Question about Craftsman 118 pc Dual Marked Mechanics Tool Set
How to change fuel lines on craftmans 36cc chainsaw
How do i change the fuel lines on my craftmans 36cc chainsaw how is the easyest way to do it
    Brigadier General:
  • 4,088 Answers
The best way is to change only one at a time. There are many folks on here that removed everything, then couldn't remember where the lines went. Use original lines, not plastic. Check your work by trying to pump fuel into the primer bulb. Good luck!
Posted on Jul 18, 2010
How do you replace fuel lines on a craftsman 16" chainsaw model#358.352161?
remove the carb and then pull fuel lines from tank ,there should be a filter in tank attached to the fuel line you will put that on the new line then feed it through from in the tank out
Oct 30, 2014 | Craftsman Garden
HOW DO YOU REPLACE FUEL LINES ON A CRAFTMAN CHAINSAW MODEL 358355160
The lines are usually a tight fit in the fuel tank. This prevents leaks. They must be pulled out of the tank (one at a time) then cut the new lines end in a "v" pattern, this will allow you to push the new line through the tank. Long needle nose pliers are needed too.
May 09, 2014 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Saw repair
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
HTH
Lou
Dec 07, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Sears model 358.356280 chainsaw. Just replaced
Sounds like you need to pull out the spark plug and put some fuel directly into the cylinder to get it fired up.
Nov 14, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Chainsaw idles, goes to high speed for a few seconds but dies under load. Sometimes cuts half a limb before it dies. Changed gas and then changed spark plug. Still dies.
have you looked at the filter in the tank? get a wire hook fish around in the tank it should be on thend of a fuel line inside the tank
Aug 22, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Craftman,36cc, 18" Gas Power Saw Blade
Go to a home improvement store and buy a new chain, they are cheap!
Jul 29, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Oil & Gasoline
Hi Thomas, you can find bar oil for the chain at just about any hardware store. Just tell them you need chainsaw bar oil. The oil that mixes with the gasoline is called 2- cycle mix. They will have that also. You can find the 2- cycle mix at a lot of gas stations too but a lot of guys caution not to use the 2 - cycle mix that is made for outboard motors. . Hope that answered your questions.
Jul 11, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Chainsaw will run for 5 min then stalls out
I would change the in tank fuel filter. Do this by draining the fuel and fishing it out with a stif piece of wire it is conected to a rubber fuel line in the tank. Also check to make shur the screws that hold the carburator to the engine are tight.
Jan 04, 2009 | Garden
Craftsman 118 pc Dual Marked Mechanics Tool Set Logo
312 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
