Wiring diagram for Dimplex wall heater Model 6100770000
Wiring diagram for Dimplex wall heater Model #6100770000
Black wire connection came loose and I'm not sure wherte to reattach.
  • Anonymous Mar 15, 2014
    see wiring diagram of air heater model no 6901181100
Installing a wall mount heater not sure on the wiring .heater has 3 wire black red and blue sources has white and black what wires go together
Posted on Dec 11, 2010
How do i wire a night store heater when using a fixed cable switch
Posted on Jun 24, 2013
I have a small wall heater, towel rack included, the fan & timer work, but no heat. Where do we find the model number
Usually on a small sticker on the back near where the wire goes into it.
If you know the make you can Google it and look at the images tab like this for 'Dimplex bathroom fan heater'.
dimplex bathroom fan heaters Google Search
Jan 22, 2016 | Heating & Cooling
Dimplex DS3311 switch is overheating and melting. What to do?
How long does it take before the switch melts?
You could try retrofitting a switch from the hardware store that has a higher watt/amp rating...
Jan 16, 2013 | Dimplex Heating & Cooling
I need a new flame generator drive motor / spinner for my Dimplex Model No. 6901050100
what kind of on off switch do i need ,has one black wire and one white wire?
Oct 14, 2010 | Dimplex DS5598 Mid-Size Heater
How to install a wall dimplex thermostat to a dimplex fan wall heater /RDH2010tcw/1000/2000W/240
disconnect wire A from the thermostat, and connect it directly to one of the supply wires. Connect B and C to the other for 2000W.
Mar 03, 2010 | Heating & Cooling
I have a Dimplex in wall heater model 690221900 120 volt 1500 watt. Their is a 110 volt feed line (black, white and ground wire)coming in to the heater housing as well their is a two wire thermostat...
Well, for your wiring, there's nothing wrong with it, So, I think there's two way to find out which ones is wrong, first:
Install your heater without thermostat first, is it working, does the breaker blowing!!!.
If No, then your thermostat is the cause, but if Yes, then,
second:
Try install it with the new breaker with 10 A minimum, you must replace the breaker with new ones.When it's OK, then try install the thermostat too.
Hope it works!!!
Dec 09, 2009 | Sewing Machines
Baseboard electric heater installed properly, yet won't work.
DID YOU CONNECT TO TH SAME END YOU TOOK OUT WHEN PAINTING WE ARE DOWN TO THE CONNECTION @ THE HEATER MAKE SURE THE OTHER END OF TH ELEMENT IS CLOSED WITH WIRE NUTS AND TIGHT , LIKE I SAID WE ARE DOWN TO THE HEATER CONNECTIONS SO LOOK THERE
Nov 22, 2008 | Fahrenheat Electric Convector Baseboard...
The switch broke on my model DS3311 and while taking it apart, it broke the one of the other switches. I need two switchs and the wiring diagram for this model
Either go to: www.dimplex.com or call their number: 1-800-668-6663 ext : 358 They are very helpful!
They can help you with a reapir manual you can download as well!
Nov 19, 2008 | Dimplex Compact Electric Flame Stove...
Install and hot wire heater
You can be assured that the element is 240 volt. The fan motor is also rated at 240 volt. the wires you have black - black are the connections you make to the line. Use a 12/2 with ground. Use a double pole 20 breaker in your panelbox. The green wire is the equipment ground - connect this to the bare wire from the 12/2. On the 12/2 cable - there will be two colors, one black and one white. Wrap a couple of turns of black tape on the white wire both at the heater location and on the white in the panelbox. connect the 12/2 to your 2 pole breaker, the black wire and the taped white to the breaker.
Sep 05, 2007 | Fahrenheat FFH1615 Heater
Heating & Cooling Logo
1,485 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
