Question about Panasonic Toughbook 29 Touch (P/N CF-29ETPGLKM) - DISCONTINUED PC Desktop
My cf29-htm50bm has the following touchscreen error after doing the calibration...parameter error dtm please input again
3 Suggested Answers
Psych0Thrash
  • 53 Answers
SOURCE: Panasonic CF-18 toughbook. Reloaded
Try to clean all of the **** (dust and such) out of the void between the lcd bezel and the touchscreen. since they operate on pressure, like most touchpads, any debris caught in that void will make your touchscreen go berzerko
Posted on May 28, 2009
  • 10 Answers
SOURCE: I am trying to calibrate the touch screen and it
Your touchscreen is defective. Please contact Panasonic official service center http://heartlandsi.com to arrange a repair. It's covered under warranty.
Posted on Sep 29, 2009
Touchscreen windows xp pro
On the Panasonic Toughbook CF29,
the Touchscreen is the same as the "Mouse".
So you have to load the Touchpad/Touchscreen
Driver, not just the Touchscreen driver by itself.
The driver for the CF29 MK2 is located at this link:
.http://pc-dl.panasonic.co.jp/dl/docs/002940?dc%5B%5D=002001&lang=005&no=31&oc=001005&p1=115&p2=1150035&score=1.0&sri=9453997&trn_org=2
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jun 21, 2014 | Panasonic Toughbook Cf-29 Laptop/notebook
Touch screen doesnt work on my cf-29
Your Model CF29NWQGZBM the letter "W" indicates that this is a T/S (TouchScreen) Model.
Please verify that the "TouchScreen" is "Enabled" under the BIOS. I recently purchased about a dozen CF29's where there were absolutely NO scratches on the LCD. The reason WHY was because the TouchScreen had been DISABLED at the BIOS level.
I can also share with you another experience I had recently. I purchased approx. 15x CF29 models and every single unit had a defective TouchScreen. When I called Panasonic Canada I was told that since the units were no longer under the three year manufacturer warranty there was nothing they could do about it but that they were aware of this defect and it was a known defect.
I hope this information helps.
Regards from an authorized Panasonic Toughbook Dealer located in Montreal.
Jan 23, 2014 | Panasonic CF-29 (CF29NWQGZBM) PC Notebook
Ello My problem is when i boot after a factory reset i have touchscreen to calibrate and when i do it it gives me try once again it's stuck there
I am not sure you are talking about a tablet PC or the new craze of tablets.
For the tablet PC you should have a screen calibration utility. You can calibrate the display for the Wacom (or other) pen, or for the touch input.
When you calibrate the pen, any touching of the screen with anything other that the Wacom pen will be ignored.
Similarly, when you calibrate the touch, any input with the Wacom pen will be ignored and you will be asked to use the proper instrument.
To get back to your case , it is possible that you are not putting the finger at the right place or not pressing hard enough. That is just a guess and I may be off the mark for the new tablets, but not for the Tablets PC:
Apr 07, 2012 | Tablets & eReaders
Touch screen on tom tom one is out of alignment toward the top. bottom part of screen is ok.
I found this on the internet, hope it helps....
Touch screen Calibration.
Method valid for NavCore versions until 8.051.
A manual method to correct the calibration of the touchscreen input device of any all-in-one TomTom systems consists in creating a file called calib.txt (e.g., with notepad) and saving it in the main directory of the TomTom disk memory (e.g., the SD card; the same directory of the ttsystem file).
calib.txt should include one line with four numbers separated by a space: MaxX MinX MinY MaxY
Notice that the ‘x’ sequence (max, min) is inverted than the ‘y’ sequence (min, max). MaxX > MinX and MinY < MaxY.
For instance, the file can include:
928 118 107 912
Each TomTom device has its own most appropriate sequence.
