FixYa.com
Tags:
Scanners
Generic problem for all Scanners
Micro3 scanner
posted by broncolady on Apr 21, 2008
Hey! did you ever get your scanner to work? I have one that I just bought and it won't work. Any ideas?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 22, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
We haveno Manual for HR6 BFBA4601CU
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP Scanjet 4370 HP Open Box 9200C Digital Sender with Digital Sending Software 4.0 HP Scanjet 4400c Flatbed Scanner HP ScanJet 6200C Flatbed Scanner HP LaserJet 1200 Path-Through Scanner Panasonic KV-S3065CL Path-Through Scanner Acer AcerScan Prisa 620U Flatbed Scanner
Can you Help with these Scanners problems?
Microtek ScanMaker 3800 Flatbed Scanner
scanner problems
my scanner has no light on when... Answer This...
problems
the light is not on???have a... Answer This...
Microtek scanmaker 3840
configuration
when scanning a document, it... Answer This...
Canon DR-9080C Path-Through Scanner
gray
the documents are coming out... Answer This...
Fujitsu fi-4120C Path-Through Scanner
Fujitsu fi-4120c doesn't scan...
It used to scan duplex, but at... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
