Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
Briggs stratton,16 H>P> runs smooth 'til mower is engaged.
Engine runs smooth "til mower is engaged then is sputtersand pops. After 20- 25 min. Engine stops. Copius amounts of smoke while running(darknot white).. Just had valves adjustednew plug new gas filter new air filter tune up. It runs the same as it did befor we took it in to get repaired. Mech thought it might be coilbut opted to check valves etc. Said ther was a lot of gas sittting on the piston head. Any ideas?could it be the carb is running too rich? It's 5 yrs. Old and has mowed hundreds of acresdry land farm dustyetc. Thanx in advance tmc
    Sergeant:
  • 197 Answers
Is the choke staying on perhaps? check spark and plug check airflow, get compression test maybe the oil/compression rings giving way... sounds like its getting hot and increasing fuel flow for some reason??? perhaps clean carb with some cleaner while running (remove air cleaner) spray directly into carby while running run at full throttle as you spray it will try and die ... relax on the spraying and see how it goes.. check air cleaner for blockages as the same time :) hope you get it working!
Posted on May 04, 2017
5 Suggested Answers
  • 3 Answers
SOURCE: oil in air breather
sounds like you have too much oil in the engine (should normally be around 500-600ml when there is too much oil, it gets past the piston rings and pushes it through to the head.
Posted on Jul 09, 2009
  • 384 Answers
SOURCE: engine will not start. there is oil in the air
I would start by draining the old gas out of the tank and filling with fresh gas. Replace the spark plug.
Posted on Jul 13, 2009
honeymokey
  • 3113 Answers
SOURCE: carb is getting clogged and spark plugs fouling
Carburetor cleaner will ruin the rings and do that.
Posted on Apr 13, 2010
  • 4088 Answers
SOURCE: Briggs and Stratton Vanguard 23Hp starter issues
The starter may need shims between the engine and starter to permit the relative gears to release. Compare the two starters, if you still have the old one, for shaft length and bendix construction. Hope this helps!
Posted on Jun 06, 2010
Testimonial: "drallim, Everything checks out, cannot believe I've received 2 bad solenoids from NAPA. I had bought a new one and exchanged it because it seemed the switch was sticking. Still have not solved problem. Thank you for your time and efforts. Tim"
Where is oil filter on 13.5 briggs
Briggs & Stratton Riding Lawn Mower Engine Oil Filter #696854 ...
? 2:05
https://www.youtube.com/watch?v=QjYmbfGU0qg
Aug 22, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacing the oil filter on a Briggs and Stratton small ...
Oil Change- Briggs & Stratton 12.5hp Mower - YouTube
? 5:05
https://www.youtube.com/watch?v=udjoD-mW5ig Aug 15, 2012 - Uploaded by Alex's Bikes and Motors
Oil Change- Briggs & Stratton 12.5hp Mower. Alex's Bikes and ... This is going to sound weird, but I can't ...
Oil Filter 492932S - Briggs & Stratton Parts
https://shop.briggsandstratton.com/us/en/parts-and.../oil-and-oil.../oil-filter-492932s Briggs & Stratton oil filters are engineered to keep your Intek, Vanguard OHV and twin cylinder engine running smooth. Save on costly repairs -- order genuine parts today!
oil filter on 13 5 briggs Google Search
Mar 12, 2018 | Briggs Garden
Engine not running smooth until blade is activated
ill bet this is an older briggs engine ? as they seem to need a little tlc on there governor speed control spring for it's feedback to the throttle , this makes the engine surge a bit (hunting) till a load is placed on it then it runs smooth , now if it doesn't smooth out under load id suspect a carb fuel flow problem
Sep 02, 2015 | Briggs & Stratton Garden
Briggs & Stratton engine model # 4455770435E1, need to find out what part number to order to fix alternator? Told our "stater" was bad?
The alternator (P/N 592831) should put out around13-14 volts DC with no load (other than charging the battery. If the voltage drops only when the deck is engaged but not when the lights are on it could be a connection to the mower clutch causing excessive current draw. I suggest covering the fundamentals such as ensure the battery is healthy, ensure all connections are clean and tight before condemning the stator. then and only then would I remove the flywheel to inspect the stator.
Aug 16, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Give me a diagram of a 3.5 briggs-stratton push mower
If your lawn mower has no throttle lever, it is most likely the throttle spring. it is too tight or too loose, you will have to *play* with it to get it right, or even replace the spring. hope this works..
Sep 01, 2012 | Briggs & Stratton Garden
Engine runs fine than after about 10 min it starts to surge and than quits will start up after a short cool down but does the same in a short time Frank
This seems to work a lot.
As the engine starts to surge, loosen the fuel cap.
If the engine runs smoothly again, clean the vent holes on the cap.
Good Luck.
Gary
May 02, 2011 | Parks Optical 13.5hp Briggs And Stratton...
Briggs & Stratton Poulon Pro 600 Series Cuts Out After a Min
Water in the carb bowl. Primer charge is gas...what the main jet draws is water! Tipping backwards lets the water move away from main jet pickup and clean fuel to enter engine.
Drain the tank. Then the carb and fuel line. Then check your gas can for watery fuel. *(dump it into a large plastic bowl and look to see if there is a layer of water on the bottom. If you shake up the fuel before you pour it off you will see cloudy liquid if there is water in it).
That should do it.
Jul 17, 2010 | Briggs & Stratton Garden
Lawn mower; when I engage the mower the battery discharges and the engine boggs down
It sounds like you have some kind of short that gets 'activated' when you engage the mower. Check your wiring around the moving parts.
Jun 04, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
203 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Bill Boyd
Daryl Gleaton
obsteiner
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
