Question about Frigidaire FGQB4000F Dryer
WHERE IS THE HOUSE FUSES LOCATED? - Frigidaire FGQB4000F Dryer
  • 760 Answers
If you're reading your manual and it refers to "house fuses" they are the fuses or most likely now circuit breaker in your "house" that supplys the voltage to the dryer. In other words, check your main electric panel for a tripped breaker or blown fuse.
Posted on Jul 17, 2010
Where are the fuses located on the front load washermachine
Could it be the house fuses? I doubt there are fuses in a washer.
Sep 25, 2014 | Maytag MAH6700AWW Neptune Front-Load...
I have no power to oven or burners. Where are the fuses located
there would be no fuses in the stove itself. Try the house breaker or fuses to the stove.
Sep 20, 2014 | Whirlpool Accubake RF362LXTT Electric...
I have a kenmore stackable washer/dryer. The dryer spins but does not heat. I looked at the owners manual and it states that one of the house fuses needs to be replaced. Where are the house fuses...
Hi jahusmc...
To find your house fuses/breakers look for a box that is mounted on a wall within the house.
It will have a metal door on the outside and will contain all the electrical circuts controlling the house.
Once you locate the main breaker box, look for a breaker in the box that looks "out of place" with all the other breakers, if you find one, recharge it by pulling/pushing on the toggle of the breaker to reset it. Once that is done you should have voltage again.
The easy way to see if you have voltage at the plug is to use a volt ohm meter, check the receptical for the correct voltage either 110-120 volts or 220 volts depending on what your dryer uses.
Please take time to rate me
Aug 29, 2011 | Dryers
Where are the house fuses in the manual located in they dryer
The fuse box is either located in the garage or basement of the house.
May 07, 2011 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Where are the 2 house fuses located at on a frigidaire dryer model #GLEQ2152EE1
The house fuse is located in the breaker box, more often than not the breaker box is in the garage or in the basement.
The fuse that stops power from getting to the motor is located on the heater assembly. I can alk you through this repair it is relatively simple. I know this dryer very well I work on seveal of them a month. If I don't respond quickly you can find help below.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Dryers
Where are house fuses
the circuit breaker is a 30 amp double breaker, it is located in your main panel inside your house. There are fuses in the dryer itself, and here is a website that will be more then helpful, Tim:
http://www.applianceaid.com/gas_dryer.html#noheat
Nov 29, 2010 | LG DLG3788W Gas Dryer
Where are home fuses located on the kenmore dryer?
If you were told to check the home fuses its the circuit breaker for the house. If the house is older it may have a small circuit breaker just for the dryer. Otherwise open the circuit breaker for the house and look for the dryer fuse. Usually 2 20amp breakers together. Flip it off and push towards off a little more to reset than flip back on.
Jul 30, 2010 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
I'm looking for the two house fuses mentioned in the trouble shooting section of the dryer manual; runs but wont heat. MODEL # is FEQB400FSI
they should be in you fuse panel in the house .how ever you can check the heating element and the thermal fuses located in the cabinet of the dryer
Sep 05, 2009 | Frigidaire FEQ1442ES Electric Dryer
Can't find fuses on my smooth top range
There are no fuses on the range. The fuses or circuit breakers are located in the electrical service panel for your house.
Feb 18, 2009 | GE Spectra JBP78 Electric Kitchen Range
House fuse
If you have a two pole circuit breaker
there will be no fuses
the breaker replaces the fuses mentioned in the manual
Most common cause of dryer running but no heat is a blown thermal fuse. a protective device that fails if airflow is restriced and temperature rises.
the thermal fuse is mounted on the fan body or exhaust duct and looks like one of these
ac65851.jpg ce345c9.jpg wired in the heater circuit
explicit instructions to open the case/body of the dryer depend on make and model which are not stated.
If the thermal fuse has blown the dryer needs to be cleaned of the lint that got past the screen, into the fan and exhaust duct all the way to the vent on the exterior wall 2092f63.jpg thermal fuses are ~$14
Nov 01, 2008 | Dryers
Frigidaire FGQB4000F Dryer Logo
111 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
