Question about Sharp AF-M1909Y Air Conditioner
The unit was working fine, suddenly, compressor stopped. If I let it cool down, it works again, but not for long. My gut feeling is, it's dirty someone or, could be too much pressure in the lines. How do I bleed it off if too much pressure?
  • 674 Answers
Do not bleed it off. Check the air filter and make sure it is clean. Then check the coils and make sure they are clean. You can buy some coil cleaner that doesn't have to be rinsed if the evaporator coil is dirty. A dirty coil or clogged filter will make the compressor head pressure rise. If this doesn't help let me know. Also make sure that the fan that cools the condenser is running.
Posted on Jul 17, 2010
Ok so I have a ge cafe. I recently replaced the motherboard as my controls were all messed up and it was not cooling. Afterwards it worked fine except that there was a howling noise inside of the unit. A...
Correct, condenser coils remove heat from the freezer compartment, thusly they will be hot. Sounds like the compressor is failing and that is probably giving off a squealing sound and stops running until it stops. Then your compressor will overheat and stop running until the thermal protector cools down and allows it to run again. Try replacing the compressor cooling fan.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 15, 2017 | GE Refrigerators
Frigidaire model number FRS6R5EMB8 Not cooling
Feel the top of the compressor and tell me what you feel
Oct 09, 2015 | Frigidaire Refrigerators
Split AC whole unit turnig off at each compressor start up!
Dirty coil wash outside unit with water and change indoor unit filter
Jun 08, 2017 | Heating & Cooling
It is a Bryant Legacy AC unit. Model #123RNA060-B. It has been running fine, now it has suddenly shut down. The interior fan is working, but the fan at the compressor shuts down. It will work fine for...
I had a unit do the same thing to me, everytime I would leave, it would stop working again. I had a bad fan motor that would spin fine and work for a little while, but would shut down. It was the motor windings that would overheat and shut off, as soon as they cooled, it would start back up. One way to check is to feel the top of the unit where the base of the fan mounts and see how hot it is, best to check while it's not working how it should, but try not to run it very long or you could damage the compressor. Hope this helps!
Jun 27, 2011 | Bryant Heating & Cooling
Hi. I recently installed 1.5 T, 3 * Split AC, LG. Whole day the AC works fine and no problem in cooling too. But once in 2 day outdoor unit start making thudding noise continously and does not stop for 4...
Hello
Sounds like the compressor is shuting down on high heat.There could be a couple reasons for this.
1 Check that proper voltage is being supplied to compressor.
2 Freon level may be low.This would be a service call.
3 Bad or intermitent connection at thermostat.
4 Main contacts to compressor sticking,usually burnt or pitted.
Apr 08, 2011 | LG Heating & Cooling
The freezer/refrigerator stopped working. All the ice was melting in the freezer. I cleaned up all the water. It sounds like it is humming and cooling; but it doesn't feel very cool in the fridge, meat...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 14, 2010 | Refrigerators
Goodman heat pump stopped cooling
yes, but I would try a "hard-start" kit before replacing the compressor itself
Jul 10, 2010 | Goodman CPLE24-1 Air Conditioner
Unit starts, it cools fine, but all of a sudden it stops I used to click on the interrupter, but it doesn't work anymore I take the power off for 15 min, connect again, it works 2 minutes and then stops.
Low freon will usually cause a freeze up, your sounds like an overheat shut off, compressors get hot, but if the get too hot there is usually a safety shut off... also, if the compressor is wearing out you can install a hard start cap inline with the compressor to bang it into operation. It would make an unusual humming sound if your compressor is not turning... capacitors are inherently dangerous when charged, so you may need someone to install it for you. The caps are not expensive.
Feb 27, 2010 | GE AGW18DH Electronic Room Air Conditioner
Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Jul 31, 2008 | Kenmore 75101 Wall/Window Air Conditioner
Sharp AF-M1909Y Air Conditioner Logo
57 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
