Question about Refrigerators
Hi my maytag refrigerator (model: msd264rheb) is pouring out water with what looks like black chunks of gunk and flakes. I would like to know how to either clean the tube the water flows thru or replace it. Any guidance is appreciated thanks.
HVACRH20
  • 237 Answers
SOURCE: Water Tube w/ Algae
Depending on how far up the growth is, a Q-tip or old fashioned pipe cleaner will do. Typically this is due to the water having the chlorine removed by the filter. I recommend that you remove your filter and install the bypass plug (if needed) and run a few gallons of unfiltered water through the system then let it sit overnight. The chlorine will kill any growth, then you can put the filter back in for filtered water. Usually doing this every few months will keep the "green" out.
Posted on Dec 11, 2006
  • 172 Answers
SOURCE: kenmore coldspot - How do you remove the ice maker box to clean
Hi Cincygrl,
Well lets see, I believe you have a whirlpool made kenmore, Your model numer should start with 106.
The problem you are having is from our drain. When you freezer defrosts the water should drain down a tube and under the refrigerator into a pan. If the tube gets clogged it will leak water into the freshfood section. To clear the drain you will need to remove everything from the freezer and remove the inside back panel in the freezer. in the center bottom under the coils and the heater you will see a tiny hole. That is your drain. If it is frozen over you will need to defrost the ice or you may need to run a smaller tube into it to clear it of an obstruction. I use a small rubber hose and I just insert it into the hole and blow on the other end. If you have something in it, it should blow out. If it does not then it may have ice in it and you can pour hot water into the drain and defrost it. Once clear you should not have any further problems. But they do make a drain heater probe to keep ice from forming inside the drain. You can get one for about $6.00. Good luck and I hope this helped you. mca0824@aol.com
Posted on Apr 30, 2008
22yooper
  • 828 Answers
SOURCE: Maytag refrigerator Model MZ02766GEW does not dispense water
In the water supply line to the refrigerator is normally a saddle type valve where the water supply is connected to your house water line. Trace it back and shut the valve off fully then turn it back on. When some work is done to any part of your household water system sediment may have lodged in the saddle valve causing a restriction. Closing the saddle valve and reopening it may dislodge the restriction.
Posted on Dec 02, 2008
peyton32034
  • 410 Answers
SOURCE: Water spout replacement
this is a surprisingly easy repair that you can do in about 30 minutes.
  • first remove dispenser cover: there are 2 slots on the very bottom of the cover insert flat tip screwdriver and carefully pry it off. then you should be able to disconnect a wiring harness and lay the cover to the side.
  • next move switch console out of your way: you will either have 2 screws or 2 thumb latches on either side. you may need someone to hold this out of your way for the following steps.
  • we need to disconnect the incoming water line down at the bottom hinge: remove kickplate and find the water line you should find a connector. while pushing the tube into the connect push down on the collar then pull the tube out of the connector.( you will most likely get a little bit of water when the tube pulls loose.
  • back at the dispenser: find where the tube comes out and remove any retaining screws, then gently pull the entire tube up and out of the door.
  • now do everything in reverse to finish up: the tube will push abck thru. when you get back to the hinge the tube may hange up I use a very small screw driver to line the tube up to come back thru the hinge.
  • whne you reconnect the tube at the grille make sure that the tubing seats all the way to prevent any leakage
Be surre and be safe by unpluggin the unit before you perf any type of repair water and electricity dont mix. good luck Peyton
Posted on Jan 31, 2009
SOURCE: Whirlpool Side-by-Side Refrigerator No Water to Icemaker or Door
If you don't get water at the valve and it has power it is likely clogged. Take it apart and find most likely a part where the rubber has softened and clogged a hole that is supposed to open up when the valve is triggered. On mine it was at the bottom of a little metal pole that the rubber was bad. Clear the clogged hole and replace the bad seal and you should now have water.
Posted on Mar 09, 2009
Maytag side by side msd264rheb freezer works frig isn't cold. We found ice on bottom freezer side and did melt it with a hair dryer. Frig vent is letting in, now a little cool air, but not a lot.
If you found ice in the freezer then there is usually a lot more behind the back plate. If you let it defrost completely it should work good for a couple days until the ice builds up again. you more than likely have a deefrost issue. There are usually nthree components in a typical defrost circiut. The heater, defrost thermostat and a defrost timer or control. one or those is bad.
