Question about Frigidaire Heating & Cooling
I have a model# fal125m1a1 was wondering how many btu it was
How to Replace broken fan on frigidaire air conditioner FAL125M1A1
Most of these AC units that are small in BTU size, under 15k, can't be repaired because most manufacturers don't have replacement parts available. Contact Frigidaire first.
Jul 30, 2012 | Frigidaire FAL125K1 Air Conditioner
I have the Model number and serial number but am unable to find the BTU's on mty furnace...Help please?
if you have the model number of the furnace, then you have the btu input of the furnace. The model number usually starts with letters, then the three numbers following the letters are usually the btu input of the furnace.
For instance if it said 075 then it would have an input rating of 75,000 btu/hr or if it said 125 then it would have an input rating of 125,000 btu/hr.
Hope this helps
Nov 16, 2010 | Heating & Cooling
How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
Btu's
That air handler can accamodate different size coils. Look for the coil model number. Also you can look at the outdoor unit model number they should be matched up. There is generally a set of 2-3 numbers in the model numbers that will tell you. xxx036xxx is 36,000 btu. tonnage is 12,000 btu per ton so 36,000 btu's would be 3 tons. xxx040xxx= 40,000btu's or 3.5 tons etc.
Mar 16, 2009 | Heating & Cooling
Btu or sq feet of home
tHATS DEPENDS ON YOUR PART OF THE COUNTRY YOU LIVE. DUE TO REQUIRED INSULATIONS VALUES!
Jun 09, 2008 | Weather King Heating & Cooling
Heating & Cooling Logo
105 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
