Question about JVC AV-27D502 27" TV
JVC 27" D series
My TV stopped working and the timer light flashes
  • 2 more comments
  • Anonymous May 16, 2008
    timer flashes, no remote control available
  • Anonymous Jul 03, 2008
    no remote controle work for volume and channel
    my tv open manually (button of front pannel )
  • guezz Jul 09, 2008
    I have the same problem however I ve been told that if the timer light flashes continuosly that there is another existing problem that requires a technicians expert repair.
  • Tancowboy Dec 18, 2008
    Did anyone find out what the cause of the problem? My just displayed the same problem. When plugged in the tv sound is on for a few seconds then it displays the flashing timer light.
    New Friend:
Jvc 54cm model avf 2143 works 4 a while then picture goes of and timer light flashes
Posted on Apr 02, 2013
There is another problem that requires a tv repairmans expertise when the timer light flashes continuosly ,and the power is not restored.
Posted on Jul 09, 2008
My tv will not turn on and the on timer light is
Try the following blog. It has detailed instructions on how to fix a common problem on this JVC TV series. I did and I fixed my TV for 2 bucks at home.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 14, 2010 | JVC AV-36950 TV
Cable went out yesterday, when came back their was no picture or sound. green light flashing on timer. jvc av 27230 27" tv
did the input line still work, for the cable input do an auto search channel to reset your tuner, if it didn't work stop right there your tuner is mabye out
Feb 20, 2009 | JVC AV-27230 27" TV
Tv shutting off timer light blinking
The problem you describe is not really related to a timer function being set. The unit is in shutdown and the light is blinkng to let you know there is a problem.
There are several possible causes. the most common is a failure in the vertical deflection circuit due to a bad vertical IC and possibly a capacitor, zener diode and resistor.
Feb 19, 2009 | JVC AV-27530 27" TV
Av-32d302 tv
The set is shutting down because a problem has been detected. Replacing the remote will not help. Count the flashes and call a JVC servicer to get an idea about what the specific problem may be.
Dan
Jul 29, 2008 | JVC AV-32D302 TV
JVC 27230
Hi, last night I tunred my tv off and when I went to turn it on in the moring, the timer light keeps flashing. I have no reason to set the timer. I've tried to un-plug it and plug it back in but it keeps turning off. What can I do? Thanks
Mar 29, 2008 | JVC AV-27230 27" TV
My TV turns off by itself. How do I correct this? JVC TV TURNS OFF IN 2 SEC. AFTER TURNED ON SLEEP TIMER LIGHT FLASHES. BYPASS POWER RELAY
it could be a memory error or a main power supply malfunction.please contact the nearest repair shop.
Jan 07, 2008 | JVC AV-27230 27" TV
TV, i plug it in, turn it on, no image, "on timer" light comes on.
In a large number of failures with these symptoms it's usually the HOT (horiz. output trans. Q522, which is a 2sd2499) and the regulator (Str30134), together with fuse F902 (Gma 1.25a). Not an expensive repair or that complicated if you're fairly good with electronics and know how to solder correctly. Otherwise take it in and have it repaired professionally - it's worth it...
Bill
Nov 29, 2007 | JVC AV-27230 27" TV
Television want turn on
Bill
Nov 15, 2007 | JVC AV-27230 27" TV
If you dont hear a click theres a problem in the standby power supply. if you do hear a click theres a problem in the Main power supply or sweep supply. Get a good tech to look at this for you if your not a tech. Good Luck
Aug 07, 2006 | JVC AV-27D302 27" TV
On Timer light flashing on my TV
If you're NOT still under warranty you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. good luck!
Nov 30, 2005 | JVC AV-27120 27" TV
JVC AV-27D502 27" TV Logo
498 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
