Question about Maytag Neptune MAH5500B Front Load Washer
I'm getting an error code of "do" and "fl" on my maytag neptune washer. Last time this happened we payed $100 to have him push some buttons and reset the washer. He did not take off the front, just pushed buttons on the panel. Does anyone know what we can do?
    President:
  • 2,468 Answers
Check the pump and all drain lines for any obstructions or hose kinks
Posted on Jul 17, 2010
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
I s a Maytag Neptune washer error code "FL" something I can reset myself?
Error on the door lock or the door switch, try and use a switch cleaner, remove and reset the lock or check the harness to the switch
click this link: Door lock
Jan 20, 2013 | Maytag Neptune MAH5500B Front Load Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Fl error on washer
Hello there :
I am hoping that i am reading this right it looks like you said a fl error right and if so please read this whole solution that i have provided below
FL Flood Condition FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
If this condition continues have the machines water level switch replaced or repaired
Hope this is very helpful for you
Best regards Michael
Feb 11, 2010 | Maytag MAH6700AWW Neptune Front-Load...
My maytag neptune washer appears to be dead. No lights come on at all. I cannot get any error codes at all after pushing the buttons it says to push in the manual. I used the washer just last night and...
theres a possibility that you could of took a spike through the wires which could of taken out the controler board if you had extended warrenty you can get someone out to service the problem if not then you will have to pay for a service person to come out to fix/replace the part which your looking at around $130.00 +
Dec 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune Model #: MAH5500BWW is flashing
The error code you describe is not listed in Maytag's book of codes. The link below will take you to Maytag's website error code page where you might be able to match it up.
http://maytag.custhelp.com/app/answers/detail/a_id/2885/session/L3NpZC8yY3lEMjNEag==/sno/0
Jul 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune mah550bww will not start up , gives a code FL
The FL error code means:
Flood Condition: FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a backup valve or flap in the drain assembly that seems to sometimes cause problems with the FL error code. Remove this piece to see if it helps.
If this is a new installation - check that the hoses arent reversed (cold on hot and hot on cold). This will also cause the FL error.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH5500B, FL code and door locked.
Check your drain and the drain line all the way to the pump. Here is some info on the F1 code.
FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for "FL" to be displayed
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
LID WON'T LATCH ERROR CODE FL
With that code FL “ Failed to lock” I would start looking at the lid latch mechanism. See this link from another site for lid latch problem.
http://fixitnow.com/wp/2006/09/06/maytag-neptune-fav6800aww-top-load-washer-op-code/
If you want to try to repair or get a better understanding of how to diagnose and repair this machine take a look at the service repair manual.
http://www.servicematters.com/maytag_library/docs/16022808.pdf
I hope this will help with your decision to try a repair or replacement.
Good luck with your issue.
Jan 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Error Code FL
it is saying failed to lock the door need door latch switch part # 22003269
Apr 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
1,053 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
