Question about GE GSH25JFR Side by Side Refrigerator
Wont make any ice. But the ice maker makes a little constant noise, even when it off
  • 1,906 Answers
The icemaker plastic gears have stripped
Posted on Jul 17, 2010
Ice maker won't stop filling. Makes a little ice, but water is almost constant into the maker
The water control valve is shot. It's not making ice because there is a constant flow of water into the ice tray. Shut the water off at the feed point for the fridge for now. If the drain gets plugged you're going to have a small catastrophe on your hands.
Here's a procedure to test it to be sure:
How to Test Fridge Icemaker Water Inlet Valve Refrigerator Repair
Mar 20, 2016 | Kitchen Appliances - Others
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
The ice maker is still working but has constant noise.
Thanks for your post, friend!
I see that you are experiencing some challenges with your Frigidaire refrigerator making a constant noise. Typically, you can have noises coming from your icemaker and they would be a normal operating sound. If it is a snap or click it could be the water valve calling for water. Additionally, the icemaker dropping ice into the bin can provide a loud noise as well. If you have your manual it lists normal operating noises. If you feel the noise is not normal I would recommend reaching out to a professional for proper diagnosis and repair. I hope this is helpful. -Matt
Sep 24, 2014 | Frigidaire Refrigerators
I get a loud grinding noise from my ice maker. What can make that noise?
Thank you for your information you provided, could the noise be described as a clicking or ticking noise? The reason I ask is I have heard for this to be a motor driven harvest and the heating within the ice maker is not engaging to release the ice, so the unit continues to push the ice out causing the gear to jump a tooth. If this is the case the only fix is replacing the ice maker to fix the issue. Other possible cause of grinding is the water in not entering the ice maker (hollow ice cubes) so the water is accumulating around the fan motor and freezing up. As the fan turns on the grinding is the fan motor cutting away at the ice. Gain access to the fan motor and check for ice around the fan, if its there remove that ice. The cause is that the water is not getting into the ice maker and causing this issue. Good Luck, I hope this helps.
Aug 30, 2014 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
What causes ice maker to make constant clicking noise. This happens in the on and off positions.
The constant clicking noise is probably the neoprene gears within the timer motor itself. Well, sometimes there is a brass 'drive' gear that meshes with a neoprene gear which then in turn operates the mechanical components of the ice maker.
Aug 10, 2014 | Frigidaire Refrigerators
Ge profile artica constantly knocking
Broken internal motor mounts in compresser.
Jun 03, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker not making ice. motor is making noise,
Hi, Reach in and see if you can feel ant ice laying on top of the ice maker fingers that might be jamming the ice maker. The motor making a noise is why I suggest this. If you can remove the ice maker and look, it would be better. Another option is to pop the ice maker head cover off and see if the drive wheel is trying to turn or maybe even broke.
Please let me know what you find so I can assist you further.
Vic
Jul 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
GE GSH25JFR Side by Side Refrigerator Logo
79 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
