Question about Harman Kardon AVR 340 Receiver
I cant get any sound out of my Harman kardon AVR 340 receiver even after reseting it, all the functions work fine its just not producing any sound out of the speakers. Please Help?
  • John Bermudez Jul 23, 2010
    I cant get any sound out of my Harman kardon AVR 340 receiver even after reseting it, receiver was working great untill a week ago all the functions work fine its just not producing any sound out of the speakers all speakers have been tested and work fine cables are connected fine and warranty has expired. Please Help?
  • John Bermudez Jul 24, 2010
    Do you know how to do the software reset of the microprocessor on a harman kardon 340 receiver? I looked at my manual all I found was the processor reset info that I tried already with no luck.
    President:
  • 4,070 Answers
Hi! The rca output may be faulty causing it not to give sound to the speakers. If that will be the problem then you will have to have it replaced for it to work again. Hope this helps and have a good one!
Posted on Jul 24, 2010
  • 532 Answers
If you bought the extended warranty, you need to go where you purchased it and they can look it up on their computer system.
Is the speakers defective, or not present (connected), check all cables
Thanks.
Posted on Jul 23, 2010
    All speakers have been tested and work fine cables are connected fine and warranty has expired.
    Brigadier General:
  • 3,917 Answers
Hi
In normal stand by mode the power indicator should be amber, in power on mode blue and red in protection mode.When you mention memory reset you mean Processor Reset? If not I suggest you do that. Here is the way. To clear the AVR 340’s entire system memory including
tuner presets, output level settings, delay times and speaker configuration data, first place the AVR in Standby Mode, and then press and hold the Tone Mode button for three seconds.
If the receiver still doesn't work correctly, try doing a software reset of the microprocessor.
The procedure is different for each model, and can be found by downloading the owner's manual on the product page or support page for the model.
The procedure is usually described toward the back of the manual on the same page
as the troubleshooting guide. Remember that the processor reset erases all of your configuration settings, and you will have to reenter them just as you did the first time you set up the receiver. If your receiver is functioning correctly some of the time or for some inputs or features only. It is recommended that you reread the owner's guide, especially the sections on first-time installation and system configuration.Many times it is possible to correct a problem simply by changing a setting in one of the receiver's menus.
Check whether the speakers are defective or not. Check your speaker wire connections to make sure no bare wires or strands are touching more than one terminal.
If you still have problems then please check the bellow link to contact the customer care…
http://www.harmankardon.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=AVR+340
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
    Do you know how to do the software reset of the microprocessor? I looked at the manual all I found was the processor reset info that I tried already with no luck. Any chance it could be a bad fuse?
HOW TO RESET HARMAN KARDON AVR70
Hi, Try this. Hope this helps and I have the link here to the manual.
Processor Reset
If the AVr behaves erratically after a power surge, first turn off the front-panel
main
power switch and unplug the Ac power cord for at least 3 minutes. plug the cord back
in and turn the AVr on. If this procedure doesn't help, reset the AVr's processor as
described below.
note: resetting the processor will erase all user configurations, including speaker and
level settings, and tuner presets. After a reset, reenter all of these settings from your
notes in the Appendix worksheets.
To reset the AVR's processor:
1. press the front-panel Standby/on switch to place the unit in the Standby mode (the
Standby Indicator led will turn amber).
2. press and hold the front-panel Standby and memory/folder buttons until the reSet
message appears on the front-panel message display.
3. press the memory/folder button again to reset the AVr's processor.
If the AVr does not function correctly after a processor reset, contact an authorized
harman
kardon service center for assistance.
to locate an authorized service center,
visit our web site at www.harmankardon.com.
https://www.harmanaudio.com/on/demandware.static/-/Sites-masterCatalog_Harman/default/dw409ee4c9/pdfs/AVR700NEW_OM_EN.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Jul 28, 2016 | Harmon Kardon Harman / Kardon Avr 70...
Working only after 10 minutes harman kardon
I dont know what to say bute it works bute i cant gett any sound from it it whas working and after i turnd it off then when i started it came no sound from it ?
Jun 18, 2014 | Harman Kardon AVR 130 Receiver
No sound on AVR 135. If there is a "sound card"
do you get sound from any input even static from am/fm this is the same receiver i have and had to replace the board on it. hope that helps let me know
Mar 19, 2011 | Harman Kardon AVR 130 Receiver
My Harmon Kardon AVR 500 sound doesn't work, I disconnected speakers, re connected & reset protection. Nos ound not even on test mode
Hi it is seem there is no output from your device. Please check the circuit components and wires for malfunction in your Kardon then. Regards
Feb 09, 2011 | Harman Kardon AVR 500 Receiver
Harman Kardon AVR 500 Only works in NON-Surff mode ?
This is a good indication that the surround processing section has a problem. This can be anything from a supply voltage being missing to a defective processing IC. Without testing inside the unit, it wil be difficult to determine. With surround procesing turned off, the entire section is bypassed. This is why standard stereo mode sounds OK. The static sound is digital noise and can be poor processing or a bad D/A converter IC.
Hope this helps,
Dan
Feb 26, 2010 | Harman Kardon AVR 500 Receiver
Hi, i am having problems with the multiroom on my AVR 630
Go into your OSD (on screed display).
Go to multiroom.
Change the SB AMPS from MAIN to MULTI.
Make sure you have only analogue sources, it will not amplify digital inputs for the MR.
Oct 09, 2009 | Harman Kardon AVR 630 Receiver
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
I PURCHASED FROM ABC WAREHOUSE HARMAN/KARDON AVR 340.ITS A FLOOR MODEL SOLD AS IS WITH OUT OWNERS MANUAL AND REMOTE.I REALLY NEEDA OWNERS MANUAL.CAN YOU HELP ME GET ONE?
Harmon Kardon AVR340 just has no sound and it doesn't pass the video through. Looks normal when on. ( Display shows everything is on)
Aug 26, 2008 | Harman Kardon Audio Players & Recorders
AVR 7000 audio/video receiver
Harman kardon amplifire are known for that.specially AVR 7000
but sometimes this comes from poor wiring and using a wire that will not conduct better sound. Remember your wiring is very important.you may think your wiring is currect, better to double check. even if your connection is ok and the wire you are using are not better to produce quality sound you will not get sound from every speaker.
good luck
Feb 28, 2008 | Harman Kardon AVR 7000
Harman Kardon AVR 340 Receiver Logo
799 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
