Question about GE WSXH208A Front Load Washer
I have a ge Adora front load washer. Fabric softner will not dispense. I just had service out here 2 weeks ago due to another problem and can not afford for them to come again.
  • 3 Answers
I'm having that same issue now. Did you get yours fixed?....if so let me know what it was, please.
tleohr1@neo.rr.com
Posted on Oct 30, 2010
The frabic softner dispensor is not releasing the softner in the washer.
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Sep 05, 2010 | GE WSXH208A Front Load Washer
My fabric softner will not dispense into the washer
Clean out dispenser it maybe clogged due to softner,rember clean dispencer and machine once a month.
Jul 05, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Fabric dispenser is clogged. How do I unclog so
The dispenser is removable easily. You can scrub down the softener dispenser and it will eventually work.
Jun 12, 2010 | GE WSXH208A Front Load Washer
My Ge Adora washer fabric softner dispenser
You have low water pressure which wont reach the dispenser drawer during rinse cycle. Clean the feed pipe in case there's dirt in the feed gauze located at the back of the machine. The mould on the rubber is dirt in the machinme. A mixture of 1 cap of bleach and 1 small tub of Swarfega mixed with water and put into the drum on an empty wash will stop it geting worse but it cant be removed.
Dec 09, 2009 | GE WSXH208A Front Load Washer
Fabric softner dispenser
Small brush and plain water. Rub, flush, repeat...
If it's clogged where you can't get a brush, pour very hot water into it. Last resort would be blowing it out with an air compressor...
May 07, 2009 | GE Profile WPRE6100G Top Load Washer
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer will not dispense fabric softner
I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
Oct 28, 2008 | Washing Machines
Fabric softener dispenser is filled with water
I had this same problem. I found a repair manual online and found out how to get into Service Test Mode. There is a test (t12) for the dispenser motor/mechanise. Running this test basically just runs water through each of the dispenser compartments (prewash, wash, bleach, fabric softner). All ran fine - no error codes. I continued to run the test on the fabric softner dispenser repeatedly and after 5-10 cycles it started draining properly. I think a tube (or valve or opening) was just clogged with the built up softner. I also put some vinegar in the compartment a time or two just to clean out any residue. Be careful with the Service Test Mode - read directions carefully - the manual warns that if you don't get out of it corretly that it can lock up you washer.
Jun 18, 2008 | GE WBVH6240F Front Load Washer
Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Jun 13, 2008 | GE WSXH208A Front Load Washer
Front Load Does not dispense fabric softner and bleach
under the bottom panel of the washer on the left hand side is a tech sheet that will tell you how to fix this
Mar 05, 2008 | Frigidaire GLTF2940ES Front Load Washer
GE WSXH208A Front Load Washer Logo
71 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
