Question about Cisco Linksys E2000 Advanced WirelessN Broadband Router Network Routers
Installing the CD with Linksys E2000 router and encounter "your router was not successfully set up"
  • 550 Answers
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Jul 17, 2010
After a few minutes up comes cannot see router
Posted on Feb 09, 2011
Can not get into e2000
Who is your Internet service provider?
If it is a DSL company then in some cases the router IP address may change to 192.168.0.1.
What happens when you try to open 192.168.1.1.
Does it ask you for user name and password?
Did you install router using cisco connect software?
Open cisco connect software.
go to router settings.
Click on Advanced settings.
It will open the setup page.
See Linksys E2000 router setup
Mar 05, 2012 | Cisco Linksys E2000 Advanced WirelessN...
Need Driver for the Linksys E2000 Advanced Wireless-N Router? Where can I download?
You can Find the Downloads Here
http://homesupport.cisco.com/en-us/wireless/linksys/E2000
Mar 06, 2011 | Cisco Linksys E2000 Advanced WirelessN...
My acer aspire one netbook will not connect with my new linksys e2000 router.. It was fine with my former linksys router
If your former linksys router was NOT N but rather b/g, then the problem is likely that your new router is running N and must be reconfigured to run b/g instead of n on its wireless. The acer aspire one netbook's integrated WiFi is 802.11b/g and the only way to do 802.11n is by using a plug-in USB 802.11n wireless adapter. To manually configure the router's wireless for 802.11b/g or n...
1. Connect the netbook using an ethernet utp cat5 patch cable between one of the four RJ-45 LAN ports on the router to the 10/100 ethernet RJ-45 port on the netbook's left side.
2. Start a browser like Internet Explorer and enter IP address 192.168.1.1 (default for Linksys)
3. On the login window, enter admin for username and admin for default password, then click OK
(The password may be changed if the router's setup software on its CD has been run.)
4. On the Linksys Setup page, click the Wireless tab
5. On the Linksys Wireless page, for Network Mode, click v for drop menu and click BG-Mixed
The preceding is from Chapter 3: Advanced Configuration which starts at page 16 of the 59-page Linksys E2000 user guide/manual. If you are missing this manual, it can be obtained by clicking...
http://homedownloads.cisco.com/downloads/userguide/E2000_UG_USA_V10_NC-WEB.pdf
A final note: The easiest way to setup the router is to run its setup software on the CD that comes with it. If you want to do this with the netbook (which doesn't have an internal CD drive), an external CD drive would have to be plugged into one of its USB ports.
Jan 25, 2011 | Cisco Linksys E2000 Advanced WirelessN...
I am trying to connect my new Cisco Linksys E2000, but I keep geeting a message to disable my other wireless networks. However, the router still does not complete set-up. What am I doing wrong?
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 02, 2011 | Cisco Linksys E2000 Advanced WirelessN...
How do I install software on cd from linksys when my acer netbook doesn't have a cd/dvd drive?
you will need to download the drivers from the internet and install them that way, no CD needed.
Dec 28, 2010 | Cisco Linksys E2000 Advanced WirelessN...
How to install the cisco links E2000 advance wireless N router in the computer. i tried bt cannot install it
there are two ways of installing a linksys E-series router
>>first is the easy setup disk/ if it will not work, try to dissable the firewall of your computer
>>if still doest work, you can access the setup page of the router with the DG, 192.168.1.1
>>for cable connection always do a mac address clone
>>for DSL, change the lan IP,
>>call linksys tech support, iwill be glad to solve your problem
Dec 12, 2010 | Cisco Linksys E2000 Advanced WirelessN...
Linksys E2000-i want to use wireless without password.
Yes
You can open the setup page of the router.
Go to the wireless tab and select the security mode to Disabled.
save the settings.
Click here to know how to access the router setup page.
Jun 30, 2010 | Cisco Linksys E2000 Advanced WirelessN...
Cisco Linksys E2000 Advanced WirelessN Broadband Router Network Routers Logo
2,075 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
