Question about Thermador T30BR70FSE Freezer
The icemaker is not making ice.
Thermador freezer is not making ice; there is ice in the chamber but it is not falling into the ice bin.
  • 388 Answers
Dear sir/madam
i think it,s low gas problem so please contect to your service technician refill refrigerant in your freezer .
hope anser the question
thank you
please vote!
Posted on Jul 18, 2010
I have a Kelvinator upright freezer model k330uf the bottom section does not work
Sounds like its got blockage.
There is a channel that allows cold air to "fall" into the bottom chamber. There is also a return. Typically the "fall" chamber is choked with either something that fell in and was trapped, frozen solid with ice or algie has grown and closed the hole.
The best thing to do is empty it completely and inspect the drop channel.
Put all your frozen goods in ice chests to keep them from thawing out.
Good Luck.
Jan 08, 2015 | Kelvinator Freezers
Why would a hoshikia 450 mab jump from freeze cycle to harvest cycle without giving iot enough time to makle aload. would it be the cube sizer adjustment or a bad borard?
clean and dry the sensor and restart the machine. Adjust the thickness until the cubes make a plate but break apart when they fall in the storage bin
Jun 01, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Icemaker not making ice what can i do
The ice maker not making ice : ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Jul 19, 2011 | Kenmore Freezers
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
Kenmore freezer not making ice
Pour about 1/2 cup of water into icemaker ( unless ice is already there ) . If the icemaker dumps the cubes , then the water valve is bad . If it doesn't dump , and holds the frozen cubes , replace the icemaker . Also check your coils to make sure they are clean from dust , lint , etc . Check the fill tube going to the icemaker , to make sure it isn't frozen with ice . If it is , then watervalve is still bad (leaking ) .
Aug 25, 2009 | Kenmore Freezers
Kenmore ice maker problem
the problem is an unlevel icemaker to prove this do you see little droplets of water freezing from the icemaker or a remote possibilty is do you have to an R/O system and have you change the filter if unit has one.
Aug 19, 2009 | Kenmore Freezers
Makes ice but bin does not fill up
i would check the manifold for mineral build up. this could be the issue for the unstable water flow.
Mar 10, 2009 | Scotsman Freezer Clear Icemaker w/ Pump
Bin Full light stays on all the time
This is usually an indication that the photo eyes are probably dirty. They "See" across the opening where the ice drops through. If they are dirty, it registers as a fill machine.
A bin stat can cause the same problem.
The eyes and sometimes be a major problem finding them getting to them. On smaller machines like this one, it's hard to get your hands on them.
Good Luck and hope this helps.
Jan 08, 2009 | Scotsman Freezer Clear Icemaker w/ Pump
Thermador T30BR70FSE Freezer Logo
208 people viewed this question
Top Thermador Freezers Experts
AJMAL KHAN
John Tripp
John Tripp
marlin siecinski
Are you a Thermador Freezer Expert? Answer questions, earn points and help others
