Question about Canon imageCLASS D680 Laser Printer
The copier is putting a wrinkle down the length of every page
  • 1,219 Answers
it could be two things wrong.
First:
Maybe the paper has too much moisture. Try to flip paper in cassete, upside down, and let few copies go. If then is OK, use fresh paper!
Second:
The worst case scenario, that I mean most costly is trouble with fixing pressure.
It could be worn pressure bushings or worn pressure roller. For that call service, youself cant do much, it must be replaced.
Hope that helped!!
Posted on Jul 17, 2010
Why is my photo copier wrinkling the paper sometimes?
Check the lower pressure roller at the heater unit for damage.Also see to it that the copies are alligned before it enters the heater unit ..
Aug 01, 2014 | Toshiba 6LH58317000-OEM Estudio 355...
Crease in page when printing cannon image runner 1310
A crease is usually caused by two issues. 1 ) paper is hitting something on the way to the fuser causing a skew. This type of problem would be repeatable every page as well as causing the image to be off centre. The 2) reason is the more likely cause. A bearing on the lower (pressure roller) is beginning to seize. Causing paper not to feed straight through the fuser. This cause a wrinkle from from to back on the sheet of paper. This wrinkle although repeatable generally the wrinkle position up or down on the sheet. This gives the impression of something that is getting in the way of the sheet. If you can change your lower pressure bearings you should be ok again.
May 03, 2013 | Cannon Office Equipment & Supplies
Every page printed has a wrinkle pressed into the paper
Its or moisture issue or wrong pressure between fixing roller and press roller.
Jun 30, 2010 | Office Equipment & Supplies
My Dell 1100 keeps wrinkling and tearing the paper
Depending on wear the tear is at determines the issue. The wrinkling paper and the look of your printer sounds like some sort of fuser issue. Recycled paper is more likely to wrinkle and the grain can cause paper to wrinkle as well. The Long grain paper is up and down the sheet and short gain is side to side on a sheet of paper. If your printer is on a long grain setting and you have the pages coming out sides ways or vice versa then your print outs can wrinkle.
Jun 22, 2009 | Dell 1100 Laser Printer
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
CLJ8550n poor print quality and wrinkled paper
this is usually not caused by the paper tray. this problem is usually caused by the fuser assembly. check your paper path. dead cycle the printer, shut the printer down before the paper enters the fusing area, check for wrinkles. remove all paper, print again, check the output, wrinkles, replace the fuser.
Feb 03, 2009 | HP Color LaserJet 8550n Printer
Paper Wrinkle when Printing
Its time you need to change the Tension roller of the printer.
Dec 16, 2008 | Office Equipment & Supplies
Wrinkled paper
bom dia, minha al 800 travou com a queda de energia e aparece h 4 naum sei mais o que fazer alguem pode me ajudarv a desbloquear??obrigada
Nov 02, 2008 | Sharp AL 800 Copier
Wrinkled pages
check the fuser film it may be dirty or must be repalce.
Jun 23, 2008 | HP LaserJet 1015 Printer
Canon imageCLASS D680 Laser Printer Logo
111 people viewed this question
old marine
old marine
