Question about Conair Compact Garment Steamer Iron
I bought a Durabrand TSK-7538S Steam Iron for $12 at Wal-Mart. It's fine but the "instructions" are poor. I can't figure out how to set the temperature. I mean, I know you turn the dial, but where's the pointer/mark that you are supposed to align with the dial?
  • 1 more comment
  • Accounts112 Apr 21, 2008
    Unless you have this iron in hand, I doubt you can answer my query, unless you can tell me where I can find the Durabrand company, which probably isn't a real company anyway.
  • erwemw2 Aug 20, 2008
    The instructions leave a lot to be desired.There is one setting on the
    steam dial I can't even identify. The instructions don't even identify it.
    Ed Wittig erwemw2@ImOnMail.com
  • crittenden82
    crittenden82 Nov 05, 2012
    I can't figure how to turn the dumb thing on!!!
Okay. thats not a bad question, i got the same iron, and i know what your're talking about. the "line" you're talking about is not a line at all, it's actually a tiny plastic indicater at the bottom of the dial. it's blue too, so you cant see it, so feel on it with your finger. =) email me if i helped. solacewishes@yahoo.com
Posted on May 10, 2008
The green light does not come on and it does not steam
follow this adjustment and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in wa
Nov 04, 2013 | Oreck Steam-It Steam Wand
GC7320 : my appliance has been well rinsed out, but is unable to produce steam when it starts to 'pump'. What should I do, please?
see the instruction and fix it. God bless you
Clean an iron:
Jul 29, 2013 | Irons
Steam iron turns itself from hot temperature to cool
1) test the electronic control for defective and follow the next steps. God bless you
Clean an iron:
  1. Unplug the iron.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Jun 11, 2013 | Irons
Pump wont run
Clean an iron:
  1. Unplug the iron.
  4. God bless you
Apr 04, 2013 | Rowenta DG-980 Iron
Have sticky substance on bottom or iron - howcan i get it off?
follow this steps and fix it. God bless you
Clean an iron:
Mar 01, 2013 | Singer Irons
No steam coming out of iron can i take the plate of to clean
Time for a new one Wal-Mart have a great steam iron for under $10 dollars.
Jul 16, 2012 | Russell Hobbs Irons
I have lost my instructions on how to "self clean"
Straight from the manual:
http://www.applianceinsider.com/storage/user-manuals/rowenta/user-manual/DX8000.pdf
Fill the iron with tap water to the max mark on the water tank.
Be sure that variable steam lever is set to minimum.
Stand iron on heel and plug in. • Set thermostat to ••• setting.
Once heated, unplug iron.
Hold iron horizontally over the sink with the soleplate pointing away from body.
Move the variable steam lever completely to the right and hold in the self clean position for one minute.
Warning: Doing this will cause steam and hot water to be ejected from the soleplate. Take all proper precautions and hold iron away from body.
• Move the iron gently back and forth and side to side until all water has run through plate.
• Carefully wipe all water and material from the soleplate with an old towel, as the water and minerals can stain the soleplate (although this has no effect on glide or performance.)
Warning: Iron and soleplate may still be very hot. Exercise care while wiping.
• Place iron on heel and leave to cool. Before using iron after self cleaning, test steam and burst
of steam on an old towel or cloth than can be discarded.
May 04, 2011 | Rowenta Professional DX8800 Iron
Suddenly began leaking and overheating, such as too hot for demin but only set of min. Last time this happened I bought a new iron. The new one has been dropped - last year but nothing recently and this...
The iron started leaking from front and back. took iron back to Wal Mart and got another iron and it did the same thing. I cannot use the iron because it is hard to hold the steam almost burn your hands because it leaks a lot all over my cloths . I was so disgusted with the iron until I just put it in the corner and bought another iron from wal mart. I did not know if they would take the iron back , because I had it for a bout (3) months.
Aug 06, 2009 | Rowenta DG-920 Iron
Rust
A few cheap n easy ideas I hope will help you...
  • You could try using a car radiator flush treatment such as rust & scale inhibitor to flush the water tank.
  • Fill water tank with Coca-Cola . Let it soak at least overnight and rinse out thoroughly.Think im crazy? Leave a old coin in a glass a coke for a few days and see what happens!!
  • Refrain from using tap water to fill the iron. Use distilled water ,it's has less of the impurities that cause rust and other metal-oxides forming
  • If all else fails use a small spray bottle of water on the clothes that are at most risk of being soiled.
That way you can add fragrance oil or other things to the water that would normally get boiled off /or pollute the water tank :)
May 26, 2008 | Black & Decker Steam Xpress AS250 Iron...
Rowenta Iron
Special screw called "Torx tamper proof" call 925 8271011 and order "Rowenta tool" $10.00 plus shipping-this place also sells Rowenta parts
Apr 09, 2007 | Rowenta Professional DX8800 Iron
Conair Compact Garment Steamer Iron Logo
951 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
