Question about Maytag Neptune MDE5500AY Electric Dryer
Trying to replace a 3prong plug with a 4prong plug
  • 760 Answers
Ok, so you currently have a three prong cord on your dryer? Your house has a 4 prong receptacle? Ok so now you've purchased a 4 prong dryer pigtail? Be sure cord is unplugged. Remove cover of junction in back of dryer. You will see three terminals. They should be labeled something like L1,L2,N . ON one terminal you well see a small ground strip This is currently connecting the neutral terminal to ground. On the new cord connect the outside two conductors to L1 +L2 connect the white conductor to the N terminal. Connect the green (ground) conductor to the frame where the copper bonding was. This seperates the neutral conductor from the equipement grounding conductor.
Posted on Jul 17, 2010
How to change from 3prong to 4prong on model FLSE60RGSI
I Am going to replace the control board to discart the possibility that I might have a brand new defective board on my hands
Feb 20, 2014 | Frigidaire FEX831CS Top Load Stacked...
Can i use a 3prong plug on my Samsung Dryer
YES IF YOU HAD A 4 PRONG IT WAS FOR AN EXTRA GROUND TO YOUR FRAME .MAKE SURE ITS A REGULAR DRYER PLUG WITH AN L SHAPED GROUND
Dec 04, 2013 | Samsung DV218AEW Electric Dryer
Compressed wiring
Pretty sure it can only go in one way.
Nov 13, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Converting a 3prong to 4 prong electric outlet, need order of colored wires
call an electrician before you kill yourself or burn down the house
Feb 20, 2018 | Kenmore Elite HE4 Electric Dryer
Can I go from a 3prong outlet to a 4-prong outlet? If so, how can I wire it. Thanks
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Jan 27, 2011 | Amana Dryers
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
I need to change the dyer cord from a 4prong cord to a 3prong cord. Is it possible? It is model number M90825760.
If you have a digital camera, you could take a picture of the plug (several different angles) and your outlet then go to one of the large chain hardware stores, camera in hand, and ask for an adaptor between the dryer's plug and your outlet. It may not be necessary to rewire the dryer at all. If they don't have one, keep reading.
The change probably is possible since dryers generally use a 2-phase connection at the most but I wouldn't recommend that you DIY. You are dealing with a line voltage whcih could be 220 and a circuit capable of supply fairly high (20) amperage.
This combination could make toast out of you if improperly wired. Any competent electrician can determine how to do the conversion with a few measurements.
There is an exception; some mfr.s have pasted a large label either inside or out on the larger panel that contains the electrical diagram of the machine.
With some care, most laymen could determine how to make the change.
Mar 03, 2009 | Kenmore 62622 Electric Dryer
I HEAR A CLICKING NOISE WHILE TRYING TO START MY EXPLORER, THEN N
Go under the hood and you will see a box it is not a big box it is a small one, Open it up and you will see some plugs,, There is a 3prong plug that is in there that needs to be taken out and replaced and it will solve the problem.
Nikki2913
Nov 29, 2008 | 1996 Ford Explorer
Maytag Neptune MDE5500AY Electric Dryer Logo
122 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
