Question about Casio Watches
I have a casio illuminator digital watch (2 time zones showing) - water resistant to 50 m -- 3 buttons:adjust, mode, EZADJ -- I cannot find any instructions on how to set the various functions and am looking for a manual on this watch -- can you help?
  • 2,272 Answers
All the model numbers have near to same procedures.But i will mention the basis setting.as no model number is provide for the watch, Time and Date The time and date  are your watch's most used functions and the first things you should set on your Casio Illuminator wrist watch. From regular time-telling mode, press and hold the top left button on your Casio Illuminator until the seconds place digits begin flashing to indicate the time setting screen. Press the bottom right bottom once to set the seconds place digits to "0." The bottom left button of your watch can be used to advance the flashing to the hour, minute, day, month and year. Press the bottom right button repeatedly to set the flashing digits to the desired number; hold the button down to scroll through the numbers more quickly. When you are finished setting the time and date on your Casio Illuminator watch, press the top left button to exit the setting screen and return to time-telling mode.
  • Some Casio Illuminator watch models are ana-digi combos, meaning that, in addition to a digital time display, they also have a traditional watch face that uses seconds, minutes and hour hands to tell time. To set the analog time on a Casio Illuminator ana-digi watch, wait until the seconds hand is in the 12 o'clock position and then pull out the watch crown. Rotate the watch crown clockwise or counterclockwise until the hands are pointing to the desired digits. Push the watch crown all the way back in to finish setting the analog time on your ana-digi Casio Illuminator.
  • Daily Alarm Setting a daily alarm on your Casio Illuminator watch can help remind you of something you're supposed to do at the same time each day. To set a daily alarm on your watch, press the bottom left button on your watch until you enter alarm mode. Once in alarm mode, press and hold the top left button until the hours digits begin to flash; you can advance the flashing from hours to minutes by pressing the bottom left button on your Casio Illuminator. Use the bottom right watch button to scroll through to find the desired number. The top left button can be pressed to exit the alarm setting screen. When your daily alarm sounds, press any button on your Casio Illuminator to silence it. Stopwatch The stopwatch function of your Casio Illuminator can be used to time athletic performances. Measure elapsed time by using the top left watch button to start, pause and stop stopwatch timing. Your Casio Illuminator can also be used to record lap and split time. As when using the stopwatch to measure elapsed time, use the top left button to start and stop the stopwatch. Press the bottom right button to freeze the lap or split time. To completely reset your stopwatch, press the bottom right watch button a second time. For getting manuals you can get it from  http://world.casio.com/wat/download/en/manual/ just fill the correct model number of your casio watch and get the required ,manual.If its still available with the casio service center.
    Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
    Posted on Jul 17, 2010
    Can not change from 24 hours mode to 12 hours mode on CASIO DW9052-1B
    1. Press [A], the top left button, and the seconds should start flashing 2. Once you have some digits flashing, press [D], bottom middle button, and will switch between the 12h/24h formats 3. Wait a few seconds and the digits should stop flashing and return from the time set mode, to timekeeping mode.
    Here is a link to a manual directly from Casio, showing you all of these steps. As per the explanation on top of the manual, this should work with 3 different models of Casio watches, including yours. http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1659.pdf
    Have a good day
    May 06, 2011 | Casio G Shock DW9052 1V Illuminator ...
    Resendly purshased a casio 4772 watch. diplay time and city. trying to get it set for dst. read manual and cant get button (A) to flash. can u help
    Hi ...
    your watch supports Time Zones , Automatic time Updates, Automatic adjustments of DST.
    First Verify Correct Home City Is Selected
    1. In Time Keeping Mode (That is The Digital Display shows time and Day of week)
    2. Press Button (A) long enough to country code start to flash on digital display.nightflare_4.png
    3. Press Button (B) or Button (D) to change Country code to current one.
    4. After Selecting Desired Country, Press button (A) TWICE.
    Now Country Code will be saved on watch.
    Supported Country codes are:-
    To Activate DST (Daylight Saving Time).
    2. Press Button (A) long enough to Digital Display start to flash.
    3. Press Button (C) TWICE to Display DST Settings.
    4. Press Button (D) repeatly to cycle through three DST Options:-
    A --> DST is set on Automatic Mode. If Your country uses DST, the watch will Adjust DST Accordingly.
    OFF --> DST is set to disabled. No DST is applied to Main Time Settings
    ON --> DST is Set to On. DST is applied even if your country doesnot follow DST.
    5. Press Button (A) TWICE to save Selected Option.
    Default values (Factory Settings) when you bought this watch is
    This way you can set DST
    Mar 13, 2011 | Watches
    On my Casio G-shock GW500A, the time is off. i dont want it on 24time and its an hour ahead
    Sounds like you're set for the wrong time zone, and your 12h/24h setting is off.
    To change time zone: Hold down the adjust button until it beeps. Your time zone will be flashing at the bottom of the display. Use the Time Memo and/or Receive buttons to change it to the correct time zone. Then... To change to 12H mode: Press adjust again. 12H or 24H will be flashing at the bottom. Use the receive button to cycle the mode. When it's what you want, press adjust once more.
    Feb 26, 2011 | Casio G-Shock GW500A-1V Wrist Watch
    How do I change 24 hour time to 12 hour
    You have to press the ADJUST button then you hold down the MODE button and while you are holding down the MODE button press the G (illuminator button)
    Jan 27, 2011 | Casio G-Shock Classic DW6900-1V Wrist...
    I have a Waveceptor 3353. If I change time zone I can usually set the watch to show ,say, Paris time both digitally and in analogue. When I try to go back to my home time zone, London, the second hand...
    If you cannot find the automatic way of setting the hands, you can manually reset the analogue hands by pressing the mode button until you reach the "HS" mode and using the 2 or 4 o'clock buttons to adjust the hands.
    Dec 30, 2010 | Casio DW9051B-1V Wrist Watch
    I need a manual for my casio wave receptor
    For all those who lost their Casio watch manual. Follow this link, fill in the requested details and download manual. http://world.casio.com/wat/download/en/manual/
    Jan 14, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    My G-shock wavecepter is 1 hour fast. I can't seem to get it to set to the proper time. I live in Oregon on in the Pacific Time zone. My watch is set to LAX. DLS is off and when I tried it on it jump to 2...
    This url (below) has a REAL manual for your watch, not the worthless one that comes with the unit.
    You can type in your 4 digit module number and get a great document that tells you how to operate your unit and some of how it works. (Adobe Acrobat - PDF file)
    The solution involves holding down the adjust button until the time zone starts flashing, adjusting with the right 2 buttons and pushing the mode button to get to other options. You then finish by pushing the adjust button again.
    Hope that helps. :-)
    Dec 05, 2008 | Casio G-Shock GW500A-1V Wrist Watch
    TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
    ANALOG TIME
    Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
    Oct 27, 2008 | Timex Watches
    Setting time on casio illuminator watch
    Here is how you do it:
    Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
    Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
    From Day and Date window it would mean pushing button "C" six times to get to that mode.
    Once in "Hand Setting Mode"
    Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
    Press "A" to exit mode.
    Press "C" to return to timekeeping mode.
    Dec 03, 2007 | Casio G-Shock GW300CA-1V Wrist Watch
    Watches Logo
    459 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
