Question about Ruud UBHC Air Conditioner
It runs without cutting off... only cooling at a small percentage compared to the past, and condensation seems to be leaking into my basement
  • 456 Answers
1st glance would tell me it might need freon. However you stated you had condensation leaking into the basement. Check to see if the insulated line in the basement is iced over. If it is iced over, the next thing to check is the air filter, then the blower motor.
Posted on Jul 17, 2010
Air conditioner fan wont start
change run capacirotor of outdoor fan motor.
Jan 07, 2014 | LG LSC121PMA Split System Air Conditioner
Tip
How to raise the value of a home with a basement by a good percentage
If you are trying to sell a house with a basement and want to include rooms in the basement in the advertising their must be a way to exit the house from the basement. for a few thousand dollars now you can add the rooms and raise the value significantly. Egressed windows are windows in a basement large enough to qualify as an exit. You will have to call a concrete cutting contractor and have him cut out the window size. then install the window. now instead of your add saying a 2 bedroom, 2 bathroom house with a basement. You can say a 2 leve, 4 bedroom, 2 bathroom house!
on Mar 19, 2011 | Tools & Hardware - Others
Our central AC has severe leaking ( condensation)...what to do ?
Every airconditioner will create condensation that needs to drain. Your condensation is not going where it is supposed to, probably because the drain is plugged. Find the cooling coils (they might be in the basement, but are probably in the attic) they will be right next to the fan. There will be a pan or tray under the coils and there will be some kind of small diameter pipe or hose that should go to a sewer inlet, or might possibly go outside. You might possibly have a small collecting tank with a pump that will be operated by a float switch. Lots of possiblities, but it is likely going to be obvious once you find the drain hose.
Good luck.
Jun 06, 2012 | Heating & Cooling
A very old, extremely heavy dehumidifier sat in my mother's basement for decades. I decided to dispose of it, but I was unaware of the freon inside it. In order to extricate the dehumidifier I had no...
Yep the ref is all gone, The EPA says that the oil is hazardous, actually its just mineral oil the at one time had ref. R-22 in with it.
Jul 03, 2011 | Dehumidifiers
My dehumidifier runs but no water will collect in the bucket. I ahve tried increasing the percentage. My basement is plenty damp!! Model504EL
Mine had the same problem: ran, sounded great, no water. Feel the coils. Mine never cooled down - stayed at room temp. No refridgerant left in the coils. It's a gas and can leak out. Expensive to recharge. Get a new one.
Jun 19, 2011 | Goldstar DH504EL Dehumidifier
My Maytag mfi2568aes refrigerator w/french doors is not cooling. It appears to have working fans; however all of the food in the freezer is defrosting, and the refrigerator compartment is warming. There...
If the compressor is running then you either have a leak or the compressor failed internally..my guess would be that you developed a freon leak....
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 23, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Water leaking from freezer
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
This will prevent water from comming out the freezer door and leaking onto your floor and running down your copper pipe to the basement.
May 12, 2009 | Hotpoint HSS25GFP Side by Side...
Our water line has a pin hole leak.
sure just get a plastic 1-4th in coupling to couple the two parts together and and cut out the section with the pinhole (Use plastic the brass ones do not work well on plastic)
Mar 25, 2009 | Electrolux Refrigerators
Rudd heatpump doesn't cool
Hi, Is the condenser fan running? If not, Check the circuit breaker inside the house and the quick disconnect at the condensing unit. Making sure the power is off, check for any bugs in the contactor. If it is running, check to see if there are any resets on a high pressure switch or control board in the condenser. Check the compressor capacitors and see if they are leaking oil or swelled up. are there any burned wires? Is the compressor hot? If the fan is running and the compressor is not hot it is probably off on Low Pressure and needs charged by a licensed Air Cond Tech. Hope I have helped. Let me know. kstfas
Sep 24, 2007 | Ruud Matching Split Air Conditioner
Ruud UBHC Air Conditioner Logo
97 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
