Question about Video Game Consoles & Games
My Wii remote is only partially working. It seems I've lost the arrow that I need in order to point to the screen. I've tried changing batteries and re-syncronizing it with the console but still no arrow. I can scroll left or right reset go to home and everything else but the arrow.
  • lordnex Aug 22, 2010
    i have this exact same problem. It was working fine a few days ago and now the wiimotes are not giving me the ability to point at things. I can use the + and - keys to scroll the screens, home to open that menu and shut down with the wiimote, i just can't point! I did plug in the original controller and it popped up and worked for a little bit but then died.. i don't get it. i've searched and googled but can't find any answers but I know this is not a unique problem.
maxicube
  • 51 Answers
SOURCE: Wii remote - upside down???
this is a solution that fixes it.
while the remote is upside down whack it several tims 4-7
and then reset the controller.
hope this helps,
Maxicube
Posted on Feb 10, 2008
SOURCE: Wii Remote Control Stopped Working
This happened to my son. I did some reading and found out you have to resynchronize the remote. This is from the manual
1) Press the Power button on the Wii console to turn it on.
2)Remove th battery cover on the back of the remote and press the SYNC. button inside the cover. The Player LEDs will blink.
3)Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment
4)When the Player LED blinking stops,connection is complete. The LED that is illuminated indicates the player number.
This procedure must be followed for each additional Wii remote added to your system.
This worked for me, hope it helps you.
Posted on Oct 03, 2008
john_n4
  • 73 Answers
SOURCE: wii remotes lost connection with console
You need to open the small compartment on the front (located between reset and eject) were your can insert a sd card. Above the slot will be a red button labled sync. Press(maybee hold) the button and press the 1 and 2 buttons on the remote. This should get your remote working with your wii.
----John
Posted on Nov 26, 2008
saif123
  • 104 Answers
SOURCE: second wii console gets err 51030 while first is internet fine
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqwtr-76
Posted on Jul 22, 2009
lucy222
  • 111 Answers
SOURCE: When Wii is turned on, the cursor does now show up
aqrtyctr-45
Posted on Jul 23, 2009
Wii remote will not point and select a program. Remote has been synchronized, seems to be working properly, Board is working and the programs come up on the screen but will not point or let me select a...
Hi. Try to borrow a friend's wiimote that will help you to figure out if it is a sensor bar problem, if it is not a problem with the sensor bar, then it can be the wii software try resetting the console or updating it.
Aug 30, 2011 | Nintendo Wii Fit for Wii
I have tried programming my wii remote but it won't work. I pressed both the sync buttons, but all it does is flash on all 4 dots and then quits. I've changed the batteries in both remotes, as...
Here's what to do. I've had this happen many times.
1. Open up the SD Card compartment on the Wii.
2. Open up the battery cover on the remotes.
3. Press the red Sync button on the Wii, and then on one of the remotes.
4. Repeat for whatever remotes need synced.
This will make every remote act like the P1 remote. For temporary syncing, just go into the Home Menu and click Wii Remote Settings. Click on another option(it'll say to press 1 and 2) and follow the instructions.
Jul 19, 2011 | Nintendo Wii Remote Controller
My wii console will not allow my remotes to work i cant get pass the 1st screen i,ve tried three different remotes please help
what you need to do is replace batteries in a controller and if it still doesn't work then you need to sync the controller to the wii.
Jul 07, 2011 | Nintendo Wii Console
Just changed the batteries in the remotes.and getting no signal when pointing at the screen to play games
sir think your remote is not working properly... you better try to reset your remote for your nintendo wii console... this is how you can reset your remote...
  1. How to Reset Your Wii Remote
    • 1 First you will need to check a few things, just to make sure what the actual problem is.
      *Check to see that all cords are properly plugged in.
      *Make sure the sensor bar is properly center above or below your tv set.
      *Make sure that nothing is blocking the signal to the sensor bar.
      *Make sure that the batteries in the remote are in good working order.
      *Make sure that there are no wireless devices close by that might be interfering with the signal.
    • 2 If after all this the remote is still not working then it probably needs to be re-synced.
    • 3 Turn off and unplug your wii console for a few minutes.
    • 4 *Turn the power back on and when you see the the safety screen open the small flap on the front of the wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
      * Then remove the battery cover from the wii remote, inside you will see another red button.
      * Press and release the red button, the blue lights on the remote will start blinking.
      * Quickly press and release the red sync button on the wii console.
      * The remote will stop blinking and it should now be synced.
or visit the links below
Read more: How to Reset Your Wii Remote ' eHow.com http://www.ehow.com/how_4527749_reset-wii-remote.html#ixzz1OyHyruvP
if you think this help you please rate me by that it will help me to... thank you in advance...
Jun 11, 2011 | Nintendo Wii Console
Have new 55ux600u toshiba. Hooked up a one year old wii and get no color
The 55ux600u toshiba hdtv has a setting that needs to be changed with the wii in order to get color.
1. Click 'Menu' on the TV remote 2. Arrow over to 'Preferences' 3. Arrow down to 'AV Connection' 4. Click 'OK' 5. Arrow down to 'AV Input' 6. Change setting from 'ColorStream HD' to 'Video' by clicking the right arrow. 7. Hit the'Exit' button on the TV remote.
This will give you color for your Wii. You will have to change this setting back in order to view DVDs in color. :-)
Jan 01, 2011 | Video Game Consoles & Games
Sensor bar inactivity on the wii videogame system
First you Should test with another sensor bar...try to take it from a friend to test it in your system...could be cracked wires from the sensor bar....try to test the wires with a multimeter and resolder the wires from the cable...or you can take your sensor bar and test it in another wii...you need to known if its really bad ,or if there is something wrong with your wii system...
Sep 09, 2009 | Nintendo Mini Wireless Sensor Bar for Wii
Wii remotes want to point at a wall light
well if u keep them on the charger for to long u need to get new ones cuz it will shorten the batteries on and on so buy new ones k!
Mar 25, 2009 | Nintendo Wii Remote Controller
Wii remote working but no arrow
Try moving closer to the TV. Where the remote is pointing only works within a certain distance so try moving closer while waving the remote back and forth across your TV.
Aug 31, 2008 | Nintendo Wii Console
Trying to install wii
I love the way this works - if everything is plugged in properly, the remote control will be detected by the sensor and you should see an arrow on the screen that you can move by physically moving the remote. Use this to point the arrow to "English", then click "A", then move it again to "confirm" (...or is it "OK"?).
Dec 25, 2007 | Nintendo Wii Console
Video Game Consoles & Games Logo
76 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
