Question about Vizio VF550M 55 in. LCD HDTV
Tv wont turn on has power.
Came home and tv wouldnt turn on used the button on the side of the tv and came on but the picture came on for 2 seconds and then went to a green screen. turned it of and unplgged it plugged it back in now the tv wont turn on.
  • Anonymous Mar 29, 2014
    screen turned green and shut off and wont turn back on
  • 11,361 Answers
Iconia w5 wont turn on battery wont charge
Try to connect charger and power on tablet by pressing power button during 5/10 seconds.
If that doesn't work, since it's a new device, I would recommend you use the service of ACER.
Apr 01, 2013 | Computers & Internet
I have an apex tv and for a long time now ive noticed that when i turn it on i have to press the video button on the remote 5 times for the tv to actually turn on. this was always annoying and sometimes...
flyback transformer is deffective (below is its picture) - if you have experience in servicing line ( electronics ) then change this particular component otherwise if you have a friend who is in servicing line ( electronics) then ask him to remove this particular component - take to electronic shop - buy same type ( equivalent will not work ) flyback transformer - below that 8 or 9 pins will be there - check whether they are same as in the old one --- then fix back to the mainboard ---- 2 or 3 knobs will be there on it ----- after switching on tv using suitable screw driver adjust those knobs slowly & carefully until you get clear picture.................. remember while adjusting knobs your hands should not touch any part of the tv .............. 100 % guarantee again your tv works normally - GUARANTEE
Jun 17, 2011 | Apex Digital AT2002S 20" TV
Hi i have a magnavox 42" plasma TV (model
I'd look for the manual and see what it says about that red light. I can't find squat for "Magnavox KM42010P".
May 28, 2011 | Philips Magnavox MRD120 - home theater...
My iphone 3g wont turn back on. the facebook app was acting up so i did a hard reset. once i turned the phone back on facebook was still acting up so i did the hard reset again within 5 mins. when i tried...
You could try putting the phone into recovery mode, then resetting the firmware through iTunes. To enter recovery mode you must: 1) Open iTunes and connect your iPhone 2) Press and hold the home button and the sleep button at the same time. 3) After 10 seconds, release the sleep button but continue holding the home button After following these steps, your iPhone should now be in recovery mode and ready to be restored using iTunes. Good luck!
Mar 12, 2011 | Apple iPhone 3G
Turn demo mode off on Sony Bravia TV 40"
Here'show to turn off the demo mode,
Power ON the television
(Use remote Commander)
1.Select "TV" mode (not AV, demo mode can't switch offwhen you are in AV)
2. Press the "home" button on the remote.
3. Select "settings"
4. Select "set up"
5. Scroll down to "factory setting" and restore them.
6. When it asks home or shop display select "home".
Feb 14, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
Dec 19, 2009 | JVC Televison & Video
When i turn it on, the green light shows, but i don't have picture, sound, and the fan turns on at first, but then it turns off in a couple of seconds.
does the red light flash when it cuts off? if so this is the"yellow light of death" there are videos on youtube on how to fix this....youll need to have some electronics skills....
Nov 02, 2009 | Sony Playstation 3 (PS3) Console
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
Doesnt turn on.
This same thing happened to me. I was playing fantastic contraption and my ipod screen just went black and wouldnt turn back on. When I plugged it in to a charger, it made that charging noise, but wouldnt turn on. SOLUTION: try holding in the sleep/wake(power) button, and the home button at the same time for about 15 seconds or until you see the white apple logo. That worked for me, hope you get it fixed.
Flaming Llama
Jul 04, 2009 | Apple iPod touch Second Gen (8 GB,...
My navigon 2110 wont turn on
2 things that might help...use a paperclip and press the reset button (small hole on side, you'll feel a click) hold it for 5 seconds. THEN hold down the power on button for over 10 secs (keep holding while it shows version number) and it will perform a factory reset. You will likely lose any settings and addresses, but better that than no GPS unit.
May 10, 2009 | Navigon 2110 Series Satellie GPS Receiver
Vizio VF550M 55 in. LCD HDTV Logo
381 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
