FixYa.com
Tags:
Panasonic CQ-R925 CD Changer
Grounding Problem???
By kioner - usenet poster
To all those more expert than I (which is most of you):
I recently installed a Panasonic CQ-R925 head unit (very happy with it, by
the way) in my 98 Contour.  I used all the factory harnesses and the
original speakers.  The unit has an AUX input on the front, through which I
play my portable CD player.  When I use the player's cigarette lighter power
adapter I get a nasty buzz, which goes away completely when I run the player
off batteries.  Not the usual alternator whine:  the noise is constant
frequency.  I think it's a ground voltage problem.  Is there an easy fix, or
should I just stick with the batteries?
All advice greatly appreciated.
MG
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 10, 2005
Not Rated (0)
Phoebe
Phoebe - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I think I had the same problem as you, but I had my Panasonic ShockWave
portable CD player hooked up directly to my Rockford Fosgate amp, and I
would get those annoying pops and static when I was powering the CD player
off of the car, but it was crystal clear when I used batteries. SO, I went
to Wal-Mart and get a Scosche EFX ground loop isolator, and it basically
went away(it's not even audible when the CD player is playing). So, try a
ground loop isolator, and if it doesn't work, take it back.
Stalker
96SL1a BkGd/Tn AC SP AU++++ DFW SR NG
712ejd$ot @oak.prod.itd.earthlink.net...
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Riddle
Riddle - usenet poster
Rating: 0%, 0 votes
I have a similar problem.  Is there anyway to fix the loop without
interefering with the audio side of it?
Brian
Solution #3
Not Rated (0)
pawa
pawa - usenet poster
Rating: 0%, 0 votes
I'm not sure what causes your problem, but there is part of the FAQ about
car audio which I found on the net, and it may interest you.
"Many people report problems while playing CDs from a portable CD player
into their car audio systems. The problem, stated very simply, has to do
with the stepping of the motor requiring a varying amount of current and
non-isolated power and audio signal grounds. Using a liberal application of
capacitors and inductors, this voltage variance can be restricted to a
window of 8.990 to 9.005V for a 9V CD player, yet even the swing between
these two levels is enough to cause annoyingly loud noise on the outputs. It
has been reported that this entire problem can be solved by using a true
DC-DC inverter at the power input to the CD player."
Can you Help with these Car CD Changers problems?
Car CD Changers
2001 crv cd player
I recently bought a 2001 crv LX... Answer This...
Car CD Changers
eax510 excedio with prestige fm...
modulator screen blank and... Answer This...
Car CD Changers
CD Player in my Citreon C3
How do I operate my CD Player... Answer This...
Car CD Changers
car radio
I have bought a 1997 dodge... Answer This...
grounding problem?
Hi there, my audio system was... Answer This...
Repair Service
Find Car CD Changer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
