Question about Sony QUALIA 005 46 in. LCD Television
Color just recently the color on my 2 yr old qualia 005 is terrible. No matter how i adjust it does not come in sharp. It seems like the color blue is entirely missing. everything is greenish or reddish. what is the best way to get help just checking the color, other than that TV seems to be in fine working order.
    Novelist:
  • 135 Answers
If you're using component video cables, check them at the jacks of the TV and video device on the other end of the cables. With component video cables try swapping two of the cables on both ends to see if you can get the color to change, if it does the problem is the cable. If the color doesn't change either the output of the source video device is bad or the TV is bad. Try a DVD player to see if the problem is your original video device. If the colors are good with the test DVD player, your original device is at fault.
Posted on Nov 11, 2008
Web pages are always very slow, no matter how I clean up internet options.
1. First of all back up the Data that you require on either DVD's or Thunb Drives / External drives.
2. Do a clean format, for that you would need the OS CD and make sure that yr Optical drive is working.
3. Steps to do OSRI (Operating System Re-Install) are different from OS to OS.
4. Let me know if you need more help.
Regards,
Nadeem
Dec 23, 2012 | E-Machines eMachines Desktop PC
How much will it cost for a screen on a lcd sony KDL46w4100
I just read in wired that the most expensive component in a laptop is the lcd screen.
my tv screen looks okay.. thin vertical color lines. are you sure you screen is broken?
Ron
Nov 30, 2008 | Sony QUALIA 005 46 in. LCD Television
Qualia 005 compatibility with Blue Ray, AND where can I find a stand and a wall mount?
I may be sticking my neck out on this one, but I don't believe there is a way to improve the input resolution. If I'm right, the issue is not related to a firmware upgrade but the hardware design of the board and IC's on them. I have the same issue with a Toshiba 1920 x 1080 resolution TV.
The best you can do is to set the blu-ray to output at 720P which is actually higher resolution than 1080i. Here's why. 1080i is actually two fields of 540 resolution interlaced or put another way one 540 image overlaying a second 540 to make one complete video frame.
Still you make the call as to which one looks best to you
Apr 11, 2008 | Sony QUALIA 005 46 in. LCD Television
47 inch sony lcd bravia hdmi hd ready tv
coverage card. sony has had that issue for a bit. take it in. it will get wores
Apr 08, 2008 | Sony QUALIA 005 46 in. LCD Television
Kv-36hs20
Have you tried disabling SVM (scan velocity modulation)? Often touted as a "feature" of TVs, it's a way of artificially making a picture appear sharp. Totally unnecessary. When SVM (sometimes called VM) is on, it can lead to some color bleeding around edges.
Mar 24, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Sony Qualia and Sony XBR 4 TV
wow. mostly all new set from the last few years have a dual tuners
NTSC and ATSC and that would depend if or which set will get the better signal. Also remember that off air is analog and the sets are now design for digital.
Feb 09, 2008 | Sony QUALIA 005 46 in. LCD Television
Sony Qualia 46" TV Model # KDX 46Q005
This would mean that your signal is being lost. Instead of snow like from a analog signal you get digital breakup when you get low reception. You need to reposition your antenna or get a better one with a little more power. Nothing wrong with your tv though just not strong enough signal.
Thanks
Josh
Feb 08, 2008 | Sony QUALIA 005 46 in. LCD Television
HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Dec 27, 2007 | Sony QUALIA 005 46 in. LCD Television
Blue Convergence just went out?
High Voltage Capacitor? Leave the set unplugged for 1/2 hour most components will selfdischarge, as for your problem, being a Magnavox, you have one of two problems, the convergence I suspect is what is blown out, this unit probably uses STK392-110 Ic's, I would suggest replacing with STK394-160e chips as they are probably shorted, some of the big resistors (1 or 2) may be opened up also, usually they change color. The only other thing that would cause usually a yellow color in the corners is the CRT Fluid, it changes from clear to Orange in color and clamps off the blue color from the fringes, I suspect the chips need replacement, dont forget to put some heatsink dope behind them, they are usually on the left in the front of the set (from the back) Big long heatsink that is fairly tall (probably the biggest heatsink in the set.) Good luck, and the repair usually runs around $350.
Jul 13, 2007 | Philips Magnavox 51MP392H Rear Projection...
Sony QUALIA 005 46 in. LCD Television Logo
91 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
