Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
Pilot lite went out and will not relite
Pilotflame ignites only when lite button is depressed
I have a Craftsmaster 50 gallon hot water heater. I've replaced the whole inside part and it run about 12 hours and went out and the pilot light goes out when you release the part you hold down for so many seconds and its not the orifice, it's been checked.
Posted on Jul 19, 2010
    Habit-Forming:
  • 8 Answers
The thermocouple is not functioning. The t/c is the small (sensor) tube that the flame touches and should have a small copper tube (capillary) extending to the gas valve. (IMPORTANT: The capillary tube should not have any kinks or crimped places...Only gentle bends. A crimped tube will require t/c replacement.) The flame will deposit a coating (minerals) that will insulate the t/c and prevent it from working. Clean the sensor with steel wool, fine sand paper (emery board) or scotch pad. Now try to relight the pilot making sure the t/c sensor is contacted by the flame, if not, shut off gas and adjust. Once aligned and contacted by pilot flame, hold for a minute, allowing the t/c to warm up fully and signal the gas valve to operate when knob is turned from pilot to operate.
Posted on Jul 18, 2010
Have a new richmond water heater.there was no hotwater.i checked the water heater pilot was not lit.i relight it, it lite.turn to temp settings pilot went out.relit it againmade a explosion bom sound
the explosion was from a build up of gas that was not properly ignited by the pilot light or was leaking into the combustion box when there was no pilot light
there is a serious problem in the gas control system that needs urgent professional assistance to fix
you were lucky as it could have blown you out of the room
get in an experienced gas fitter as it is not a diy job
May 11, 2016 | Water Water Heaters
The pilot light on the water heater went out and the red light is blinking four times on the thermostat (Honeywell WV8860B1317). How do I get this to stop so that the pilot light can be relit?
The flashing light 4 times indicates high water temperature has activated the over heat sensor, and that the only remedy is to replace the gas control valve/thermostat.
Dec 08, 2014 | Water Water Heaters
Why does my pilot light on my hot water take not stay lite
It depends on many factors, including brand, type of heater, age, gas pressure, maintenance, venting, proper installation of thermocouple, bad thermocouple, air intake cleaning, if the flame is clear blue etc.
Copy following link to read more:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
Sep 20, 2012 | Water Heaters
How do I relight my 10H Hydropower? It went out in the rains last night. Casing instructions have faded and on/off switch referred to in an online manaul doesn't exist.
the 10 h does not need to be relit it does not have a perminant pilot when you turn on your tap the water flowsthe hydro ignitor spins igniting the pilot and then the burner.
May 30, 2011 | Water Heaters
Can not get pilot to lite was working fine had to turn off gas will I changed out some water pipe went to relite and could not get pilot to lite
I would first make absolutly sure that I had all air bleed out of gas line to water heater. If you are trying to bleed air out thru pilot assembly this can take a long time because the opening in pilot orifice is very small. To speed up process if you have a union close to unit or flex connector,you can slightly loosen fitting till you can hear a little hiss of escaping air/gas. When you first smell gas immedieatly tighten fitting. Before you do this make sure there are no standing piloy lights or other sources of flame in the vicinity. When you smell gas and tighten fitting back up try to relight pilot to water heater.If you still can't get pilot to light I would remove pilot line from gas valve and burner. Check to see if you can blow thru it, visually inspect pilot orifice, and if blocked I would get a orifice cleaning tool from hardware or welding supply store. Be careful to select the right size for your orifice and clean it. Reinstall and try to light pilot again.Hope this helps. Thanks
Nov 17, 2010 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Hi im having trouble lighting my water heater and turn the water to hot. it says push and hold the knob and repeatedly press until pilot ignites.
after pilot lite you got to hold it down for 45 sec before you can turn it on..if you still having trouble get a qualify technician to relite it.
Aug 09, 2010 | Honeywell Water Heaters
My 3 year old "Smart Water" heater will not turn on. No hot water
It sounds like there is air in the line, so open the gas line just a little for a few short seconds to let some gas out, after that, keep the one red dial on pilot then turn the other to about medium. Light the pilot by depressing the red button, then once the pilot is lite, continue to hold the red button for about 1 minute, Once that is done slowly release the button and then turn the dial that is set to pilot to on position and give it about 1 hour to heat up
May 08, 2010 | General Electric GE SmartWater Household...
Pilot light went out but will can,t get it relit it only stays on as long as I hold the button down
Is the thermocouple in the pilot flame? & does it get hot [glow red] If not adjust position until it does & make sure it's clean
If thermocouple gets hot but no relight, replace couple
Oct 26, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
My hot water tanks pilot light turns off after I have relit it. It stayed on while heating the water in the tank and once it stopped heating the pilot light went out again. What would be causing my...
are you holding button down long enough for thermal coupler to warm up? after pilot lights up, don't immediately let go of button for about 15 to 20 seconds then let go and pilot should stay on. If not, you may need a new thermal coupler for that water heater
Jul 03, 2009 | Water Heaters
Pilot went out and wont re lite
hi there i come from the uk, but it sounds to me as though it maynot be a thermocouple as if it was the pilot would light when you held it in & go out when you let it go.
it seems to me as though the pilot injector could be blocked no gas getting through to it ? or possibly there is a break in the insulation of the igniter so that when you try & light it it just earths out to the heaters metalwork.
These are just a few ideas that might shed some light on your problem?
Kindly
Richie
Dec 15, 2008 | Water Heaters
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
236 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
