Question about Dolphin Maytronics Advantage
How do you change the yellow treads on the Dolphin Diagnostic Advantage Pool Cleaner
  • 640 Answers
Below is the users manual for these pool cleaners. It will give you instructions and diagrams for changing worn parts of your cleaner.
http://www.backyardcitypools.com/images/smartpool/Dolphin-hd-Manual.pdf
Posted on Oct 11, 2010
Goes to wall and turns itself over. It is clean.
Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ...
? 3:44
www.youtube.com/watch?v=-x8hwghv8BE
Apr 4, 2012 - Uploaded by Swimming Pool Tips, Reviews & How To -MrDgvb1 Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ... Solar Breeze: The Robotic Solar-Powered Pool Cleaner Review: http://youtu.be/jzWfClbOnIc ... Pentair Kreepy Krauly Legend Review, Troubleshooting & Tips:
Aug 08, 2015 | Dolphin Maytronics Diagnostic Robot...
My Dolphin pool cleaner runs fine along the bottom of the pool but will stop and shut down when it ties to climb the side of the pool. If I move it away from the wall it will run around until it moves to...
The control board inside the motor pack is failing as the sensor for the units orientation is included on that board. The only way to fix it is a new motor pack. For additional information on repair parts or sending it in for service please contact Maytronics at www.maytronicsus.com or us thru www.arrowpools.net.
John
Jul 07, 2011 | Dolphin Maytronics Advantage
Cleaner wont reverse.will try to climbe out of pool wont reverse. this is a dolphin superkleen.
Contact Maytronics, manufacturer of the Dolphin cleaners, for troubleshooting assistance and referrals to regional service centers directly at www.maytronicsus.com or 1-888-DOLPHIN.
John
May 23, 2011 | Dolphin Maytronics Diagnostic Robot...
What materials for a plane would you need to transport a dolphin
Are you asking how best to package a Dolphin pool cleaner to be shipped via air courier?
Please comment back with some clarification as to what you are trying to do.
Dec 02, 2010 | Dolphin Maytronics Advantage
My Dolphin Diagnostic pool cleaner stopped working.
Thank you for posting your question here on Fixya.com.
For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up
If that is not enough, try our sites FAQ section on Dolphins at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jul 13, 2010 | Dolphin Maytronics Advantage
My Maytronics Dolphin pool cleaner does not entire pool
Check to make sure that your power supply is in a position that it can reach all sides of the pool. It may be as simple as repositioning your power supply to make it more effective. Also, with these automatic pool cleaners, you need to make sure that the filter is off, because it being on can affect where the cleaner is able to go. Finally, make sure the handle is locked in a diagonal position.
May 30, 2010 | Dolphin Maytronics Diagnostic Robot...
Instruction for changing yellow track on pool cleaner
You remove the side plate by pulling the six screws inside the unit to expose the track. It is a bit of a challenge getting everything to line back up because the new tracks are stiff and tight but once you stretch them a little you can put them on and get the unit back together. If you would like a quote on the part (our web store is not quite finished yet) please use the contact button on our site found at www.arrowpools.net. As a repair center we can usually beat the prices of any of the aftermarket parts centers and if you have further need of technical assistance, we provide that too.
John
Jan 13, 2010 | Dolphin Maytronics Diagnostic Robot...
My dolphin diagnostic cleaner for my below ground pool, just stopped after years. I went to turn it on yesterday and there is power to the power box as the light goes on, but the unit is not moving. I am...
If your unit has a fuse it will be on the back side of the power supply. If the light on the power supply switch is on, it will not be the fuse though.
Try turning the cleaner upside down on the deck and connect it as you otherwise would. Power it up and it should go through a self test process that takes about 40 seconds to complete. If it turns the tracks in both direction with and without the impeller turning, it is fine and will likley start working in the pool again.
If not, contact us through www.arrowpools.net and click on the FAQ and then Dolphin cleaner catagory. You can also use the Dolphin Serice button for information about sending it in for repair.
Jul 03, 2009 | Dolphin Maytronics Advantage
Circuit board inside power supply is bad. I need a replacement
You'll need a replacement board. You'll need model and serial numbers off of the cleaner itslef to help identify which power supply and therefore what PCB is needed to replace yours. Try contacting our service center at www.arrowmotor.net and click the contact button in the upper right corner.
Jun 13, 2009 | Smart Pool Inc Dolphin Diagnostic...
Dolphin Maytronics  Advantage Logo
384 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Marvin
Marvin
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
