Question about Zenith IQB55M90W 55" Rear Projection Television
My zenith inteq tv 's blue and red alignment won't line up. what can I do to solve this issue.
5 Suggested Answers
jimbo4026
  • 50 Answers
SOURCE: zenith inteq 60 in rear projection coolant leak
I would check with LG/Zenith on this, there was a update sent out to add a collection cup in case this would happen. If leaked on the board it would be to costly on repair with the board is still available.
Posted on Nov 20, 2007
  • 2920 Answers
SOURCE: Red and Blue convergence
you may need a new convergence board only a tv shop can tell you for sure
Posted on Nov 03, 2008
  • 556 Answers
SOURCE: zenith projection tv convergence proublems
YOU HAVE BAD CONVERGENCE IC'S AND POSSIBLY SOME LOW OHMAGE RESISTORS THAT FEED THE IC'S.
Posted on Sep 14, 2009
johnnydiode
  • 647 Answers
SOURCE: Need a red bulb for Zenith PVR5263RK rear projection tv
It sounds like your looking for a CRT (red) the part # is on the CRT and could be puchased through any Zenith (LG) distributer- usually around $300- $500. Google the part # when you get it and you may find a used Picture Tube (CRT)for cheaper.
Posted on Sep 22, 2009
Green line on left side of an image and a red line on right. Such as around a face. Colors just don't line up and picture is very fuzzy. Had another old rear projection and it had a way to align it. Can...
Your other model was more than likely a CRT projector where you coulod manually align the Red/Green/Blue guns. The one you have now is more than likely an LCD projector which can't be readily aligned. Sounds like the panel is failing.
Mar 13, 2011 | Zenith R57W46 57" Rear Projection...
The picture looks bent and looks 3d...my friend who sold me the tv had the same problem and she was able to fix it but she cant figure out how to do it now ... somthing about the red and blue being off...
In the tv menu settings there should be a convergence menu or alignment menu...you need to go here to re-align the red and the blue guns to display the proper picture...most projection tv's have a setup screen for aligning the colors..you want to line up the red and the blue to get as close to white as you can
Dec 21, 2010 | RCA HD52W59 HDTV Projection Television
My Zenith tv picture on the screen looks like a bowtie red green and blue are seperated on screen
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | RCA D52W23 52" HDTV CRT TV
How do you fix shadowing on a zenith inteq
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 23, 2010 | Zenith D52WLCD 52" Rear Projection...
Zenith R45W46F has sound but no picture
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 27, 2010 | Zenith R45W46 45" Rear Projection...
When i try to align the colors. red and yellow align but blue will not align
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 14, 2009 | Zenith R60V26 60" Rear Projection...
3d picture
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
This blog covers many makes and models with many issues solved, just with that one solution
Give it a try, it's free and simple :D
Hope the blog helps you.
Jean
Dec 28, 2008 | Sony KP-43HT20 43" Rear Projection...
Zenith inteq 60 in rear projection coolant leak
Nov 10, 2007 | Zenith IQB50M90W 50" Rear Projection...
Liquid gel
Thats coolant. Thats bad.
Call a Zenith service place and ask how much to replace that gun and clean up the mess.
Nov 09, 2007 | Zenith IQB50M90W 50" Rear Projection...
Zenith IQB55M90W 55" Rear Projection Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
