Question about Northland D48 / G48 Side by Side Refrigerator
Refrigerator Unit motor runs but no fan in freezer/Refrig units.
I have a Northland 48" side by side refrigerator/Freezor Model NM13A S/N 030826-4. Unit is 6 years old. You can hear the unit running but the box is warm and there is no forced air going into freezer or refrigerator. Air is gently being pulled into and out of the top motor unit.
  • 1214 Answers
SOURCE: amana refrigerator warm
Chances are if they are getting cool but not cold-
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Posted on Jan 20, 2009
  • 227 Answers
SOURCE: Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Posted on Jul 06, 2009
projdoc
  • 2237 Answers
SOURCE: Whirlpool Side By SIde Refrigerator Freezer stopped cooling
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 28, 2009
  • 101 Answers
SOURCE: My northland 48
You could have something as simple as frozen evaporator due to defrost system malfuntion, bad compressor electricals or failed compressor. I believe the sealed system in that unit comes with a good warranty. I would contact Connie at the factory, 800-223-3900. She can help you find a servicer to repair it and also provide any further troubleshooting assistance you need. You can also find servicers in your area by visiting their web-site www.northlandnka.com in the support area.
Posted on Feb 13, 2010
  • 4 Answers
SOURCE: I HAVE A KENMORE COLDSPOT
We had the same thing and the problem was the frost sensor on the coils inside the freezer. It is behind the metal cover that gets all frosted up. When it works it senses frost on the coil and tells the control panel to activate the defrost wire which heats up the space melting any frost and then shuts off.
Our issue was the frost sensor but it could also be the heating element or the control panel. Anything in that little system.
Posted on Dec 23, 2010
I had the unit 8 years now and both side are not cooling although motor is running. Does the unit need to be recharged?
which motor is running? if the compressor is running, but you have no cooling at all, the unit has 'blown' its refrigerant charge. Game Over. If the fan motors are running, but the compressor is not, check the compressor start device for continuity... Sometimes the fans will mask whether the compressor is cycling, you may have to put your hand on the compressor itself to verify... If the comp. is very hot, but not running, once again, suspect the start device.
Apr 26, 2016 | Northland 42SSWGX2 Side by Side...
Freezer was freezing up. Technician came and thawed it up and got it cooling as it should; however, the freezer is only getting to 40 degrees. It is not making ice. It is not cold enough to keep my food...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 19, 2011 | Northland Pro-Chef Model, Three Door,...
Inside refrigerator strip between the freezer and refrigerator
The condenser fan motor at the back near the compressor is either dirty or not running at proper speeds. Clean the coils for air flow over compressor and if the fan is not running replace the fan.
Jul 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
After emptying the ice bin on 2 year old side frigidaire, the freezer is OK, but the fresh food side has stopped cooling. Any ideas?
check that the fan in the freezer is running,it circulates the cold air,if it isclose freezer door,open refrig. door lookto the upper left you will see where the cold air enters the refrig compartment and should fill air coming thruough vent this is a motorized unit and they sometimes fail,also check the return air hole located at bottomof refrig.sometimes get blocked by plastic bags etc
Jan 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Upper section of refrig. not cooloing. Remainder
check to make sure the freezer fan is turning. This should be inside the freezer unit at the top. It is probably behind an access panel.
If this fan is not turning, not enough cold air will move to the refrigerator side to keep it cold enough. If the fan has died, it will have to be replaced.
Oct 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Kenmore side by side refrig (no ice maker) Freezer works fine. The refrigerator side is not cooling. I have cleaned out the vent between the freezer and the refrigerator section by defrosting the...
Check to make sure the evap fan is running.
IF so, then let unit defrost, then turn back on, check for air comming thru top of refrig vent, if air moving ok, then let run for a few days and see if refrig warms again, if so then check for frost build up on back wall of inside freezer, if so, you have a defrost problem. With a defrost problem, defrost heater may be bad, defrost timer/electronic control may be defective. Either way, in most cases it is a defrost problem unless you don't have air moving and fan is running in this case you have a damper door problem inside air duct in refrig.
Sep 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hot refrigerator
you need to check the condenser fan motor located in back of the refrig behind cardboard cover. most likely the motor is bad or something is obstructing the fan from turning. also be sure the coil under the unit is clean as well. temporarily you can place a house fan blowing in the rear of the unit to keep it operating normally until you get it repaired.. peyton
Jul 14, 2008 | Whirlpool ED2FHSS Side by Side...
Confused /
Ok the freezer section works the refrig section think of the refrigerator as a large cooler with an inlet and outlet hole cold air is blown into the refrig from the freezer via the fan motor in the freezer the really cold air comes in the top of the refrig and drops to the bottom of the refrig then it is sucked back into the freezer thru a vent hole in the bottom of the refrigerator ..GOT IT?? Now when a unit has a defrost problem there is an ice or frost build up in the freezer on the coil (bad heater,bad bi metal, bad timer can cause this) the ice builds and builds to the point where it blocks the air flow across the coil hence the air can not get to the refrigerator section making it warmer but the freezer section will work ok .. I hope this makes sense...Hint : A sign of this is a lg frost buildup on the back wall of the freezer.
Nov 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Problems with Frigidaire FRS6R4E Side by Side Refrigerator?
The refrig side does not have a fan. only the freezer. Is that fan working??? you will hear it when the unit is running (and not in defrost) The clicking you hear is the Damper (a motorized door allowing more or less air to the refrig) opening or closing. Is there frost buildup on the back wall of the freezer??
Nov 23, 2007 | Frigidaire Side by Side Refrigerator 26...
Northland D48 / G48 Side by Side Refrigerator Logo
75 people viewed this question
Top Northland Refrigerators Experts
Cameron Dyer
Cameron Dyer
Level 1 Expert
Bill Boyd
Terry Weaver
Terry Weaver
Are you a Northland Refrigerator Expert? Answer questions, earn points and help others
