motherboard with your hands after you remove the heatsink from the chip.<br /> <p> <br /> <p>1. Turn off the computer and unplug the power cord before removing the AMD processor. Unplug the connector on the back of the computer case and remove the screws, the lid of the computer, in the case with a screwdriver.<br /> <p><br /> <p>2. Slide the computer cover and set aside. Pull the cord that connects the heatsink fan on the motherboard with one hand.<br /> <p><br /> <p>3. Lift the lever on both sides of the fan heatsink, so straight up and remove the plastic clips on the sides of the sink on the motherboard.<br /> <p><br /> <p>4. Pull the heatsink and fan on the motherboard and set it aside.<br /> <p><br /> <p>5. Lift the AMD processor motherboard and carefully remove it from the computer.<br />
on Jun 21, 2011 | Computers & Internet
I need to take apart an inspiron one19 to replace the fan
Are you replacing the system fan, or the CPU heasink fan. The first is simple, the second, is less simple, but not too hard.
Unscrew the screws in the back of your case (most have 4-6) Depending on your case, you may only have to pull the screws on the left side (as you look at the PC). Remove the exterior case.
The system fan will be held in place on the back of your PC by 4 smaller screws. Unscrew em, and disconnect it from the power supply. Install the new fan in the opposite order, and call it a day!
If you're replacing the heatsink fan, you may have to get more detailed instructions on the exact fan/heatsink model. Some are screwed in, some are clipped, ect. Just remember: if you do pull the heatsink fan, DO NOT touch the chip, and before you put a new one back on, DO use thermal grease. Nothing more disappointing that replacing it twice because you forgot this step. Good luck.
Mar 16, 2011 | Computers & Internet
I have a Lenovo 3000I have a Lenovo 3000 J115 7387-A32, I replaced the AMD athlon 64x2 Dual-Core 3600+ with a AMD Athlon X2 5000+ 3200mhz Scoket AM2+ CPU, when I turn on the computer the fan in the power...
I think the first thing to do is go back to the cpu Fan and check the plug and make sure you are on the pins as should be make sure that there isn't any Bent pins . Continue on to the next fan in question.If not then I would not continue Running this machine Until I had the fan problem fixed. It doesn't take long to mess things up. I am surprised that it will run . I would like to have faith in the hardware monitor to propely shut it down.then I would go to the power source Plug on the motherBoard . Check that it is connected good and try it for a short run on then off to make sure that the fans are running like they are supposed to.
Nov 19, 2009 | Computers & Internet
Toshiba Satellite 1005-S157 shuts down periodically by itself. Replaced fan/heatsink. Still shuts off.
you need to check a few things... when the fan/heatsink assembly were replaced, did you make sure that the thermal pads on the CPU and GPU are NEW/Good.... Make sure that the Heatsink GPU pad Firmly sits in the chip....
You can test the thermal controller by using a hair dryer or heat gun.... Point it onto the heatsink pipes and see if your fan spins when the pipes get hot, then remove and see if the fans slow after a minute...
You might have faulty RAM or Misseated RAM... Pull The RAM chips and reseat them...
Also Make Sure Your CPU Is Locked Down....
Periodic Shut Downs Can Be Caused By Quite A Few Different Things...
Typically it's due to Thermal Damage
Though Failing RAM or A Failing Hard Drive, Overheated Video/GPU Chip, Or Even Failing CPU can as Well Cause This Issue...
Nov 16, 2009 | Toshiba Satellite 1005-S157 Notebook
Gateway laptop ml3108b no screen coming on
this is a common fault with this laptop, the only way to repair this is to strip the laptop, remove the mother board, heatsink and fan under the heatsink you will see the nvidia chip this needs to be heated to 480C for about 5 mins only heat the nvidea chip nothing else! paste chips and replace heatsink fan etc laptop should now be fixed, remember to clean fan whilst it is out as a clogged fan probably caused the fault in the first place
Jun 11, 2009 | Gateway M305CRV Notebook
Chip Set Fan Replacement
Try doing this. If you can, Un plug your computer, then remove the fan from the Heatsink. Using water and Dishwashing Liquid soad mix in a container. Soak the fan in the solution for 1 hour. Then rinse it using running water. Then sun dry it for 3 hours. Then re-affix it to your Heatsink! Hope this helps.
Sep 17, 2007 | DFI LANPARTY UT ICFX3200 T2R/G Motherboard
ASUS NCT-d
Hi, have you tried removing the CPU and using a Air Jet Spray can to clean all contact pins and pin holes? The problem sounds like a loose chip. So also check all on board chips are seated, including RAM chips. Air spray can be bought from most Computer stores. Goodluck mistyman
Sep 09, 2007 | ASUS NCT-D (90MSV430G0UAY) Motherboard
Dell Dimension™ 4600C PC Desktop Logo
Alun Cox
