Question about Dryers
I need a basic wiring diagram for a 3spd, 3 wire capacitor ceiling fan with reverse slide DPDT switch. The rotary pull chain switch is connected to: L-black (line), 1-3uF Cap., 2-6.5uF Cap., 3-yellow to one ?? of the four DPDT switch connections. Now, what connects to the Cap. input? Do the two center connections of the DPDT go to the rotating motor winding, or does one go to the static motor winding? This is a MOSS Heirloom Deluxe ceiling fan, mid 80s
2 Suggested Answers
SOURCE: I need a basic wiring diagram for a 3spd, 3 wire
Try L-BLACK 1-GRAY 2-BROWN 3-PURPLE. IF THIS COMBO DOESN'T WORK. BLACK WIRE GOES TO L , 123 IS YOUR SPEEDS YOU WILL HAVE HOOK THEM UP BY PROCESS OF ELIMINATION FIGURE OUT WHICH IS HIGH MED & LOW. IT SHOULD BE 1-HIGH 2-MED 3-LOW.
Posted on Jul 27, 2010
Where can I purchase a Jin you e70469 ceiling fan switch.
ebay 14 bucks
Jin You E70469 Pull Chain Switch for 3 Speed Ceiling Fan 4 Wire 1 2 ...
https://www.ebay.com > ... > Lighting Parts & Accessories
item 2 ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire -ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire. ... item 3 OEM ZING EAR ZE-208S 3 SPEED CEILING FAN PULL CHAIN CONTROL SWITCH E-89885 DR73 -OEM ZING EAR ZE-208S 3 ...
Exhaust Ceiling Fan Switch 2 Speed Pull Chain Blower Jin You ...
https://www.ebay.com/itm/...Ceiling-Fan-Switch...Jin-You-E70469...-/132376583704 Replaces Jin You E70469, Santa, Gardner Bender GSW-33. The control module provides two speed setting for your fan. 2 Speed Pull Chain Switch. 3" (7mm) Brass Chain. Spark Electric Components LLC. Width 11/16" (18mm). ' eBay!
Jin you e70469 ceiling fan switch Google Search
Dec 12, 2017 | Dryers
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
Lights come on at random .has a remote how to fix ?
The fan remote control receiver used in the Hunter 25730 model fan (see picture) is not available from Hunter. Remove the fan from the ceiling. Remove the receiver and take it to recycling. It can be replaced using a readily available and inexpensive replacement universal remote and receiver controller. There are limitations though. The Hunter receiver provided fan reversing functions. The universal controllers do not. You therefore have two options.
Option 1: The universal receiver can be installed such that the fan direction is fixed, either up or down, all other functions operate normally.
Option 2: A reversing switch can be purchased from Radio Shack for about $4 and installed in the fan. This does require cutting a square hole and drilling two bolt or rivet holes in the side of the cylindrical housing which previously housed the Hunter receiver. I'd suggest the Radio Shack DPDT slide switch part number 275-403.
Refer to the wiring diagrams and connector pinout diagram for connections. Please note that the connector pinout diagram is the connector that is soldered to the circuit board as shown in the photo of the Hunter receiver. If your motor wire colors are different then with the connector unplugged from the receiver use a multimeter to probe all the motor wires in order to identify two pairs of wires that indicate approximately 70 ohms each pair. These will be the motor windings. 6b0a1409-5a20-4efe-a059-c600652e9512.jpg 5da8e4ef-1b54-40d0-a8a4-21d4608b1d23.jpg 9fc8772d-3ac3-41b7-aa55-78ccc6e5ea00.jpg 0759e340-6464-4c4b-90f5-6d9926e74e42.jpg
Jan 23, 2014 | Hunter Ceiling Fan Light Remote Control
Old fan switch has 4 wires, new one has 3. A Ceiling fan light switch is for the fan, not the light, correct?
You have 2 questions:
1) Pull-chain Switch question:
You need a fan switch with 4 wires.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=202191016&langId=-1&catalogId=10053&PID=500871&cm_mmc=CJ-_-500871-_-10368321&cpncode=00-29062147-2&AID=10368321&cj=true&srccode=cii_9324560&locStoreNum=577
Your pull-chain switch has one wire that connects to Hot from wall switch. And then one wire for each of the 3 speeds.
Best way to start is to test the old switch with continuity tester.
Compare results with following image of 3-wire switch for general reference:
http://waterheatertimer.org/images/Fan-motor-1-500.jpg
2) Ceiling fan pull chain switch is for the fan only.
Jul 18, 2011 | Westinghouse Electric Ceiling Fan 3-way...
I need a basic wiring diagram for a 3spd, 3 wire capacitor ceiling fan with reverse slide DPDT switch. The rotary pull chain switch was removed along with the cap, so i do not know how to put a new switch...
Jul 24, 2010 | Hampton Bay Dryers
Ceiling fan capacitor hook up problem. I have a 3 speed fan. 4 switch. A 3 wire capacitor - CBB61. Kids lost wiring diagram. Any which way I try to wire it up only one of the speeds works. Any wiring...
The reverse switch on my Hampton Bay ceiling fan didn't work. I cut the 6 wires; 1 white, 1 gray, 2 pink, 2 yellow. Here's what I did. Removed reverse switch. Had 6 wires white, gray, 2 yellow, 2 pink. Connected gray to yellow, connected white to pink and fan runs fine. Is this OK? I do not need to reverse fan. It's been running for 1 hour now with no problems. Don S.
May 15, 2010 | Dryers
Cealing fan wiring problem
Hi, try this.
The pull chain has four wires, L, 1, 2, 3. Connect '3' to the main black (hot) wire entering the fan. Connect 'L' to the red wire on the reverse switch. connect '1' to the lowest uF, eg ( 1.5 uF ). Connect '2' to the next uF, eg ( 3uF ). The other end of the capacitor has to be connected to the neutral wire, ( black with pink or white). If you have a VOM tester, check that pull switch is working properly, eg when the switch is on the Hi speed position, you should get a continuety reading on all the ends of the switch,
Apr 05, 2009 | Westinghouse Fans Indoor Ceiling Fans
I'm trying to install a used Shell Electric Manufacturing (Holdings) Co. LTD. model U42 ceiling fan, however it appears that the internal wiring has been moved around and in some cases cut off. I am...
the black rectangle is a capacitor! there is no diode in a ceiling fan, usually the white wire is the common or neutral , the blue is for lighting and the black one is for the fan
Mar 10, 2009 | Dryers
Trying to replace 3 speed ceiling fan switch and don't know which wires go where - 3 speed fan switch, 4 wire unit.
Hi
The pull switch has 4 wires, L, 1, 2, 3.
Connect ' L' to the reverse switch red wire or the wire that is free.
Connect ' 3 ' to the main black ( hot ) wire entering the fan.
Connect ' 1 ' to the capacitor's lowest uF eg. ( 1.5 uF )
Connect ' 2 ' to the capacitor's next uF eg. ( 3 uF )
the Capaciotr also has to be connected to the neutral wire entering the fan, usually black attached to another color wire. If you have a VOM tester, veryfy that it is a neutral wire.
Regards
H. Montero
Aug 06, 2008 | Westinghouse Fans Indoor Ceiling Fans
Dryers Logo
425 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