In order to compile the file with default data, one method could be to perform a TomTom reset (or to eject the SD card), powering on the device and holding down the ON button for a few seconds until a unit status screen appears. The line named “Touchscreen calib. data:” will include four numbers that in sequence represent MinX MaxX MinY MaxY; these numbers can be used to fill the configuration line of calib.txt remembering to swap the first two ones. For example, if the unit status screen returns 118 928 107 912, calib.txt has to be saved with 928 118 107 912.
Tuning can then be done by adjusting these numbers until the touchscreen is calibrated. Distortions like screen rotation, trapezium and rhombus correction cannot be achieved with this method even if tuning these parameters can provide an acceptable touchscreen management even in presence of distortions; the best screen to tune the calibration is exploiting the soft keyboard of the NavCore application.
For instance, in my old TomTom GO Classic device I realized that, after activating the NavCore soft keyboard, when moving vertically (Y axis) the cursor appeared calibrated, while the horizontal movements (X axis) prevented to manage the left and right key columns (especially in the left bottom corner positions). So, I left the last two digits unaltered and, after some tests, I successfully used the following values: 805 200 107 912.
Method valid for NavCore versions post 8.051.
For NavCore versions 8.2x and 8.3x, use the same method as mentioned above, with these small differences:
the file should be named cal.txt (and not calib.txt) and should again be positioned in the main directory of the SD (or HD) drive of the TomTom system (e.g., the same directory where ttsystem can be found). Besides, the four numbers included in the file should have a different sequence than what previously described for versions until 8.51; cal.txt shall include the following sequence: MaxX MinX MaxY MinY (notice that also MaxY precedes MinY).
For instance, cal.txt could include the following four digits: 928 118 912 107
Again, these numbers are specific of each TomTom single unit.
E.g., my TomTom GO Classic correctly runs 840 245 912 107.
Feb 23, 2010 | Tomtom ONE GPS Receiver
My harmony touchscreen remote is working intermittently. sometimes taking out the batter works but it is not working now.
try recalibrating the lcd. to do this, please follow the steps below:
One can incorrectly calibrate the remote by pressing areas on LCD other than the ones marked during the calibration process.
Solution
To re-calibrate a remote which has been incorrectly calibrated, please follow these steps:
  1. Put the remote in safe mode.
    1. Remove the battery
    2. Hold down the System Off button on the remote while inserting the battery back into the remote
    3. Continue to hold the System Off button until the remotes LCD has lit up and reads Safe Mode
    4. Let go of the power button
  2. Reboot the Remote
    1. Remove the battery once more
    2. Re-insert the battery
  3. Follow the calibration wizard on the Remote to re-calibrate it by pressing on the areas indicated.
Jan 12, 2010 | Logitech Harmony 1000 LCD Touchscreen...
I am trying to calibrate the touch screen and it keeps giving me an error of "Parameter Error. Please input, again."
Sep 23, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic Toughbook CF-30 Touchscreen Calibration
Sep 14, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Touch pad seem to be out of calibration - when you touch anywhere on the screen, it highlights about 1/2 inch above where you are pointing - very hard to enter addresses etc.
not sure what tom tom you have but try this (found in a forum)
SAW THIS IN ANOTHER FORUM - RESOLUTION TO SCREEN CALIBRATION ISSUE
So I will give it a try to help sort out a friends TomTom.
928 118 107 912
May 19, 2009 | Tomtom ONE GPS Receiver
Panasonic CF-18 toughbook. Reloaded the correct touchscreen driver. After calibration, when I hit enter, I get "error Dtm, please try again"
Jun 27, 2008 | Computers & Internet
Touchscreen no longer works
Well watch this video and after you follow the directions get the screen and find the glass like cover and remove it from the screen bend it in a very lightly way, then put it back on and put the PDA back together and BAM.
Nov 07, 2007 | Palm Tungsten E2 (Multilingual) Handheld
Panasonic Toughbook 29 Touch (P/N CF-29ETPGLKM) - DISCONTINUED PC Desktop Logo
371 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
