Question about Toshiba Satellite A100-S8111TD Notebook
SanDisk port I'm trying to insert my memory card from my camera into my Toshiba Satellite a205 laptop. in the front, there is a port with the obiovs logo for SanDisk, my memory card. It wont open. i dont know how, anyway. Help much? thanks!
The port is empty.it dosent come installed with this particular series.
Posted on Apr 21, 2008
My Toshiba Satellite A205 S5000 came with 2 Ram memory chips of 1GB each. The OS is Windows 7 with 32-bits. Can I upgrade the memory to 4 GB by inserting 2 memory chips of 2GB each?
Hi Lewis
yes you can
here is the link but is cheaper if you just write down the exact numbers from the website and buy in computer warehouse or shop.
http://www.crucial.com/uk/upgrade/Toshiba-memory/Satellite+A205+Series/Satellite+A205-S5000-upgrades.html
but don't forgot to clean your laptop airflow with air duster every month with this you prevent the dust clogging up.
blocked airflow lead to owerheating
and heat differential is not good especially on lead free compound because the composite of welding material contain
silver and aluminium these metals hate each other both has different friction and heat transfer.
lead is more efficient but by eu law is not permitted any more.
if you want to run fast tasks you should go for pc laptop has modified core voltage is slower than computer
and all the high spec numbers are to attract customers to spend money.
Oct 23, 2013 | Toshiba Satellite A205-S5000
Toshiba a205-s4707 will not boot windows from any location.
You didn't mention the DVD/CD rom? Shut down, unplug, remove battery, plug in reboot and try this procedure: http://www.ehow.com/how_5766144_restore-satellite-laptop-factory-disc.html
Dec 16, 2012 | Toshiba Satellite A205-S4707 Notebook
Toshiba satellite CD door will not open
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Oct 31, 2012 | Toshiba Satellite Computers & Internet
Toshiba a205 color off on screen, it seems that the colors are bleeding
Try this first. Start your Laptop in Safe Mode. Are you still having the problem. If you are try reinstalling your graphic card drivers..the color bleeds are mainly due to improper installing of graphic drivers...the blue screens are usually due to memory dumps(RAM problems)...
Sep 12, 2009 | Toshiba Satellite A205-S4607 Notebook PC
I cant find the xd slot for my toshiba satellite l300d
Sorry all_smiles_0 but I'll possibly wipe your smile away with the fact that your lappy only supports
SD, card, SDHC card, Memory Stick, Memory Stick Pro, Multi Media card
I don't see Xd in the list, so, the reason you can't find a slot is that it doesn't have one...
However there is a silver lining, you lappy has vista which supports the vast majority of cameras natively. Try finding the USB/Firewire/1394 port on your camera and hooking it directly to your lappy and you may find the vista picture wizard appears on it's own and offers to import the pics. If it doesn't, don't worry many of the main accessory manufactures io, startech and the like make USB based Xd readers, if you have no reader and your cam won't download without you shoud be able to find one for $20-$30 at your local computer store.
Hope this helps,
Chris
Armor-IT
Apr 24, 2009 | Toshiba Satellite A205-S4617 Notebook
I purchased 2x 2GB DDR2 rams for my laptop (toshiba A205-s5823) but only one will work in the slots with a 1 GB in addition. I've tried every variation in both the slots. What am I doing wrong?
Your laptop can only accommodate a maximum of 2GB of physical memory. If you are running Windows Vista, you can get a little extra memory by using the "ReadyBoost" feature that is built into the OS. I have done that in the past and it works well for me.
Here's a link to Kingston's (a good memory mfg) memory guide for your model laptop:
http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=43561&mfr=Toshiba&model=Satellite+A205&search_type=&root=us&LinkBack=&Sys=43561-Toshiba-Satellite+A205-S5823&distributor=0&submit1=Search
Let me know if that helps!
Mar 11, 2009 | Toshiba Satellite A205-S5823 Notebook
Toshiba satellite a205 s5825 memory upgrade
what my audio setting suppose to set to step by step on my Toshiba satellite A205-S5880
Jan 29, 2009 | Toshiba Satellite A205-S4617 Notebook
S-Video Output and SD Memory
S-Video would allow you to run your laptop onto a TV, you would have to buy an S-video cable and have a tv or box that is s-video compatible or buy a converter. You would connect the cables to the tv from laptop and Using th <FN> and <F5> toggle between lcd/external/both
SD media card reader just reads SD card you have e.g. camera memory cards, data transfer etc.
sd card is inserted pin side down and pushed in till it clicks in place
Apr 21, 2008 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
111 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
