Question about Whirlpool MH7140XF Microwave Oven
Reads F2 doesnt work - Whirlpool MH7140XF Microwave Oven
    President:
  • 949 Answers
F2 indicates a failure in the touch key pad. The part number for the keypad is 4393916 for white, 4393917 for black and 4393918 for almond color.
The part runs about $77.00. It can be replaced by removing the upper grille, then removing the one screw on top of the touch pad.
Posted on Jul 16, 2010
Error code F2
Per the tech sheets (page 8), "F2" error code means "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too. Not the best recommendation but we have to follow it.
- The part number for the touch panel (aka a membrane switch) is AP3130765
- The part number for the control board AP3130764
Here are the break down diagrams for the Kitchen Aid microwave Model KHMS155LSS4
Gene.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Read more: http://forum.appliancepartspros.com/microwave-repair/19054-kitchen-aid-microwave-error-code-f2.html#ixzz3bRus7JKM
May 28, 2015 | Microwave Ovens
Whirlpool mircowave model MH3184XP the display reads F2
There is a problem with the control pad. The membrane, or surface, of the pad may be broken or damaged somewhere, resulting in the F2 error code. This is common for Whirlpool microwaves.
Press "Stop/Cancel" twice and select a new cook program. Press "Start" to begin.
If the error code persists, press "Stop/Cancel" again and unplug the microwave. Wait several minutes and plug it in. If the F2 code appears again, it requires repair.
Replacement membranes can be found online
http://www.appliancepartspros.com/whirlpool-panel-asy-control-8205376-ap3775860.html
but the internals of a microwave are dangerous, having high voltages even when unplugged. With the cost of parts and labour from a service tech, you may be best buying a new oven.
Sep 04, 2013 | Whirlpool MH3184XP Microwave Oven
A code of F2 appears on the LED clock timer - not always, but peridically every 30 seconds or so. I unplugged the unit, for 30 seconds, plugged it back in and it worked for about 20 seconds. Then the key...
F2 is a bad keyboard error code. Try this, unplug the unit, open the control panel and disconnect the ribbon cable from the control board, plug back in, if f2 comes back on the board needs replacing, if it does not, then the problem is with the keypad.
You can visit this link if you need any help regarding replacement of the touch pad.
Hope this helps. Thanks and have a nice day.
Jul 05, 2011 | Whirlpool MH1150XM Convection/Microwave...
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    Kitchenaids microwave error message F2.Q1. What to
    F2.Q1 Not reading keypad
    inputs
    1. Unplug microwave oven or disconnect power.
    2. Replace the user interface board (UIB).
    3. Replace the door control assembly.
    4. Replace all parts and panels before operating.
    5. Plug in microwave oven or reconnect power.
    Many of the error codes may be solved by power cycling: unplug microwave oven or
    disconnect power. After one minute, plug in microwave oven or reconnect power.
    i found this info on a tech sheet hope this helps, let me know how it goes... some of those electronics had 5 year parts warranty i would check that out....Also u might be better of buying a new one if its out of warranrty as some of those boards are expensive, obvioulsy unplug unit first try to reset it self.
    Feb 14, 2010 | KitchenAid KHMS2050SSS Microwave Oven
    F2 Error
    F2 is a membrane switch error.
    2. Replace membrane switch.
    3. If problem persists, replace electronic control.
    The answer to your question is YES. I would venture to say the PART is - but not the labor. You would need to read your warranty to confirm.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Sep 11, 2009 | KitchenAid KHMS155L Microwave Oven
    Microwave quit
    I dont know if this is going to work but qhat the heck do you have to lose
    unplug it for a few min. then plug it back in
    Feb 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    F2 WArning light on Kenmore Microwave oven
    The light bulb already works, so this isn't the problem.
    Oct 01, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
    Whirpool microwave
    check the operation of the micro switches on the lock motor. that they are open when they should be and closed when they should be. often they need to be cleaned or replaced.
    if this doesnt help re post there is some board work to do, i would suggest a tech do this part though. always unplug range when you work on them! If you are good at electronics and stuff and would like to do it yourself then contact me for further support!
    Regards,
    Vij
    Nov 21, 2007 | Whirlpool MH3184XP Microwave Oven
    Whirlpool MH7140XF Microwave Oven Logo
    78 people viewed this question
    Top Whirlpool Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
