Question about Peavey Pv 2600 Power Amplifier
How can i prevent it from over heating
How can i prevent my Peavey 2600
from over heating
  • Peavey Master
  • 5,603 Answers
Do NOT block airflow via the vents and fans. If other equipment blocks or restricts airflow, space out the items in the rack.
Some amps have vent fins at the sides and these must have free airflow.
Do not go below the load resistance rating by paralleling too many speakers.
Do NOT drive the amp into the clipping region with too high volume.
Posted on Jul 16, 2010
Pv 2600 manual como conectar subwoofer
Peavey service is quite helpful and has most parts in stock for good prices. Call them directly at (800) 752-7896
Jun 22, 2014 | Peavey PV 2600 Power Amp
My peavey amp pv 2600 only plays on channel A. No output on the B side
Check the "BRIDGE" switch position, "IN" for "BRIDGE", "OUT" for "STEREO", and clean ALL back switches with a cleaning spray and then run the amp again, also check the two green lights activation at front, if they activate, then amp is certainly working, let me know further.
Jan 28, 2013 | Peavey Pv 2600 Power Amplifier
Peavey 2600 m series shuts off power when turning up volume after about 30 to 40 seconds of playing and takes about 2 minutes to reset
Sounds like the thermal cutout is sensing over temp. Make sure there is FREE airflow around the unit. If it is in a cabinet, install vent fan(s). This amp will throw out a lot of heat. Make sure cooling fins have airflow. Cables can block the airflow... check for that possibility. Repeated thermal cycles will eventually cause failure of components.
Mar 27, 2011 | Peavey Pv 2600 Power Amplifier
Wat does the peavey 2600 do in a 2ohm stereo & a 4ohm bridge
It burns up...You are allowed no less than 4 ohms stereo or 8 ohms bridge mode.
Jan 14, 2011 | Peavey Pv 2600 Power Amplifier
Do you know what regulator/ rectifiers are used and their numerical values so i can repair my fried pv 2600 these are the row along heat sink small black ones 2 pin and 3 pin cheers
7815 and 7915 plus and minus regulators specifically. Diodes fr the 15 supplies are 1N4001 but you can use 1N4007 or anything in between.
Big power rectifiers are 2504's... which are probably 25 amp 400 volt modules.
Jul 18, 2010 | Peavey Pv 2600 Power Amplifier
Peavey PV 2600 and PV 14 mixer blown out by hard lightening bolt. Totally fried. Is it feasible to repair them?
Man, that's a tough one. Best answer I can give, it depends. It would take a tech looking at it and making an evaluation. Sometimes it just takes out the front end (preamps), sometimes it's worse.
Jul 31, 2009 | Peavey Pv 2600 Power Amplifier
No output on the right side of the peavey 2600 amplifier but the right is ok
Each channel is protected separately. I suspect that the outputs are fried on the right side or the output fuse has blown. This should be checked by a service shop.
Dan
Jul 15, 2009 | Peavey Pv 2600 Power Amplifier
Power supply problem
Use the series light bulb trick when trying to first power this up. Use a 150 watt bulb in series with the 120 volt power to avoid damage and blown fuses.
Jul 02, 2009 | Peavey Pv 2600 Power Amplifier
Circuit diagram for a Peavey 130 special
Try http://www.peavey.com/support/contactinfo/ You may be able to get one from them. When I was doing repairs they would only release schematics to Peavey dealers but you can always ask.
Jun 24, 2009 | Peavey Pv 2600 Power Amplifier
Peavey Pv 2600 Power Amplifier Logo
81 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Peavey Music Expert? Answer questions, earn points and help others
