Question about Garden
Lawn mower fires but doesn't wanna run
I have this lawn mower, it is a push lawn mower, not a ride one. I believe it is a electric start? anyway it has this button that you hold down with the bar and then it will fire and sputter but will not run. I Prime it 3-4 times just to make sure were getting gas in their and then i have to pull the string 3-4 times to get good compression, then i hold this orange button in and pull the bar back which ignites the engine and makes it sputter but it seams like it won't get enough power to run, sometimes RANDOMLY it may start but it's very hard and tiring getting it to. When i go to pull the cord again i can see grey smoke just coming out of the exhaust and it's not even running. And if the string is pulled to many times it makes a quiet to sometimes loud backfire noise. It's got plenty of fresh gas in it, and the rare few times that it has ran it runs very good. Any ideas as to the problem here? I was thinking it might have something to do with the fly wheel??? or winding cord, or maybe the carb is just bad, it fires everytime though and i see smoke everytime to, it is not black smoke.
Help appreciated.
(I apologize for bad grammar)
    Guru:
  • 630 Answers
You may have to inspect the woodruff key that is possibly worn out in the groove of the main shaft, To inspect this key way devise you need to remove the top off the mower probably 4 phillips screws off the plastic housing comes dont forget to pull out the oil stick, then removethe pull chord assembly in one piece 3 rivets need to be drilled out and reinstalled with new ones from Ace hardware when done, then remove the 3/4" nut...tap the shaft not to hard to loosen the flywheel and check to see that the keyway(woodruff pin) is worn out, go to a hardware store with the old one and buy a replacement reinstall everything and mower should be good to go.
Posted on Jul 16, 2010
  • 2 more comments
  • fantasyized Jul 16, 2010
    Thank you very much, i'll see to it that this is inspected.
    Is their any other possible problems i should know
  • JOHN DAVIDSON Jul 16, 2010
    Just the basics like a new spark plug, a new air filter, and every few years replace the muffler, also spray the mower down with WD 40 to keep all the moving parts functioning properly and to keep the mower intip top shape, also have them chanege the oil every few years and always check the level, and keep a nice sharp balanced lawn mower blade on the unit for a clean crisp look after the grass has been cut.
    Happy Mowing!!!
    Thank you for the good review!!! ;)
    your welcome sir, i'm confident all this saved information should help me make this thing fire back up, much cheaper then buying a new one anyways, lol!
  • JOHN DAVIDSON Jul 19, 2010
    Clogs and dirt in the carburator are a major factor as with all gas machines, the pro's use small cleaning rods used for gas/propane stoves etc. and carb. spray cleaner to try to flush them out.
    I just got done looking at a gas leaf blower...a part on the carburator went bad wouldn't start the part cost almost 90.00 it is called a diaphram small nothing looking item....i resoved myself to not repairing these smaller engines any longer as it is cheaper to replace them then it is to repair them with less the headaches!!
Engine will not start by the key and the electric PTO will not stay on
Hi John, I don't know if your mower is push OR ride on so The links below are YouTube videos that might get you out of trouble... Also there's videos down the right side of the links that may help as well....... I hope these help......... CHEERS..
How to test a lawn mower Key switch....
How to test lawn mower key switch
How to test a solenoid....
How to test lawn mower solenoid
How small engine governors work....
How Small Engine Governors Work any governor setup
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 28, 2016 | Electric Garden
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Our John Deere 160 lawn mower wont start. Installed new carb, fuel filter, battery. Has spark but wont turn over and run.
if the engine doesn't spin look at the starter if it has spark and a new carb is there power to the solenoid on the bottom of the carb does it fire on carb cleaner?
Apr 27, 2012 | John Deere Garden
21 hp electric start Craftsman lawn tractor, B&...
Have your mechanic set your intake/exhaust valves at .004 when piston is 1/4 inch past top dead center on compression stroke.
May 19, 2010 | Garden
Electric Start Spns & won't engage
i have a riding mower and i get that problem sometimes and what i do to fix it is i take a metal pole and put against the motor and gear on the starter and push when it moves i turn the key and that normally fixes it.
Jun 14, 2009 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Garden Logo
140 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
