Question about Braun Kitchen Appliances - Others
Braun 4118 toaster NOM 176. Won't stay down when you push the lever to start toasting. We took it apart but couldn't see anything broken. Yes, it was plugged in.
Ian Prins
  • 11 Answers
SOURCE: toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Posted on Dec 06, 2007
SOURCE: when i push the lever down to make toast, it does not stay
no solution, problem, my lever (sometimes) will stay down, sometimes not, but it makes a loud "ractething" noise many times when the lever is pushed down>
best, randy
Posted on Dec 12, 2007
SOURCE: My toaster doesn't stay in the down (toast) position unless I hold it down
I had the same problem with this model. Made sure it was unplugged, took the 4 screws out of the bottom as others did. Pulled off the handle for the toast push down and the knob for the darkness control (it took some effort but came off ok, if you can tilt the darkness knob opposite the number 1 it will come off easier, there's a hook-tab right at the 1 position).
My problem was with one of the points on the 4 copper tabs that come together as the toast is pushed down. The outer copper tab was slightly out of alignment when the toast was in it's latched position and broke the circuit making it never want to latch. I bent the problem one into alignment and solved the problem.
Posted on Jan 01, 2008
SOURCE: Digital Display no longer showing, lever won't stay down
YOU HAVE A DEFECTIVE DIODE THAT LITES THE LCD. A .99 CENT PART. SELLER SHOULD REPLACE THE TOASTER WITH OUT QUESTION.
Posted on Sep 30, 2008
venexcsd
  • 1185 Answers
SOURCE: my cuisinart cpt 160 toaster won't start
Do any of the lights come on ?
If not then have you checked the plug top fuse
If the lights come on and then when you press the lever down it does not latch a solenoid has gone open circuit
Good toasters can be fixed
Cheap ones go in the trash bin
Posted on May 29, 2009
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
www.dummies.com/how-to/content/how-to-fix-a-broken-toaster.html
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
https://www.youtube.com/watch?v=QKiJkpuHy-Q
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
GE toaster model 169100. : the lever to toast won't stay down. I researched removing the base to clean the magnets, but not regular Phillips screws. Suggestions??
I have the same GE toaster and now my lever won\'t lock in place when I push it down to cook my toast. The handle does not pull off and when you turn the toaster over there are no screws to take the toaster apart. So I guess I have to say this is a disposable toaster but I am extremely bummed because it is beautiful and match decor and microwave that has the same color scheme as my toaster.
I wish companies would stop making cheap junk that doesn\'t last more then a few years.
Sep 06, 2013 | GE small appliance toasters 169100 User...
Lever on toaster will not stay down
For what it might cost to fix it buy a better brand of toaster for about 10% of the cost of this horrible brand.
You'll notice their new ones are "smart" toasters with NO LEVER. You push a button and the electronics takes care of the rest (and blow up quickly.)
$15 to $25 at Walmart.. instead of $100 to $200.
Dec 13, 2017 | Breville Kitchen Appliances - Others
The digital control panel is on the fritz,
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down--and none of the buttons were functional.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Nov 28, 2008 | Oster 6330 4-Slice Toaster
Braun 550 Toaster
Return it to vendor for replacement.
Small electricals such as Toasters, Kettles, Computer parts, Audio & Cameras and the like do not get repaired - they get replaced and the seller is the place to go.
Jan 24, 2008 | Kitchen Appliances - Others
Bread won't toast
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down.
Dec 27, 2007 | Kitchen Appliances - Others
When i push the lever down to make toast, it does not stay
This is a problem, our old toaster had this problem, and it would only work if we jammed the handle down, but don't try this, only because ours broke after we tried this, but if you can send it to the manufacturure, they should be able to fix this. If you don't what to do this, please phone me at 505 9181, but please call me from 8:00-10:00, 2:30-8:00.
Oct 21, 2007 | Cuisinart CPT-60 Custom Control Total...
Toaster lever wont stay down
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
Kitchen Appliances - Others Logo
418 people viewed this question
Top Braun Kitchen Appliances - Others Experts
Oscar Netto
Oscar Netto
Tom Chichester
Are you a Braun Kitchen Appliances - Other Expert? Answer questions, earn points and help others
