Question about Microsoft Streets and Trips 2008 for PC
Streets & Trips 2008 stopped working. Now all I get is an error that states the registry files were not copied correctly. Looked on line and tried several fixes for this problem but nothing worked. Any suggestions
  • 38 Answers
Right click on the program icon and click Run as Administrator. Type in the Admin password. Should start with no problem. You'll need to do this every time you start the program.
Posted on Aug 15, 2010
When I started MS Streets and Trips 2010 with GPS, I got a window that said: "Your registry settings for this application were not copied correctly. To correct these settings, run Setup again for...
Look on the box to see if Windows Vista supports this software. If so, I would suspect you have a deficiency in the hardware. (i.e. Not a powerful enough video card, not enough memory or not a powerful enough processor)
Nov 22, 2010 | Microsoft Streets and Trips 2008 for PC
HOw can I reinstall Streets and Trips 2008 when my disk isn't working? I have the product key.
I'm think Streets and Trips 2008 was really just an update to the 2007 version.
This means there wasn't really a download for S&T 2008 - It was a download of 2007 plus an update file to 2008. If you can find the FREE TRIAL version of Streets and Trips 2007 from somewhere and the 2008 update, you will still be able to use your existing product key to upgrade it to a full version again.
You might be able to get a disc-image file of the CD supplied with the 2008 boxed version from somewhere like Rapidshare. Try a rapidshare search at www.rapidshare.net or www.filecrop.com
Beware versions supplied with a cracked product key as using them constitutes software piracy. As long as you install it and register it with your own product key, it's legit.
Unfortunately, you can only download the current 2010 version of S&T from Microsoft although map updates are still available for the 2008 version.
Oct 13, 2010 | Microsoft Streets and Trips 2008 for PC
STREETS AND TRIPS 2010 INSTALLS CORRECTLY, but states "registry settings not copied correctly". Set-up RUN AND INSTALLATION o.k., BUT PROBLEM PERSISTS
Hi
I'm giving you a link to Microsoft that will tell you the steps to fix this based on your operating system.It seems to be a fairly common problem if they post a dedicated troubltshooting page.
If this works for you,would you rate my post please?
Thanks
Bob
http://support.microsoft.com/kb/314590
Aug 20, 2010 | Computers & Internet
I am using Vista Premier. My Streets & Trips
uninstall. type regedit in run. In the left pane click HKEY Local Machine. Find Software and Click. Find Streets & Trips Delete it 'All". close the box. clean your drive. Restart & reinstall
Jul 30, 2010 | Microsoft Streets & Trips 2009 Full...
Will not open on computer
The uninstall might not clear everything from the PC. Often files and registry entries are left behind, and maybe they are causing a problem in your case.
Try secureuninstaller to completely remove everything and then install again.
Apr 17, 2010 | Microsoft Streets and Trips 2008 for PC
Registry settings for this application were not copied correctly
it was 2008-2009 thats why it said it i have a vista computer 2 mine did the same thing the version last up2 2009 2008-2009 thats why
Jun 04, 2009 | Microsoft Streets and Trips 2008 for PC
Microsoft streets and trips 2009 registry issues on vaio p588e/r
Hi, go to the "streets.exe" file in the program folder, right-click it and go to "Properties". Click the "Compatiblity" tab and uncheck "Run this program...". Try it now. It's what I had to do.
May 03, 2009 | Microsoft Streets & Trips 2009 Full...
Your registry settings for this application was not
Hi
My personal openion is , by using just only Registry cleaners will not solve your problem
We need to get rid of every supported file.
so suggest you for
1) Uninstall the application
2) Restart
3) Use Regsitry Cleaners
4) After successfull cleanup of regsitry go into registry for manual removal by clicking Start -> Run --> Regedit
5) Now locate HKEY_LOCAL_USER -> Software ->
Here locate the application matches with the name of MS Streets (actually i have not used this, so i am not sure about the exact name, but i am sure that you will locate it)
And DELETE that key
6) Same is for HKEY_Current_User--> Software
7) Now go into System Drive (usually C drive) and locate the programfiles -> MS Streets
(again i have not used this, so i am not sure about the exact name, but i am sure that you will locate it)
And DELETE It.
8) Now restart the system
9) Now we need to use some JUNK FILE CLEANERS for get rid of other supported files
so i suggest you to go with Tune-Up Utilities 2008 version (its trial ware for 30 Day - Fully Functional)
so from that use your JUNK FILE CLEANER
10) After successfull clean up i incist you to execute the Defragmentation process on system drive (usually C drive) so that we can close the backdoor for support files.
11) So after doing all above MAINTANANCE then try to install the application once again
If problem persists.
Please let me know, then I personally get involved with this topic
Thanks
Sep 17, 2008 | Microsoft Streets and Trips 2008 for PC
Microsoft Streets & Trips 2005
Maybe if enough people come together and post our opinions they'll listen. Lets get everyone with these problems to post their problems. United we stand and devided we fall
Jun 01, 2008 | Microsoft Streets and Trips 2008 for PC
Microsoft Streets and Trips 2008 for PC Logo
80 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
