SOURCE: I dropped it in water...
Take it apart and let it dry, thats about all you can do I dropped my mp3 into water and I just let it dry before tryiing to turn it on, I let it sit out all day in the hot sun. To my surpise it still works today.
SOURCE: NO DRINKING WATER
common problem the water line inside the freezer door is frolzen up . to fix remove everthing from the freezer door , turn off freezer . open freezer door and put a blanket over the opening to the freezer leaveing the door to room temp for an hour or so to defrost . check if defrosted . remove blanket close door . this will happen with ge , try seyying the freezer control on the next lower number (warmer)
SOURCE: OASIS drinking fountain , no water
Pull the water jug and open the top of the unit. Look for frozen water. May need repaired or adjusted to keep water from freezing.
SOURCE: drinking water from refrigerator stopped dispensing immediately
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , pt # WR49X10173 which comes with instructions , to keep this from happening again .
Testimonial: "Determined that it wasn't the water line freezing up so my husband is next going to check/replace the valve if needed. If this doesn't resolve the problem, not sure what the next step is to correct the problem?! Thank you very much for this information!"
SOURCE: Sunbeam Drinking Water Cooler model YLR2-5-24H2
my hot water faucet is broken!!.. when can i get new?