Jul 28, 2014 | Maytag Refrigerators
This morning i awoke to the side by side maytag refrig.. and water was all over the kitchen coming from the fridge.. pulled the unit out and the compressor seems to be out.. i think.. the fan is just...
Hello
Black flakes? Could be the start capicitor on the compressor has blown.If this is the case the compressor is probably damaged as well.
On the compressor is a black cylinder with 2 wires going to it,this may be under a plastic cover.
Unplug refige and look to see if this black cyl is blown apart.This is the start capacitor which starts the compressor.
You can try to replace it yourself,but it sounds as if your going to need a service person to come out.
Sep 23, 2011 | Maytag Refrigerators
My lg Washing Machine WF-T853A is putting black rubbery chunks and flakes through every wash.. This has been happening for about 12 mths and is getting worse to the point where half the lint bags are full...
sorry to ask you this but are you sure the flakes are rubber? usually the black flakes are lint from the clothes. to help combat this problem try this.1- buy 2 pkts of bicarb of soda or baking soda, 2- select high water fill. 3- select hot water fill.4- pour soda into an empty machine. 5- shut the lid and push the start button. 6- let it fill and wash, let it wash for about 5 to 10 min"s , do not let the water drain.7- turn machine off after letting it wash for 5 to 10 min"s , and leave the water sit in the bowl overnight . 8- in the morning start cycle again and let it go thru complete cycle. this should get rid of most of the lint. you might have to do this twice depending on how dirty the plastic tank is. please reply 4 more help and good luck.
May 12, 2010 | Washing Machines
Sometimes there are black particles (looks like black flakes) in the ice from my icemaker. Do you know what is the likely cause for this? Thanks
put a filter in the water supply line going to your ice maker more than likely it is rust from the inside of the water lines
Apr 22, 2009 | Refrigerators
"Check Filter" light is on
Take out the filter and pour water on the oposite side that is the dirt,if the water is not enough use degreaser and also clean thefront cover where the filter goes.
Apr 04, 2009 | Maytag M6Q10F2A Air Conditioner
Water collecting in bottom of freezer coming from back grill.
To poshodian: There are a few more posts about this problem. Of course, in order to fix it, you have to remove the panel hiding the condenser coils behind the grill and showing the drain hole.
This is what I just posted on one of them:
I’ve had my Maytag 2454 fridge for 8 years. But only this week did the same problem show up as cathy824 and lew223. When I poked a drink stirrer into the top of the drain hole, it was hard as a rock. Not knowing why condensate from the coils was not draining into the hole and tubing that would empty the water into the pan evaporator on the bottom of the fridge, I took everything apart in the back and messed around with the black rubber elbow at the other end of the drain plug. I shouldn’t have bothered, because what I finally did was to pour boiling, boiling hot water over the drain hole to melt the ice and gunk that was frozen solid in the drain tubing. While I was doing that, I poked the stirrer into the hole, washing the gunk down the drain and into the very dry evaporator pan. Keep pouring hot water into the drain hole until you’re satisfied that water can flow freely into the pan.
That solved the problem of condensate water freezing on the bottom of the freezer and running onto the kitchen floor. Thanks to lew223 for the fix! The fridge should be good for another 8 years now.
Jan 13, 2009 | Maytag MSD2454G Side by Side Refrigerator
Diswasher doesnt clean and leaves "gunk" on top shelf items
The rinse agent is a separate product. I use CascadeCrystal Clear in a 16 ounce bottle. In your machine (if it's anything like mine) there should be what looks like a screw cap next to the soap dispenser. Unscrew that and pour in the product.I was told by the appliance store where I bought my machine that you have to use this in stainless steel washers. Also I would try a liquid type soap. I use Cascade with shine shield. I think from past experience that the pellets aren't very good especially if you have hard water.
Dec 16, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Ice Maker has some black stuff in water
check the ice-maker itself, it has a teflon coating (like a frying pan) that sometimes flakes off leaving little black flakes in the ice. if this is the case you have to change the ice-maker.
Jun 28, 2008 | Nor-Lake Norlake Refrigeration 4' x 6'...
Black flakes, like mold in water dispenser
check your water reservoir lower part of refrig. section ( take out crispers)
Dec 14, 2007 | Frigidaire FRS23R4A Side by Side...
Plastic Chunks????
There's a good chance that what you're seeing is a combination of limescale and residue from all the coffee that's been through the machine. Running the machine through with a proprietary descaler might well make a difference. A.
Apr 04, 2007 | Black & Decker SmartBrew DCM500 Coffee...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
