Question about Sony KDF-E55A20 55 in. LCD Television
I am replacing the bulb on my Sony lcd tv. I am waiting for the new bulb (with housing) to arrive and decided to practice. I pulled the old bulb housing out and slid the new one in. Seemed very simple but the power light is blinking red which indicates the new buld is not installed correctly. It seems so simple that I don't understand how I could not have it in correctly. I slid it directly in and the 2 connectors on the left side seem to be aligned. I believe I have pressed it in hard enough and don't want to force it. Any suggestions?
  • Sony Master
  • 5,569 Answers
If you lost video and assumed the fluorescent tube was at fault, you may not have guessed correctly.
There is a power supply (normally called an inverter) which may be separate or combined with the main supply that produces the high voltage the back-light requires. The tubes, if bad, will have a well-defined dark area at one or both ends of the tube. If the inverter has failed, there will simply be no voltage to ignite the gaseous tube.
The effect is the same but the solution is different.
Posted on Jul 16, 2010
I am trying to replace my lamp and it won't lock in. Please help.
maybe your new housing is not fit for the projector
use the new bulb (lamp)
use your old housing ,
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Dec 20, 2014 | Sony KS 50R200A Replacement Rear...
Replced bulb starts to power then fail red light blinks thre times
You might need a new housing! Sometimes, the housing can be damaged with a new bulb and it can caused the TV to want to shut off.
Mar 15, 2013 | Sony KDF-E60A20 60 in. LCD HDTV
I it easy to cange the lamp in my e55a20 sony tv. I have one coming 2moro, and was wondering the difficulty level.
It involves removing a housing an pulling out the bulb then inserting the new bulb and replacing the cover. Sony has excellent instructions in the owners manual:
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=KDFE55A20
pg 76
Mar 02, 2011 | Sony KDF-E55A20 55 in. LCD Television
Tv nt coming on red light is on next to power light 50 inch lcd projection sony tv
hello. it sound's like you need to replace the lamp in your set. and here is how to do it the right way. rember to all ways unplug your set.. # 1 first. .Remove the outside lamp cover. The lamp cover is located on the right side of the Sony television. To remove the lamp cover, simply pull down. You will now have access to the lamp housing. # 2 Open the lamp housing door by turning the locking handle counterclockwise while pulling the door toward you # 3 Pull the lamp unit straight out of the television unit. Be sure not to touch the bulb, as it may still be hot. # 4 Slide the replacement bulb into the lamp housing. # 5 The lamp will slide securely into place.!!! "Do not" touch the new bulb as it will cause damage to the bulb and result in malfunction. # 6 Push the lamp door back into place. Turn the locking knob clockwise to secure the door in place.# 7 Slide the outside lamp housing cover back into place on the television.!!! plug your set back in to the wall & The television is now ready for use. thank you
Oct 21, 2010 | Sony KDFE50A10 50" HDTV
Is it an easy fix to replace the bulb on a Sony KDF-E50A12U HDTV LCD
yes just be careful not to pull off soddered wires close by
May 03, 2010 | Sony KDF-E50A12U 50" LCD HDTV
How do i change the bulb
In order to change the bulb you must first pull out the housing from the TV, take the screws of and take the old one out, i suggest using latex gloves to protect the glass on the front. After that just insert the new one in and push in the housing until you hear a slight click, close the door and that's it!!
I advise that you check on youtube videos in how to install the lamp if you have any other question, just type in the model and the videos should appear!! Hope i could be of assistance!! (:
Mar 16, 2010 | Sony KDF50E2010ATNS 50" HDTV-Ready LCD TV
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
How to replace lcd tv bulb
Most of those models you replaced them through the front. The lower front panel pulls off. Some models have a knob that must be loosen on the back of the set at each end. Once the front panel is taken off the Lamp door is easily accessed. The new Lamp from Sony will come with the proper Wrench to remove and reinstall lamp.
Hope this helps,
Skyassoc
Jul 03, 2009 | LG RZ-17LZ40 17 in. LCD Television
XL-2100U lamp cycles on and off
Hi
I recently had a similar problem after replacing my lamp the set would work for 22 mins then go into standby for 30 sec then come back on, then repeats, I decided to experiment with the lamp housing, I removed the new lamp, unscrewed the top of the lamp that holds the actual bulb then switched out the main housing (bottom part) with the original housing, that seemingly has corrected my problem, you may want to try if the replacement lamp did not come from Sony...good luck
Sep 10, 2008 | Sony LAMP BLOCK XL2100U Projector Lamp
Lamp failure indicator
I had the same issue when replacing my lamp for the first time. I replace just the bulb with the Phillips replacement bulb. After installing the power down issue started and it would take up to 7 attempts before the TV would stay on with a picture.
Since I never had this problem until i replaced the bulb i decided to send the new bulb back and replace it with a difference one. In my opinion replacement parts are never made to the same standard as original OEM parts. This TV is definitely very temperamental in regard to the bulbs.
When the second replacement bulb arrived I decided to not only replace the bulb I also cleaned the connector plug in the cartridge with a QTip and alcohol. I did the same for the plug receptor in the TV.
When I replaced the bulb i insured the the top of bulb lettering was facing the handle of the cartridge so when you put the cartridge back in the TV the top of the bulb would be facing you.
I also cleaned the entire inside of the TV where the cartridge is inserted including the screws.
Once I did all this the TV turned on the first time and has been working fine for three days now.
I do believe the replacement bulb position is very important as to how it heats up and determines when it needs to cool.
I hope this helps others with the same success i had because I really do not want to replace this TV and start replacing all the parts others have done with little to no success for this issue.
Jul 11, 2008 | Mitsubishi WD62527 62 in. LCD HDTV
Sony KDF-E55A20 55 in. LCD Television Logo
135 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
