Question about Campbell Hausfeld 26 - Gallon Air Compressor
Electric compressor will not start up im getting power thru the switch but comp.doesnt attempt to start.
    President:
  • 2,468 Answers
Your pressure switch is defective that controls the cycling of the motor,its fed air pressure off the tank line and opens and closes contacts to start and stop the motor to build air pressure when needed
Posted on Jul 17, 2010
My craftsman 4 gal pancake compressor kicks of the breaker when the switch is turned on. split second buzz aand then OUT GO THE LIGHTS...
well craftsmen doesnt make 3phase compressors in fact there all low voltage 120 volts , so lets start there the outlet your using is it rated for 20 amps 120 volts ? if not theres your problem but thats ok unplug compressor and use a small screwdriver thru the fan end to move motor shaft around thru one complete turn if you encounter any real friction the unit is damaged and needs repair
Sep 28, 2014 | Air Tools & Compressors
I have an lg split system airconditioner. The unit starts up fine and runs for a few minutes. After a few minutes it trips the circuit breaker. Could you tell me what causes this? Thank you
Sounds like an electrical problem.. or the compressor is beginning to fail. Check the wiring connections on top of the compressor for burning etc ... If OK, the compressor may be shorted out.
Make sure the power has been switched OFF before any testing is done.. Usually an LG will show a fault code on the display on the internal unit but a dead short on the comp will happen to fast for this to occur. One way to isolate a compressor fault is to disconnect it.. If the unit runs ( fans etc) with the comp disconnected and does not trip the breaker , then you have narrowed down what the fault is.
Jul 14, 2011 | Heating & Cooling
The compressor runs fine and shuts off when the pressure builds up to the appropriate level. When I use air, it tries to kick on to build pressure up again, but it's not able to get started and...
Check the circuit feeding power to the compressor. These conductors may be too small. Conductors have a degree of resistance. Resistance consumes power. The power conductors consume is dissipated as heat and present a voltage drop to the equipment being served. Length and size of the conductors determine power loss.
An electric motor momentarily needs up to six times the running power and this power loss is squared ( PxP) at start up.
The bottom line: Shorten the length of the conductors or increase the conductor size to avoid voltage drop.
Aug 10, 2017 | Craftsman 33 gal Air Compressor 6 hp...
What size compressor can I run
You would need 10 times the watts it takes to run electric air compressor,the start up takes a lot more amps to get it going ,then it will level off to the amps,what ever they are.That is the problem,getting it to power up,then it is fine,so you are looking at about 8000 watt gen.
Jun 13, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Desktop doesnt start
may b your power supply is fail check Ur power supply. if that is OK it's mean Ur motherboard fault.
Feb 27, 2010 | Computers & Internet
2006 3500 a/c problem
see if you have power to the comp is it a 2006 see if you have power on thre dark blue and yellow wire if not could be a code set or problem with power module at left frnt fender
Jun 15, 2009 | 1995 Dodge Ram 3500
Help! air compressor trouble.
ASSUMING YOU ARE TALKING ABOUT THE PRESSURE SWITCH. YOU SHOULD EITHER HAVE 2 WIRES OR 4 WIRES ON THE SWITCH. THE SWITCH IS TYPICALLY MARKED LINE-LINE-LOAD-LOAD. IF YOU CAN SEE THE INSIDE OF THE SWITCH YOU WILL SEE THE CONTACT POINTS. ONE CORD WIRE CONNECTS AND PASSES THRU ONE SET OF POINTS TO ONE WIRE OF THE MOTOR. THE OTHER CORD WIRE PASSES THRU THE OTHER SET OF POINTS AND CONNECTS TO OTHER MOTOR WIRE. YOU TYPICALLY WILL NOT HURT THE COMPRESSOR BY HAVING THIS WIRING INCORRECT - PROBABLY JUST POP THE BREAKER INSTANTLY. IF YOU CANT SEE THE PATH THRU THE POINTS YOU CAN OHM THRU THE POINTS AND GET A CONTINUITY BEEP ON A VOLTMETER. IF THATS NOT AN OPTION, JUST SWITCH THEM AROUND UNTIL IT RUNS. HOPE YOU BOUGHT THE SAME CUT-IN AND CUT-OUT PSI. GOOD LUCK AND WRITE BACK IF THIS DOESNT GET IT. JODY
Apr 05, 2009 | Campbell Hausfeld 26 - Gallon Air...
GE chest freeze won't get cold
the noise your hearing indicates the possibility of a bad start relay on the comp or possibly it just came loose during the move. on the side of the compressor you will see 2-3 wires running into an electrical connection reseat this first. if still no operation replace teh relay. you can purchase thru any reputable appliance parts dealer. after replacing the relay if you have no operation then likely problem is seized comp.
domestic freezers do not have low pressure switches that indicate low freon charge.
Jan 28, 2009 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
206 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
