Question about Pioneer Car Audio & Video
I need to know what the colors silver, silver black strip,green black strip, and green brown strip are on a pioneer deh-235 super tuner the third
  • Pioneer Master
  • 17,130 Answers
These are the speaker output connections, the silver goes to the positve in the right speaker and the silver black strip on thenegative of the speaker. Similarily the green brown goes to the positive of the left speaker and the green black to the negative of the speaker. I hope this helps. Good day
Posted on Jul 20, 2010
Deh 6 wire colors
normally the speaker wires have a matching coloured wire with a black strip and are distinct from power (red/yellow) , ground (brown/black), aerial (blue) , remote power etc. Not always the same but sometimes grey/grey with black stripe, green, green with black stripe.
Aug 27, 2014 | Pioneer Car Audio & Video
I have a 1990 Ford murcuery and i just got a 2010 Pioneer super tuner 3 D 2200UB but i cant seem to get any power to the DEH and i was wondersing if you could help me solve this problem?
Did you use a factory wire harness in conjunction with the after market wires included with the Pioneer? You might have a bad ground. The basics behind the factory should look like this: Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Red/Black Illumination n/a Dimmer Blue/Red Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) White/Green Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Green Left Rear (-) Pink/Blue Right Rear (+) Pink/Blue Right Rear (-) Green/Orange
The best thing to do is to use an after market harness if you didn't before. Just in case you aren't sure, the Pioneer wires are color coded to the after market wires. You wire the two harnesses together, and then plug that into the factory wires. This would help on the chance that you decided later on to sell the car, but want to keep the Pioneer until. I hope this helps, and let me know what you come up with.
Apr 12, 2011 | Car Audio & Video
Need color schematics for pioneer super tuner III
This is manual for super tuner 3 but there are different model look on this site and you can pick the one you want.
http://www.pioneer.com.sg/storefront2/manual/DEH-1050E.pdf
Feb 18, 2011 | Car Audio & Video
Need wiring diagram for pioneer supertuner DEH-405
Download manual from Pioneer website. Yellow is b+, red is acc, black is chassi ground. Green, brown ,gray and white wires are color paired for speakers. Blue wire is amp remote turn on .Hope this helps
Nov 01, 2009 | Pioneer DEH-1600 CD Player
Sterio installation question
its possible if Ur very careful u need the power wire/ ground and all the speaker wires u can identify these using a multi meter to determain which is the power wire and ground the speaker wires shoul be similair in color like solid brown then a brown with a stripe on it them solid green then a stripped green etc.
Sep 17, 2009 | 1990 Toyota 4Runner
Having trouble hooking up the pioneer deh1700. the colors dont match with the vehicle its a 92 chevy lumina
" I AM NOT A PROFESSIONAL NOR AM I ACTING SUCH, I am only stating what I have done to solve "this" kind of problem.
First look on the original stereo from the Lumina and look for a wire digram to see the color coded wires. If you see this match with the list below, if you do not see this... after removing the stereo, With a test light or multi-metor look for a good ground to place the - clip or - probe. then look for a red wire. place the + end or the test light into the plug. if it light up that is the constant + [hot] wire. then with the ignition ON, place the light probe in to the next socket till you find another hot wire. turn the key OFF and see if the light shuts off. when you find this wire it is your ACC. the power antenna on my Honda is yellow/white I do not know the factory color for yours maybe blue, i don't know. to locate your speaker wires...... generally same colors [ brown, brown/black yellow, yellow/red and such]. you can take the batt pack out of your cordless drill and "TAP" the wires to the + and - of the batt pack. {hold the white to the + side and tap the white with black stripe to the - side...the speaker will make a popping sound. log all the colors with the location. You should have this....2 speakers should have 4 wires, 4 speakers - 8 wires If you do not have the amount stated then you have a common ground system and your - is grounded to the chasis [body/frame] and you will have one + wire for each speaker.
" just in case " the wire diagram for the Pioneer DEH 1700 is as fallows...
Black -- GROUND [-]
Yellow -- 12V constant [+]
Red -- 12V ACC [key on + only]
Blue -- Power Antenna
White -- left front +
White/black -- left front -
Grey -- Right front +
Grey/black -- Right front -
Green -- Left rear +
Green/black -- Left rear -
Violet [purple] -- Right rear +
Violet -- Right rear -
Aug 14, 2009 | Pioneer DEH-1700 CD Player
Need a wire diagram for pioneer DEH-1100 super tuner
Usually it's....
black = ground
red = switched battery power
yellow = constant batery power (for clock...etc)
orange = illumination
blue = amplifier turn on or accessory (electric antenna, amps etc)
green/white/purple/grey are speaker wires.
Apr 25, 2009 | Car Audio & Video
Manual for pioneer deh-10 super tuner
Have you tried www.PioneerElectronics.com? They have the Manuals if you go to Customer service on the Site and Do some Searching. That's where I get ALL of mine and I only Buy Pioneer!
Dec 31, 2008 | Pioneer DEH-P2000 CD Player
Pioneer deh-p520 super tuner 3
Black, red, gray and white (for the front speakers only).
Black: Ground
Red: VCC
Gray: Speaker
White: Speaker.
Remember to isolate any unused cable like the blue (remote), green and purple (rear speaker).
Feb 15, 2008 | Pioneer DEH-P5200 CD Player
Car Audio & Video Logo
95 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
