Question about Brother IntelliFAX 2800 Laser Fax
Machine error 77
The machine reads machine error 77 unplug the machine and call brother
    President:
  • 567 Answers
Hello there, in a situation like this the best thing for you to do is to call Brother customer service at 800-284-4329 and explain the problem.
Thank you
Posted on Jul 17, 2010
2 Suggested Answers
guru_dev
  • 315 Answers
SOURCE: machine say error 77 call brothers
Power off the printer for 15 minutes and power back on again. If that fixes the problem then OK.
If not then go into maintenance mode -
Press and hold the menu/set key while turning on the machine. Wait until it comes completely up before releasing. It should say Maintenance in the display.
If not press function,*,2,8,6,4 within two seconds. It should say maintenance in the display. Or on some machines Menu,*,2,8,6,4 within 2 seconds.
Once you get it into maintenance hit 91 to do a parameter reset and than 99 to get out of maintenance.
If this corrects the problem then OK but you may have a failing thermister in the fuser.
If the problem happens again then change the thermister.
If the reset does not work then either the thermister or the fuser lamp has failed. In rare cases there is a poor connection with the cables to the fuser.
You will have to reset the parameter again after replacing the fuser if you need to replace the fuser or repair it.
Posted on Jun 26, 2009
After paper jam am getting error 77
Try this one:
1) Unplug machine.
2) Hold down menu key while plugging in machine.
3) Enter 99 while holding down menu key
4) After it says "PLease wait" hit the stop/exit button to get out of the maintenance mode
Hope that helps.....
Aug 01, 2008 | Brother MFC 6800 All-In-One Laser Printer
Machine is on and showing "error message #77 and says to unplug machine and call dealer. What is error 77?
Error #77 refers to a mechanical problem, but I'd say about 7 times out of 10 it's a mistake. Fortunately, Brother fax machines have override commands :). Try this:
1. Turn the power off and unplug the power source.
2. Press and hold the menu button and plug in the power source (don't let go of the menu button!).
3. Hold the menu button for 5 seconds after plugging in the power source.
4. Release the menu button and press "91"
5. If the screen still shows the error code, press "99".
Hopefully this will override the error and you can get back to work :) .
Hope this helps! Good luck!
Aug 30, 2010 | Brother IntelliFAX 2800 Laser Fax
Error 77 message
The 77 error is caused by a fuser temperature sensor. The following steps can be used to possibly reset the Intellifax 4100 77 error.
1. Unplug machine then wait 15-20 minutes.
2. Hold down menu key. Plug in machine.
3. Release menu key at maintenance message.
4. press 91 then set button
5. press 99 then set button
6. Machine will warm up.
7. Press Reports key, then press 1. This will test if the machine can
print.
If these steps do not reset the error the thermal fuse would have to be replaced by a repair technician.
Jul 22, 2010 | Brother IntelliFAX 4100 Laser Fax
MACHINE ERROR 77
You have a defective fuser unit, not heating up.
Jun 22, 2010 | Brother IntelliFax-4100e Fax
Fax machine Error 77 What do we do?
This is a Heater thermistor short circuit, to reset it...
  1. Unplug the power, press and hold the menu button, plug in the power
  2. (hold the menu button for 5 seconds after power is plugged in). Release
  3. the menu button, now press 91, if the display still shows the error,
  4. press 99.
Most people just ignore it, I suppose eventually if the thermoster is malfunctioning you could burn the printer out. But from a cost perspective I don't think it's worth replacing.
Jun 10, 2010 | Brother IntelliFax-4100e Fax
Error 77
Error 77 is fuser error . Shut off the power for 20 minutes . If that didn't reset the unit , then you need a new part . Call the local dealer to ask about new part price .
please rate !
Apr 13, 2010 | Brother IntelliFAX 2800 Laser Fax
Message on machine states error 77, unplug and call brother?
Error 77 basically means- Heater thermistor short circuit. However, the message is sometimes incorrectly shown. You can try this- power off the machine, take out the cartridge, close the door and power up. The machine should notice either the toner or the front door is not in place. Now open the door and place the toner. This might solve the problem. You can also try to soft reset the printer. If none of these works, you might have to change the thermistor.
Apr 06, 2010 | Brother MFC 9700 All-In-One Laser Printer
Machine says "unplug and call brother
unplug the machine for 15 to 20 minutes then try again. If not then within 2 seconds hit the keys in this order:
Menu-2-8-6-4-* (star key to left of 0) this may take a couple of attempts, but you will know when you are there because the lights will start flashing.
"maint. mode" then hit:
9-1-"set
and finally 9-9-"set"
this should clear up the error message if there is not a problem with the fuser unit.
Jun 24, 2009 | Brother IntelliFAX 4100 Laser Fax
Machine Error 76
Machine error 76 is a bad fuser lamp. Machine error 78 is a bad thermistor. Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off.
Sometimes the machines will give a false code and can be reset. Unplug machine. Hold down the Menu key while powering back up. You should still get a Machine error message. Enter the number 9...The display should change to Maintenance 9 then enter 1. The Machine error will return. Enter 99 and then make a test print. If you get either a machine error 76 or 78 you will need to have service done on your machine to have either the lamp or thermistor replaced, and depending on the usage of the machine, it might not be a bad idea to replace the entire fuser.
Jan 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
330 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
