Question about General Electric AJCS12DCC Thru-Wall/Window Air Conditioner
GE wall unit ajcs12dcc is not cooling enough - General Electric AJCS12DCC Thru-Wall/Window Air Conditioner
  • General Elec... Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 19, 2010
My side by side 23.6 cu. ft. no frost refrigerator is not freezing and the refrigerator is not getting cold enough. There's frost on the back wall inside freezer. It's a GE TFX24VR. What can I
usually that means your fridge thermostat is being blocked by items in your fridge, telling the cooling system to shut down. If your fridge and freezer are packed, the fridge might protect itself by shutting down the cooling system. Happened to us last Thanksgiving.
Mar 07, 2012 | GE Refrigerators
Not cooling enough on frigerator side but it still works on freezer side.
Hello Mjorgy,
I understand that you are having a problem with you refrigerator. The freezer is cooling fine, however the fridge side is not cooling enough. This is a common problem with the evaporator coil stops working. When you open the fridge or freezer you should hear a fan running or fell are coming out of the vents to the fridge.
I would love to help you further if you can please post a model number for the unit I will look up where the fan is located and let you know how to get to it in step by step instructions. You should be able to locate the model number in side the compartments on the wall close to the front. It is also located on the rear of the unit. Please post back to this thread so that I may assist you further.
Thank you for choosing FixYa.com
Justin
Apr 05, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Have a GE side by side gsh22sgress unit. Child left freezer door open. Unit ran for days (in non-occupied appartment). Meat thawed. Cleaned unit inside with mild soapy mix. Unit runs but will not cool...
Open door let too much moisture into refrigerator. (The cooling coils, behind the back wall of the freezer compartment, are blocked with frost) If you unplug the refrig for a day or so it will work again, or you can take the back wall out from inside the freezer and melt the frost with a hair blower.
Aug 21, 2010 | GE GSH22SGRSS Side by Side Refrigerator
My GE wall Airconditioner is not cooling brings out warm air?
mcdevito75, here, wall A/C do they also give out Heat, if so, refer to the owners manual for instructions on how to use the cooling. Set switch to low cool and the switch with the blue scale about 1/2 way thru the blue scale shown on the switch (Knob) Both your A/C units may be set on heat, double check position on switches, (Knobs)
Jun 24, 2010 | GE AJCQ08ACB Air Conditioner
Freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Nov 08, 2009 | GE PSS25MGN Side by Side Refrigerator
The frezer not cool enoug
you may not have enough air circulation at the rear of the machine when you moved it. if the machine can not loose heat through the radiator at the back it looses its cooling capacity. move it back to where it was?
Jul 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side fridge not cooling enough Freezer side was still
check see if you have frost build up in the freezer back wall you may have defrost problem
Apr 06, 2009 | GE Refrigerators
Ge refrigerator & freezer not cooling - frost build up on back wall of freezer
You probably have a bad defrost heater behind back wall of the freezer if you turn the unit off and let it defrost a fan will help speed this up the unit will run for about 2 weeks giveing you time to get a defrost heater GE have glass tube heaters and they are bad about going out good luck
Mar 31, 2009 | GE GSS23SGSSS Stainless Steel Side by Side...
General Electric AJCS12DCC Thru-Wall/Window Air Conditioner Logo
134 people viewed this question
Top General Electric Heating & Cooling Experts
Bill Long
AJMAL KHAN
Are you a General Electric Heating and Cooling Expert? Answer questions, earn points and help others
