Question about GE GSS25LSMBS Side by Side Refrigerator
Trying to find out what the two temperature controls are supposed to be set on i have a ge side by side
  • GE Master
  • 2,005 Answers
Freezer: zero degrees refrigerator: 32 degrees; adjust from there.
Posted on Jul 17, 2010
Testimonial: "very good i appreciate the info"
How do I set water temperature for the rinse cycle?
I suppose you have looked at the owners manual, on the page below, it seems to indicate knob B. but it is unclear
GTWN4250DWS GE 3 9 DOE cu ft stainless steel capacity washer GE Appliances
Dec 24, 2014 | GE GTWN4250DWS 3.9 cu. ft. capacity top...
I have a GE Profile Side by Side Model PSS26PSS2C that will only cool to 44 degrees. Any recommedations as to a solution?
If the freezer temperature is okay, you might want to check the damper control. The airflow from the freezer might be blocked. Now, if the freezer temp is not where it's supposed to be (0F-10F degrees), then you need to check the cold control or there may be an issue with the defrost system.
http://www.appliancepartspros.com/
Feb 09, 2011 | GE Refrigerators
I have a GE side by side refrigurator model Gss201epc ww serial Tf220054 and am having a problem with stuff freezing in the crisper, I do not see any type of adjustment any ideas here? Thanks
initially, set the refrigerator compartment control at 5 and the freezer control at 5 and allow 12 hours for the temperature to stabilize.
Several adjustments may be required. Adjust the controls one increment at a time, and allow 12 hours after each adjustment for the refrigerator to reach the temperature you set.
Adjustable Humidity Crispers and Snack Pan (on some models)
HIGH LOW
HIGH LOW
Normal
Coldest
Slide the control all the way to the High setting to provide high humidity recommended for most vegetables.
Convertible Meat Pan (on some models)
The convertible meat pan has its own cold air duct to allow a stream of cold air from the freezer compartment to flow around the pan.
The variable temperature control regulates the air flow from the freezer compartment.
Slide the control all the way to the Low setting to provide lower humidity levels recommended for most fruits.
Dec 20, 2010 | GE GSS20IEP Side by Side Refrigerator
GE GSS25QSTSS Side-By-Side temperature controls isn't working
I bought a GE profile Side by Side refrigerator PSS26NGPBB for $1,800. The temperature settings won't hold. We were gone for the day, came home and found our food all thawed in freezer. Inside temp both sides is now 70 degrees. Whats wrong???
Sep 17, 2010 | GE GSS25QSTSS Stainless Steel
The refrrigerator and freezer not holding tempreture it started with the freezer - how can i fix - i have defrosted the freezer and removed all food?
hi there,
have you check the temperature?
The temperature controls are preset in the factory at 37°F for the refrigerator compartment and 0°F for the freezer compartment. Allow 24 hours for the temperature to stabilize to the preset recommended
settings.
The temperature controls can display both the SET temperature
as well as the actual temperature in the refrigerator and freezer.
The actual temperature may vary slightly from the SET temperature based on usage and operating environment.
Setting either or both controls to OFF stops cooling in both the freezer and refrigerator compartments, but does not shut off electrical power to the refrigerator.
Jun 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25LGMFWW side by side. Freezer will run till iced up then defrost everything in the freezer compartment. Why is it doing this?
hi, have you try adjusting the temperature:
To change the temperature, press and release the
WARMER or COLDER pad. The SET light will come
on and the display will show the set temperature.
To change the temperature, tap either the
WARMER or COLDER pad until the desired
temperature is displayed. The
freezer temperatures can be adjusted between
–6°F and +6°F.
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Temperature reverts back to old number which is 33 and is too cold for vegetables. How can I set it to 37 degrees
set the controls to off. then , unplug the unit from the wall for 15 minutes. this will allow the control processor to completely reset itself . after fifteen minutes, plug it in and reset your desired temperatures on your controller. if this does not work, I would suggest you consult the manufacturer or your owner's manual for more information on programming the temperature controller.
Mar 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25LSMBS Side by Side Refrigerator Logo
847 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
