Question about Whirlpool GEW9250 Electric Dryer
Whirpool dryer is not working the panel is not working
  • 3 Answers
A lot of people are having this issue, including myself. My dryer is under service contract and they are refusing to fix the bad control panel because they said it is my fault because of a clogged lint vent (untrue my lint vent was just cleaned). Here are several more posts about the same issue and talk about a class action lawsuit because this is a common issue and the boards are very expensive to replace. http://www.fixya.com/support/t390430-whirlpool_duet_electric_dryer_not
Posted on Jul 20, 2010
Whirlpool dryer awd60a manual
Hi
Click the following link to download the whirpool dryer awd60a manual.
I hope this helps.
Dec 10, 2011 | Whirlpool GEW9250 Electric Dryer
F 01 error code whirlpool duet dryer. Can I replace the control panel?
Where is the thermistor on the dryer on whirpool duet or remove control panel
Feb 28, 2011 | Whirlpool Dryers
I have a used whirpool electric dryer model number Ler563EQ1, it just stopped working .There is power going into the unit ,no blown fuse,
their is a thermal fuse in the back of dryer. take panel off. its small. white. shaped like a small depository, check with ohm meter
Aug 19, 2010 | Whirlpool Dryers
CANT FIND THERMASTAT
its behind rear panel on the blower housing
Apr 14, 2010 | Whirlpool LGR8648L Gas Dryer
I have to unplug every time for an hour in order for my whirpool dryer to work. What is the problem
f you didn't unplug but only shut off for the hour would it start up ?? sound is like a overheated motor . de lint dryer this will help / if you have to unplug to correct it is the panel if digital .. mm
Dec 03, 2009 | Refrigerators
Need to get to belt on my whirpool dryer
TAKE FRONT OF DRYER OFF PLACE BELT OVER TUB @ THEN OVER THE PULLEYS MAKING A FIGURE 8 LET ME KNOW IF YOU HAVE ANY PROBLEMS
Apr 30, 2009 | Whirlpool LER4634J Electric Dryer
My Whirpool dryer model LXE 7400 WO doesn't
Unplug the dryer.
Remove the back panel.
Inspect the wires at the terminal block where the cord connects.
With a volt meter set for continuity check the thermal fuse on the heater canister(up high). No continuity , replace it.
Check the hi limit thermostat at the heater terminals, no continuity , replace it.
Check the heater terminals for continuity. If none replace the heater.
Remember to remove at least one wire from each part before testing.
Feb 22, 2009 | Whirlpool Dryers
Whirpool GGw9250Pw3 no power on Control Panel Inside light works
In my case, the problem was a dead main board. The board cost $190 and the overall repair cost $335. I will never buy another Whirlpool due to this experience.
Dec 11, 2008 | Whirlpool GGW9250PL Gas Dryer
Cleaning Whirpool Ultimate Care II
once that you have lifted the top up you can remove the two screws that are down inside the frount panel about three inches, pull out on the frount panel and swing to the side, if the lint buildup is large then check the vent to the dryer for any kink a shop vack works great for this chore
Feb 18, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
75 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
