Question about Maytag Heating & Cooling
Where to find selector switch
Where to find replacement for selector switch of Maytag M3X05F2E (original broken at the knob)
  • 14 Answers
SOURCE: Program selector know is broken
First thing i would do if it is not selecting a different cycle is take the knob off and check to if the inside of the knob is broken and hust turning on the shaft, other then that it proberly is electronic replacement.
Posted on Nov 02, 2007
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
SOURCE: Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Posted on Nov 18, 2009
TheMobilian
  • 8220 Answers
SOURCE: how to replace lid switch
Solution
Posted on Jan 23, 2010
Testimonial: "this was excellent exactly what i was looking for. i will pass your website along to friends & family"
tbirdfan1
  • 3051 Answers
SOURCE: how do I replace broken washer cycle selector knob
Hello there and thank you for choosing fixya
These knobs are normally the pull off type so all you have to do is get a small flat tip screw driver behind the knob and gently pry it out to get it started then it should slide off
However if you are needing to replace the entire part then the top back section of the machine may need to come off it may even have some screws behind the white side plates that allow to be removed and the top part folds up and back allowing you to axcess the part ok this part is usually held on by 2 or 3 screws
Posted on Jun 29, 2011
The program selector knob turns without resistance. How do I remove it to see if it's the knob or the shaft that's broken?
If no set screw on knob just pull it off. If shaft turns freely then the problem lies with the switch and it needs to be replaced.
Nov 07, 2015 | Washing Machines
Dewalt dc725 type 10, cant get 2nd gear
The selector switch may not be getting activated by the switch knob. This could be because they are not aligned properly or because the plastic ribs on the knob are broken.
This will usually result in the switch knob being much harder or much easier to move than normal.
Oct 20, 2011 | Drills
Model GSD3620Z02BB - The normal cycle will not engage when the knob is turned. The short cycle will engage (sound like it is working) but the soap is left in the reservoir and about 2 inches of water is...
Sounds like the selector switch has gone bad. The machine is not fully cycling thru and draining because the selector isn't proceeding like it should.
This typically happens if the selector dial is spun real hard repeatedly over time. The little cogs inside of the selector will get broken and sometimes the broken parts will lodge inside the switch and cause jams.
May 27, 2011 | Maytag Dishwasher
Bottom oven element stays hot will not cut off
In order for the element to stay on, the oven switch must be broken. No details are provided, but if your oven is like most, you have an Oven Selector knob for ~bake, broil, clean and another knob for Temperature selection.
Look at your Oven Selector knob closely to make sure it is not slipping on the shaft. It may be as simple as the knob being broken, and even though you are turning it to the Off position, the switch may still be on. If the knob is indeed turning the switch shaft, then it is most likely the switch stuck in the own position. Thanks for using FixYa.
Mar 03, 2011 | Ovens
Whirlpool Dryer LEO8857HQ. Selector switch. I'm not in front of the dryer now it's 1800 miles away in my sister's garage and she doesn't use a computer. The selector control knob came off in her hand and...
a piece of plastic from the original knob may still be on the shaft, thus preventing the new knob the ability to lock in place. Hope this helped Tim
Jan 14, 2011 | Whirlpool Dryers
Fabric softener cup on Maytag Neptune washer is full of fabric softener after the cycle. Checked valves in output mode. Both the main and the bleach valve turn on and dispense water, but no water dispenses...
Hi. your problem is actually a rather complicated one.
Timer and selector switches The timer switch is usually the largest dial on the main control panel. It can be either a mechanical device much like a simple clock, or completely electronic with just a digital readout.
The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
The Start switch is usually part of the timer knob. When you set the timer to the proper cycle, you either pull or push the timer knob to start the cycle.
The selector switches or knobs vary from machine to machine. Most washing machines have one or several switches or knobs on the control panel besides the Timer/Start switch. These let you adjust certain settings; for example, the water temperature, spin speed, timer cycle, and so on. Normally, the washing machine completes the cycle selected on the timer, regardless of how you set these switches and knobs.
Jul 14, 2009 | Maytag MAH2400A Front Load Washer
The program selector knob seems to be set wrong. When the arrow is pointing to off, we are able to turn it on.
Take the knob off. Re -position it with the flat side of the knob on the flat side of the shaft of the timer
If that does not work, replace the knob because it is broken inside.
Jul 09, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryer knob sticks in one spot- won't move
 Door switch / Door switch actuator leverThe dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Oct 25, 2008 | Maytag Clothes Dryer Almond Timer Knob...
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Heating & Cooling Logo
54 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
