Question about Lexmark X4650 InkJet Printer
My lexmark X4650 gives me a message that the network printer is busy when I try to print wirelessly. There is no other computer trying to print.
    Genius:
  • 1,087 Answers
Make sure there are no print jobs stuck in the queue then unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging it back in. When the printer's ready, try printing again. If the problem persists, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Posted on Jul 17, 2010
I recently purchased a Lenovo All in One wireless computer. I've plugged in the USB cable as per instructions but my X4650 printer will still not print.
Have you installed the printer drivers? Is the printer power turned on before plugging the USB cable into the computer? You could have a bad cable. Try a different cable.
Dec 13, 2014 | Lexmark X4690 Wireless InkJet Printer
I have a Lexmark X4650 InkJet Printer I need to find a driver to install
You can download the drivers for your Lexmark X4650 at www.Lexmark.com. Just choose the Operating System of your computer.
May 03, 2012 | Lexmark X4650 All-In-One InkJet Printer
How to stop orange wi fi light from blinking
The blinking WiFi light on your printer could indicate that it's trying to communicate with your wireless network or it's not connected to your wireless network anymore. A quick fix to this problem can be achieved by rebooting your system. Simply unplug and re-plug your printer and your wireless router into the power outlet and reboot your computer. Once everything turns back on, check the status of the WiFi light and try to print again to verify that the problem is fixed.
You can also do the following steps to reset the printer wireless network adapter:1. From the printer operator panel, press the Setup button.2. Select Network Setup.3. Select Reset Network Adapter.4. Hit the OK button.
The WiFi light will momentarily turn off and then on solid orange. You can then try to reconfigure the printer to connect to wireless network using the Lexmark Wireless Setup Utility application on your computer. Go to Start menu > Programs > Lexmark 4600 Series folder > Lexmark Wireless Setup Utility. Simply follow the instructions on your computer screen.
However, if you wish to have it connected directly to your computer. Simply connect the printer with the USB cable that came with it in the package.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 20, 2011 | Lexmark X4650 All-In-One InkJet Printer
My wi fi orange light is blinking on my lexmark x4650 printer
The blinking WiFi light on your printer indicates either your printer is trying to communicate with your wireless network or your printer is not connected at all. For a quick fix, try to disconnect your printer from the power outlet. Power cycle your router and reboot your computer. Then, power on your router first, then your printer and lastly your computer. Check the WiFi light on your printer. If it goes to a solid green, that means you are connected back in your network. If not, you may reset your printer's wireless network adapter to its default settings. From the printer operator panel, press the Setup button > Network Setup > Reset Network Adapter to Default. The WiFi light on your printer will momentarily turn off then back on solid orange. Then try to run the Lexmark Wireless Setup Utility on your computer to reconfigure your printer to connect to your wireless network.
I hope this helps.
How to stop wi fi from flashing orange on my x4650 lexmark printer
I hope this helps.
Nov 20, 2011 | Lexmark X4650 InkJet Printer
Hi their, im matt Right, i reinstalled everything on my computer because i wanted to start a fesh installation. Im running windows 7 ultimate 64bit. I have tried to reinstall my printer but no look. I...
Check if your printer is still connected to the same network as your computer. Refer to this article: How to Print the Network Settings Page on X4600 Series All-In-Ones (AIOs). If you the printout, check the SSID and other network information. If printer still belongs to your network, then it could be a firewall issue. Make sure to allow all Lexmark and printer communications in the program rules/permissions for your firewall. If printer doesn't belong the same network as your computer, then you need to reset the printer's wireless network adapter and re-launch the Lexmark Wireless Setup Utility. How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults
May 29, 2011 | Lexmark X4650 InkJet Printer
After the power went out and came back up the wireless printer is orange and i reinstalled all the drivers on all the laptops, but it wont communicate with the printer lexmark x4650
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Frequently, issues are caused simply by a break in the signal sent from PC to printer or vice versa. Unplugging and re-plugging the printer allows the small amount of on-board memory on the printer to be cleared, with the result that the PC recognizes the machine properly. Programs continuing to run in the background of the operating system (OS) can cause the signal to be lost. Rebooting the PC ends all programs that may be running and makes a 'clean' start, allowing the signal to be detected.
If connection is still not established, try to print the network settings page to determine if your printer is still registered in your wireless network. 1. Press Setup (pattlnk_632008_2048-x4650stup.jpg) on the printer operator panel. 2. Press the right or left arrow button until Network Setup is displayed, and then press(pattlnk_632008_2052-x4650ok.jpg). 3. Press pattlnk_632008_2052-x4650ok.jpg at Print Setup Page. 4. Press pattlnk_632008_2052-x4650ok.jpg when prompted to Load Paper. 5. Press pattlnk_632008_2052-x4650ok.jpg. The network settings page will now print.
Check the SSID and the IP address on the settings page. If info shows that your printer is no longer registered, you may need to reset the wireless network settings of the printer.
Follow steps 1 & 2 above, 3. Press the right or left arrow button until Reset Network Adapter Defaults is displayed, and then press pattlnk_632008_2052-x4650ok.jpg. 4. Press the right or left arrow button to display Yes, and then press pattlnk_632008_2052-x4650ok.jpg. 5. Observe the message"Clearing Wireless Settings". The WiFi light will momentarily turn off then lights up solid orange. You can now launch Wireless Configuration Utility or Wireless Setup Assistant (Macintosh) to reconfigure your printer to connect to your network.
Sources: How to Print the Network Settings Page on X4600 Series All-In-Ones (AIOs) & How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults.
May 11, 2011 | Lexmark X4650 InkJet Printer
I have a green Wi-Fi indication of the from of the printer, but it won't print. it says... Lexmark 3600-4600 series 3A82A0_P1
Try to unplug then replug the printer into the power source to reset it. This usually fixes minor communication issues. If problem continues, try to print the wireless network settings to check if your printer is still connected to the same network as your computer(s). Follow the steps in this article: How to Print the Network Settings Page on X4600 Series All-In-Ones (AIOs). If not in the same network, you may need to reset the printer. Follow the steps on how to reset the printer wireless network settings: How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults. To reconfigure printer back to your wireless network, refer to this article: How to Install the X4600 Series on Wi-Fi Network - Infrastructure Mode.
Apr 20, 2011 | Lexmark X4690 Wireless InkJet Printer
I am attempting to scan a document with my X4650 without success. The copy function works with no problems. I have used the scan function to my computer on numerous previous occassions without problems.
How is your printer connected to your computer, wireless or hardwired with a USB cable? If wireless, check the status of the WiFi light on the printer (green = connected to a network, orange = not connected to a network). Try to turn off/on your printer. Doing this usually fixes minor communication issues. This article in the Lexmark website might also help resolve your scan problem: No Communications Error When Trying to Print or Scan.
Apr 18, 2011 | Lexmark X4650 InkJet Printer
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
Lexmark X4650 InkJet Printer Logo
978 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
